I have an old 6" Delta and with the way I use it, a 4" would be adequate because I only ever edge joint.
When I need to true a face, it is often larger than 8". So I use the sled + planer method. With a particle board sled and careful shims/hot glue you can get just as flat a surface as a jointer. And my lunchbox planer goes up to 12"!
The only advantage of a wide jointer over the planer+sled method is time. And I'm a hobbiest, so a few more minutes doesn't bother me.
