[h=4]Delta Hybrid Saw Set Up [/h][h=6]Rate this Entry[/h]
0 Comments
by badger fan
, 01-13-2016 at 02:32 PM (1 Views)
Categories Uncategorized
0 Comments
by badger fan
I have purchased a 10" Hybrid table saw that was new in 2008 and has not been used very much at all. I wanted to be sure and set the saw up or check the set up to insure that everything is good to go, so I have been reading on line and reviewing the manual regarding blade alignment with the miter slots. In following the instructions, I have loosen the two trunion bolts and taped it as much I it will move for alignment. It is close but when measuring from the same tooth front to back as the instructions suggest, I find that it is still out maybe a 1/32".
I would like to get this set exactly of course and I do not really know what else to do. I tried calling the Delta technical help desk but they are down and said to call be in a few hours. Go figure.
Has any body had a similar problem with a Delta saw and if so any suggestions on how to fix this.
My thoughts are that since I do not believe there is any more movement (as little as there is) on aligning the trunion, that one wold have to dismantle the saw to get the holes enlarged (allowing move room to move). I hate thinking about this and hope there is someway other than that to address this.
Could really use some help.
Thanks,
Thanks,
