Hello All,
Thought I'd ask the brain trust for some advice on adding some additional outlets and shop lights. To be honest, electricity is not my area of expertise, although I do have some experience in wiring things for work (mainly repairing/resoldering connections). So perhaps, the best advice is to point me to a good book on the basics of electricity and wiring or maybe it's easy enough that I can do it without that.
I just replaced the original light fixture with one of those LED "strip" lights that's supposed to last for 20 years or whatever. While that light is definitely bright, it is still a little dark around the edges of the shop. So I thought about adding at least two more lights (one on each side) and maybe a third along the back wall. As of now, there is only one switch, that operates the main light. I'm not sure if it would be better to add an additional switch for the other lights as sometimes it may not need to be blindingly lit up in there. :gar-La; As for access, the panel is on one of the walls of the garage and there is attic space above the garage, so I could crawl around up there as needed. As of now, I have two outlets, one on each side (plus one above the garage door). I would like to add at least one additional outlet on the back wall (which is an internal wall) and possibly one more outlet on each side. Any advice is greatly appreciated.
Thanks,
Trent
Thanks,
Trent
