Help us understand why this or the Wixey or a bevel "has serious limitation or flat out doesn’t work"
@Scott H you are showing an obtuse angle there at 165if you would rotate that 180 degrees you would have something similar to what @pop-pop is showing or 15 degrees acute... that is what I don't understand - he is getting 28 degrees as a direct reading on his gage...Unless I'm missing something obvious you cannot take a direct reading of about 15 degrees or less because of the way the tool is designed. The spot you would put the thing to measure closes up. You could use a square block to measure it as 105 degrees instead but that is an extra step.
Situations seem to pop up all too often where the bulk of the tool gets in the way of making the measurement. To be expected I guess since some sort of swivel is needed.Help us understand why this or the Wixey or a bevel "has serious limitation or flat out doesn’t work"
I have some really good angle measuring tools, but if I need something accurate to less than 1 degree I don’t trust any of them. Like you and others I will draw it in a Cad program. However I don’t trust a print-out either. I will use the numbers from my cad layout and draw it out with 2 legs being a minimum of 24” or whatever it takes to exaggerate the geometry.My query here is to make sure that I am not missing out on some clever tool.
RIGHT!@Hmerkle Sorry, I am being unclear, maybe this is a better illustration of what I'm referring to. I am sure you have used these plenty so I am probably just communicating poorly.
If you have an angle of say 25+ degrees there is the angle formed by the two pieces you can stick something into, so either you set the gauge by closing it on the item and reading, or set it to a reading and look for daylight. When the angle is too small that gap closes up and the best you can do is what I have in the 2nd picture (10 degree angle) which doesn't feel anywhere near as positive/accurate of a reading, compared to things mechanically touching or seeing daylight through a gauge. It's fine for getting kinda close though.
RIGHT!
But don't use it that way...
Use the long end of the measuring arm to create an acute angle like @pop-pop did and take the measurement on the other side of the protractor:
