Oneway 1224 Wood Lathe w/Accessories
Oneway 1224 Wood Lathe w/Accessories - tools - by owner - sale
Oneway 1224 Wood Lathe in pristine condition. Includes all Oneway 1224 standard package equipment plus the following:
6" Tool Rest
Vari-Grind Tool Sharpening Guide Tool
Bowl Steady
Spindle Steady
24" Bed Extension
Custom Made 6 Drawer Tool/Accessory Box
Description
GENERAL DIMENSIONS
■ Spindle Height: 44½”
■ Power Input: 110V, Single Phase ■ Length x Width: 47 x 23½”
■ Bench Height: 30”
■ Weight: Approximately 300 lbs.
12½” swing over the bed (9” swing over Banjo) 24” between centers
11” Stainless Steel Toolrest with 1” Post
2 step pulley (50 - 2000 / 100 - 4000 rpm)
Two position Control Box
Spindle is hardened and ground
Spindle Thread: 1” - 8tpi RH (inboard
¾” - 16tpi RH (outboard)
7/16” thru hole (in spindle)
24 position indexing
#2 Morse Taper in headstock & tailstock
Forward & Reverse with two pre-programmed accel / decel settings
110V input, 1HP AC variable speed inverter (drive) with dynamic braking (220V also available)
1HP Marathon Motor
High Performance Powder Paint on Stand & Lathe Cast Iron Tailstock with Acme thread & 3” quill travel Patented clamping mechanism in Banjo
Offset Bed for easy clean up
PACKAGE INCLUDES
■ #2 MT Safe Driver
■ #2 MT Live Center (with cones)
■ Knock-out Rod
■ Powder Painted Metal Stand
(two wood shelves included)
■ 3” Steel Faceplate (Powder Painted)
■ 11” Stainless Steel Toolrest
■ Two location Control Box
■ Powder Painted Lathe
■ Leveling Pads
■ 4mm, 6mm and 8mm Allen Keys
■ Spindle Lock Wrench
■ Hand Wheel
This package new would cost a little over $4,000 including tax, and delivery........so in pristine condition at $1,850 this is a great buy.
This lathe is a professional level tool in every aspect. It's a precision machine......that won't break the bank.
This is a cash sale, and serious, financially qualified buyers are encouraged to text or call seven 5 seven 6 nine 6 one 4 seven 5.
Local delivery may be available.
6" Tool Rest
Bowl Steady
Spindle Steady
24" Bed Extension
Description
GENERAL DIMENSIONS
■ Bench Height: 30”
1HP Marathon Motor
PACKAGE INCLUDES
■ #2 MT Safe Driver
■ Knock-out Rod
■ Leveling Pads
■ Hand Wheel
