best type of flush trim router bit for burl veneer as well as plain cut veneer?
kooshball
I am dangerously close to the veneering stage of my speaker build and want to ensure that i don't make any critical mistakes at this point in the project. I will be veneering the front baffles with burl and the rest of the cabinet with plan sawn veneer.
What type of flush cut router bit is going to give me the best chance for success with the burl...I assume it will also be appropriate for the plain sawn?
Thanks
ehpoole
Ethan
David,
My preferred flush trim bit is usually my 1/2" solid carbide upcut spiral flush trim bit. My second choice would be a shear (as in diagonal) cutting flush trim bit -- in which case you can experiment with such bits of varying diameter (even some stepped rabbeting sets include a large diameter flush trim cutter).
You will find it helpful to first trim all but a small portion of the overhang away beforehand so that you are left removing only a thin sliver on the final pass. You may also find it helpful to back off on the router's speed (i.e. speed control) to prevent burning and allow you to advance the router more slowly to reduce tear out -- at least this is what I have found helpful when working with Purpleheart which is an exceptionally stubborn wood to do complex routing on!
Regardless, it is always best to experiment on a sample piece before you tackle the real thing.
kooshball
David,
I guess up vs. down cut spiral depends on where your router is (i.e. handheld vs. table)...either way, I assume that you want to spiral to drive material into the work / substrate to prevent it from peeling up. Is this the correct assumption?
Thx
ehpoole
Ethan
Thx
The terms can be confusing, but "Upcut" draws the waste *towards* the router and is a great general purpose bit for handheld and table mounted use. It also ensures that you always maintain full control over the router and workpiece because it is always pulling the two towards the router's subbase (or the router table's surface) so there is little chance of loosing control of the router. If you have dust collection, these bits are compatible with dust collection because they pull the waste towards the router's dust collection port or below the router table.
A "Downcut" is more along the lines of what you are describing, but downcut can create control issues if you try to take too great of a bite because it will be pushing the router *away* from the control surface (i.e. trying to physically lift the router). This can be especially troubling if something catches and you are not expecting it because there is a chance of loosing control of the router in a handheld operation. If you have dust collection, these bits are generally not terribly compatible with such as they are either pushing the waste towards the floor if handheld or launching it straight up into the air when table mounted.
Even so, I don't usually have an issue with tearout, even in difficult woods, when using an upcut spiral and if you do you have a couple of alternative solutions to address the concern: 1) tape the edge with a low-tack masking tape so that the tape provides added stability -- the router will cut clean through the tape; 2) Use some masonite (plywood, etc.) to make a zero-clearance subbase for the bit (drill the hole 1/64" larger than the spiral bit's diameter, or ream/file it out a little after drilling); or 3) use a thin piece of masonite (plywood, etc.) taped down to the veneer (you need only tape it enough to keep it in place and under control, no need for double-sided tape) -- the masonite will provide the necessary support to prevent tear out. If you should get very minor tear out, you can always follow up with a chamfering bit (or even sanding block at an angle) to chamfer the edges slightly, which would also make the veneer less prone to lifting when something catches the edge of the veneer in terms of normal wear and tear, so there is that recovery option if needed.
Typically, I find lots of opportunities to make use of upcut spiral bits, but only rare opportunities where a downcut bit would be substantially more preferable. If you do opt for a downcut I would only use to remove the very last sliver of remaining wood and not for removing any significant quantity of overhang. There are also some combo upcut/downcut versions (e.g. half and half) made specifically to try and manage both concerns (similar to some combo reverse/normal scrollsaw and jigsaw blades), but I have no experience with them and can offer no opinions.
Ultimately, though, it is your creation and you should base your decision upon what you believe is best as I'm not the one that will exchanging expletives with the wood if something goes wrong!
Best of luck and we really look forward to the photos when you are finished!
Joe Scharle
For me, it's upcut for mortises, downcut for dados (esp in plywood) and a flush trim bit for veneer(one case where I prefer smaller bits). JMTCW!
nelsone
Ed
Burl veneer? Sounds like a job for a knife, file and sandpaper. Even with a spiral bit, I think you would risk tear out.
Matt Furjanic
I think Ed Nelson has it right. You are only removing 20-30 thousandths of material. A flush trim bit is really not necessary. Use some fairly coarse sandpaper - about 100 grit, glued to a wood block. This always works for me.
merrill77
Master Scrap Maker
If you are flush-trimming veneer, I'm with nelsone - hand tools. Knife, fine-tooth saw (veneer saw?), maybe a block plane.
