I have long wanted a better way to resaw stuff, so I made the trip down east to see a Hitachi CB75 from craigslist (thanks Martin)....it is a little rough and history says it was used mostly to resaw reclaimed barn wood....not a lot of evidence of TLC. But I brought it home
unloaded it
and began the survey. The table need a little elbow grease
The blade is a 1" and has more history than future.
The upper guides are phenolic plates (I think) and the upper thrust bearing is fused to the point that the back of the blade has worn a groove in it.
The rack and pinion fence system works pretty well but needs some new fasteners. The wheels are heavy cast iron and turn easily and smoothly
The lower blade guides are again phenolic? plates but I can see no thrust bearing or place to mount one...maybe it doesn't need one?
The motor is a bitsy thing with apparently gearing that makes it suitable to the blade. It is very noisy.....I think I will eventually replace the motor.
The blade tension adjustment and blade tracking mechanism are very sturdy and easy to use.
The standard blade for this saw is a 3" stellite blade...but I will likely start of with a 1".
Not sure of the vintage, still searching. If anybody can help with that I will appreciate it.
So it looks like I have some things to do before it is set up and running. Stay tuned.
unloaded it
