Travis - I could help you this weekend. I'm tied up the following two weekends. If I spray the lacquer he'd never ask you to do anything again! :rotflm:
I hope you chewed on the neighbor's tail for a while. He should be there offering manual labor and helper-level support.
Chuck
We had a very robust chat. I am no longer under deadlines or feeling rushed, and I am now starting to get some help. Still, it is a lot of work.
Here are some more pics and some updates. All of the cabinet carcasses are assembled with screws using my Kreg pocket hole jig. No dadoes, just a rabbet for the backs. Here you can also see the holes and the shelf supports I will be using. I borrowed a 13 spindle line borer for the shelf pin holes. I wouldn't mind having one myself.
Here are the shelf supports for the bar. Solid maple (actually hard maple left over from my workbench project). I fastened them to a strip of plywood to make them easier to handle for finishing.
Here are all the plywood parts for the uppers. They are just rough sized at the moment.
Here is the spray rack I made for this endeavor. I have already shrunk it once, but I need to shrink it again. Still a bit on the large size so I expect I will be shrinking it again when I get the time. It took a around 20 six foot long poplar dowels to make it. To Jeff's point, all made in China :-(.
Overall, construction isn't bad, but the finishing is the pits and I am not happy with the way it is working out. The color is pretty dark and using toner (dye mixed with the finish) is not coming out even as I would like because it is so dark. Additionally, if I sand even lightly between finish top coats I am cutting through the dye layer and it is not good. Personally, I hate finishing maple as it is splotchy, to me, splotchier than pine or cherry so I am looking for suggestions.
Should I whip up a batch of straight dye mix it with alcohol and spray it or break down and go the pigment stain route? I will probably need to do something like Minwax wood conditioner, but if it makes finishing easier, I definitely want to do it. The color shouldn't be too hard to match. It looks like an almost exact match for Minwax red mahogany.
Any and all suggestions and comments would be appreciated....
