If you never want to do a cross-cut using a miter gauge, then fine. If all you do is scroll, pretty much moot anyway as the fence is out of the picture. Or only re-saw, then sure, adjust the fence. I use my saw for almost everything so skewing the fence does not work. My fence needs to adjust to match the table T- track, just like on a table saw. The closer to the perfect center the bottom of the gullet is, the more consistent it tracks. Of course, tires may change this, but when I measured and marked my center, it got a lot easier and quicker. Tire center of crown is actually hard to eyeball and that will lead to frustration. I was usually a little too far forward. Half a day? Have to admit it took me longer than that to master. If your tires are getting hard, or don't have enough crown, and the gullets not too deep, then I can see how the Snodgrass tracking might behave as if you were too far back. How quickly set is damaged by being too far back I don't know. Kiss a guide once and you are done for. As a procedure, when changing bands, I adjust the tracking forward until I see how it will be running as I slowly spin while levering in the tension.
Another thing that throws any tracking off is not getting the rear guides within half a hair of the blade. Add low tension and the process of cutting will move the tracking and twist the band. The more narrow the band, the more sensitive I found. Getting a 3/8 blade to not skew in an 8 inch resaw is really really hard. 3/4 seems easier than 1/2. Blades with less than perfect aligned welds make this very hard. As the lower guide is harder to see and adjust, it is often left not as perfect as it needs to be. If a side bearing starts to spin, it usually means I am feeding too fast. Guess you can't use that with disk or block guides though. Surface wear of the rear guide or miss-alignment can also twist the band. I had the alignment issue on a 10 inch Delta. I suspect the rear guides sitting flat may be less sensitive than the ones like mine running on the circumference for wear.
Repositioning the trunnions on my saw to align the table to the drift would be many times harder and would not lend itself to the small tweaks in tracking as a blade wears. On my saw, no more than 1/8 turn on the tracking knob is all I need. I can envision a design that would make it easier much like some table saws have screws to align the table. Alas, there has been about no innovation in band saws in the last 100 years. Opportunity awaits!
I only adjust the guides when changing blades. As every band is different, you have to anyway. And yes many books, "experts",, and video's, lead you to less than optimal ways. Posts to skew the re-saw to follow the drift? Hand guiding re-saw without a fence? Magic sleds? I understand the Snodgrass method as the physics of the pivot point makes sense. Move the pivot point back on the blade like most books show and variations in the wood would more naturally twist the blade. I believe carbide re-saw blades have a more consistent set by way of grinding instead of running between two gears.
