Klingspor's Woodworking Shop (Locations) Ad #1
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 31
  1. #16
    DQ
    Nickname
    Alan Schaffter
    Join Date
    Dec 2005
    Location
    Washington, NC
    Posts
    2,896
    Visit Freq
    2.54 visits/week
    Threads
    270
    Classifieds
    Re: Bowclamp clamping cauls reviewed
    Do they have a durable and smooth enough finish so glue doesn't stick or can be easily scraped off? If I hadn't paid about 1/2 of what the Bow Clamps cost for my Besseys (during the Bessey frenzies of a few years) I'd think about buying a couple.
    I still would like to see a test with a number of pressure strain gauges spaced along the joint. And also do the engineering and see what it costs to make my own- the curve should be easy to determine and draw with a computer and CAD program.
  2. #17
    Returning Member NCPete's Avatar
    Nickname
    Pete Davio
    Join Date
    Dec 2005
    Location
    Hope Mills, NC
    Posts
    5,512
    Visit Freq
    0.12 visits/week
    Threads
    161
    Classifieds
    Hey, he is over 30!!! He can't be trusted! :lol:
    Failure is the opportunity to begin again more intelligently. Henry Ford
    However your life is, meet it and live it.
    Henry David Thoreau
  3. #18
    Staff Advisor
    DaveO's Avatar
    Nickname
    DaveO (48)
    Join Date
    Aug 2005
    Location
    Clayton, NC
    Posts
    15,304
    Visit Freq
    0.85 visits/week
    Threads
    556
    Classifieds
    Quote Originally Posted by Alan in Little Washington View Post
    I still would like to see a test with a number of pressure strain gages spaced along the joint. And also do the engineering and see what it costs to make my own- the curve should be easy to determine and draw with a computer and CAD program.
    Alan, I e-mailed with Craig and asked about the pressure that they applied and if it was comparable to a clamp like a Bessey. He told me that in the design his aim was for 150 psi across the entire length of the caul. He also has some engineering type test with a material that is compressed and the measured with calipers to show that the pressure is even across the whole length.
    They are waxed to prevent glue from sticking, but if I was to use them as cauls that would be in direct contact with a glue line (like keeping a panel flat) I would consider putting some packing tape over the faces just as an extra precaution.
    I don't think that the design would be to hard to duplicate by following the original, but I still think that it would be more work than it's worth.
    Dave:-)
    :-D Nothing left to do but smile, smile, smile :-D
    --Dr. Seuss
  4. #19
    DQ
    mkepke's Avatar
    Nickname
    Join Date
    Nov 2005
    Location
    Fuquay Varina, NC
    Posts
    1,335
    Visit Freq
    1.88 visits/week
    Threads
    115
    Classifieds
    I'm sorry, you lost me at:
    "I was making a cat bed out of lacewood".
    :lol:
    -Mark
  5. #20
    Staff Advisor
    DaveO's Avatar
    Nickname
    DaveO (48)
    Join Date
    Aug 2005
    Location
    Clayton, NC
    Posts
    15,304
    Visit Freq
    0.85 visits/week
    Threads
    556
    Classifieds
    OK, let's call it a doll bed for my daughter, as I don't think that the cat will sleep in it without some adhesive persuasion. Although I did build a cat tree and they took to that like a fish to water.
    I just needed something to make ops: ...I can't just glue boards together for no reason, and the cat bed was my wifes suggestion. Wife wants = more shop time with less grief :-D :-D
    Dave:-)
    --Dr. Seuss
  6. #21
    Forum Leader User
    DQ
    cskipper's Avatar
    Nickname
    Cathy (63)
    Join Date
    Oct 2005
    Location
    Forest City, NC
    Posts
    8,380
    Visit Freq
    2.31 visits/week
    Threads
    590
    Classifieds
    Quote Originally Posted by DaveO View Post
    Dave:-)
    Dave, youi can send me that glued-up wood! It'd make some pretty trivets....
    Cathy Skipper
  7. #22
    Returning Member DavidF's Avatar
    Nickname
    David (62)
    Join Date
    Oct 2005
    Location
    Lydlinch UK, NC
    Posts
    4,198
    Visit Freq
    0.12 visits/week
    Threads
    140
    Classifieds
    Bow clamp clamping cauls
    Just a quick impression of the Bow clamp clamping cauls as DaveO did a fine job in his review.
    My first thoughts when I started to use these was how well made they were and how nice they felt! My project was 19" long and 3 x 5" wide cherry being glued up into a panel. I had to use a 1/2" spacer under the panels to lift the pieces up sufficiently to allow the cauls to sit centred on the edges. No problem, just used 1/2 MDF under plastic sheet to prevent sticking. Got two of my cheapo F clamps and started clamping. Here is were I came across the first little difficulty. The boards were not sitting level and because of the pressure in the centre being so much greater than the outsides; I had to remove a lot of the end load in order to adjust the boards; adjusting them level was done with a dead blow, but I also wanted to shift them sideways. When I had removed enough pressure to do this I had lost some of the stability of the whole setup and the levels changed again. Not a serious flaw, but still.. Then I had a small "explosion" The cauls had shifted all the way to one side and therefore one of my clamps was near the ends of my boards, the other was 4 or 5 inches off the other end. I released a little too much pressure off the close in clamp and all **** broke loose as the clamp slip out of the grooves and the because pressure was still being applied at the other end...well you know what happened! glued up boards all over the place, cauls, clamps.. etc... So lesson learned - don't use cauls that are overly long for the project in hand. At that point I didn't like them! The I continued and found the next slight problem. My clamps are cheap as I said and with the 24" caul I was using I couldn't quite get the caul closed up right on the ends because my clamp was bending instead! This left a tiny gap on one end. With a normal setup I could have closed that gap with the clamp without the additional force required to overcome the bend in the caul. Lesson learned - use better clamps! However I tried I could not get the panel to sit quite flat when clamped up even though the joints were good; perhaps a bigger spacer would have allowed my to juggle the position of the caul to adjust for this. Top pressure from more straight cauls fixed that.
    At the end of clamping up 6 sets of panels I would buy these for my shop. Not sure whether the 24" is strictly necessary because it only takes 3 clamps to clamp that distance anyway, but the 36" would be nice. Over all I like them. I would like to try the woodcraft panel clamps that apply downward pressure as well with a user supplied 2 x 2.
    You can see the clamp bending here.
    And the small gap. Changing to a standard bar clamp not an F clamp fixed the problem.
    The woodcraft system. I would like to try this.
    WOODCRAFT Clamping System
    "There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
  8. #23
    DQ
    Nickname
    Chuck
    Join Date
    Nov 2005
    Location
    Rocky Mount, NC
    Posts
    2,783
    Visit Freq
    0.00 visits/week
    Threads
    120
    Classifieds
    Re: Bow clamp clamping cauls
    Thanks for the review. I wonder how much force is applied at the point that the cauls are perfectly flat against the panel sides?
    Sounds like you handled the "explosion" well. I get a little edgy when a glue up heads South. :lol:
    Chuck
  9. #24
    Nickname
    David (62)
    Join Date
    Oct 2005
    Location
    Lydlinch UK, NC
    Posts
    4,198
    Visit Freq
    0.12 visits/week
    Threads
    140
    Classifieds
    Quote Originally Posted by cpowell View Post
    Chuck
    I do tend to think that the amount of bow on the 24" is a little too much. My clamps were bending to close the gap and I know the edge joints were good so without the cauls I would have needed minimal pressure to bring the joint up. Heaven only knows how much force was being applied in the middle!
    The only problem with the "explosion" was that all the time I was fiddling the glue was drying out
  10. #25
    Returning Member tonyps's Avatar
    Nickname
    Tony
    Join Date
    Dec 2006
    Location
    Durham, NC
    Posts
    211
    Visit Freq
    0.04 visits/week
    Threads
    Classifieds
    Evening,
    I saw this product a while back and have been waiting for someone to put a pair of em through the wringer.....it seems like a pair of em would be well worth it if you glue up boards on a regualr basis. It seems like it would sure reduce the number of clamps needed for this type of operation...
    Do you know the cost and different lengths available?
    Thanks,
    Tony ...
    Tony Strother
    SFC, USA (Ret.), DAV
    "We can generally fix ignorant. Stupid, well now that is gonna take a wee bit longer."
  11. #26
    jeff...
    Guest
    So Dave - are they really all that?
  12. #27
    Staff Advisor
    DaveO's Avatar
    Nickname
    DaveO (48)
    Join Date
    Aug 2005
    Location
    Clayton, NC
    Posts
    15,304
    Visit Freq
    0.85 visits/week
    Threads
    556
    Classifieds
    Quote Originally Posted by tonyps View Post
    Thanks,
    Tony ...
    Tony and all. I merge this thread with the review that I did, where I list the costs and sizes, so someone looking for the information wouldn't have to look in several places.
    DavidF, thanks for putting your spin on the review, anyone else that would like to give them a try just let me know.
    Dave:-)
    --Dr. Seuss
  13. #28
    DQ
    Nickname
    Alan Schaffter
    Join Date
    Dec 2005
    Location
    Washington, NC
    Posts
    2,896
    Visit Freq
    2.54 visits/week
    Threads
    270
    Classifieds
    I got to thinking about my previous question about the Bow Clamp's ability to apply even pressure across the length of a glue up and testing with strain gauges- would be nice to know (since I am a skeptic about manufacturer's claims), but I doubt anyone puts even pressure across a glue up with clamps of any sort- you just tighten until it feels right.
    What is lacking with the Bow Clamp is the ability to put more or less pressure. If you need to put more pressure in one area (first you didn't do a good job jointing or had some post jointing warp- wouldn't be the first time:-D:-D) you can add a clamp on top of the Bow Clamp. Of course then you are changing the dynamics of it- so why do you need it at all. Second, I often release pressure on one or two clamps in a long edge glue up to make it easier to realign the faces. As DavidF found out you can't do that very easily with Bow clamps. Also, it would be hard to run cauls across the face of a glueup unless they are shorter than the width of ther glue up, since the Bow Clamps would be in the way. It might be better to use regular clamps on the edges and Bow Clamps across the face.
    I guess the bottom line for me, they are not a "be all end all" clamping tools, but just another (expensive) tool in the clamping arsenal. I still think they are too expensive for something made from wood (Besseys are too expensive also), and if I were regularly gluing a lot of panels, I would make a panel clamping rack.
  14. #29
    Nickname
    David (62)
    Join Date
    Oct 2005
    Location
    Lydlinch UK, NC
    Posts
    4,198
    Visit Freq
    0.12 visits/week
    Threads
    140
    Classifieds
    I tend to agree Alan, I would have had to apply a huge amount of force at the ends of the bow clamps to match that which was being applied in the middle. When I have made curved cauls in the past, I have had a tenth of the bow on these clamps. If you were to clamp a flat caul and measure the gap, if any in the centre then multiplied by 10 to actually apply pressure I am sure you would not be talking more than 0.1" of bow needed.
    I did indeed have to use face cauls that were shorter than the panel width, and then long cauls on the top to apply the pressure. Certainly only juggling two clamps was nice, but as you say, they are not a "magic bullet" to the panel clamp game. Another member has offered me the use of the WC clamp system which I look forward to trying on the drawer sides and fronts. I will let you know how it goes.
  15. #30
    Returning Member Craig Feuerzeig's Avatar
    Nickname
    Craig Feuerzeig
    Join Date
    Feb 2007
    Location
    Montclair, NJ
    Posts
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Thanks for two great reviews guys. Glad to see my Bowclamps put through their paces. This product will either stand on its own 2 feet... or not. And let the chips fall where they may.
    But a few thoughts.
    With the benefit of CNC, I can change or adjust the pressure rather simply. And David, I think you might be right about too much pressure on the 2 footers...You see, I never intended on the 2 footers being used in pairs, in a panel glue up, for the reason you stated... it only takes 3 or 4 clamps normally across that length. But this is exactly the kind of feedback I'm looking for.
    I certainly know the "explosion" you speak of . But it does take a little practice getting used to a new method. And a dry run or 2 always helps. I like to get started by applying just enough pressure in the middle to allow for adjustment and alignment. With a little practice you'll find that a half a turn one way or the other will let you "dial in" the right amount. Then just clamp until the ends are tight.
    Nothing can be right for every situation, but I'm trying to work with averages for most common everyday clamping dilemmas. Also I do custom orders, and am toying with the idea of introducing light duty and heavy duty versions. Again looking for your feedback.
    Also there is no "be all end all". But the Bowclamp is not just for panel glue ups. It will also apply solid wood edgebanding, attach face frames, counter-top edges, act as a deep jaw clamp going places other clamps won't, work as a veneer press, a hold-down... and as DaveO and Jeff are finding out, new uses come up everyday.
    And wait until I show you the no clamps at all trick.
Similar Threads
  1. Bowclamp clamping cauls reviewed
    By DaveO in forum Reviews
    Last Post: 02-05-2007, 11:35 PM
  2. Need help clamping odd shape
    By rhett in forum General Woodworking
    Last Post: 01-21-2007, 09:10 PM
  3. Bow clamp
    By cskipper in forum Reviews
    Last Post: 11-12-2006, 01:34 PM
  4. Calls or Cauls (?) (Re. Bow Clamp)
    By John Reeves in forum General Woodworking
    Last Post: 09-28-2006, 01:00 PM
  5. Clamp down
    By sapwood in forum General Woodworking
    Last Post: 08-02-2006, 10:19 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
