West Penn Hardwoods (Ad 1)
Results 1 to 9 of 9
Thread: Waterlox loss
  1. #1
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,811
    Visit Freq
    6.88 visits/week
    Threads
    661
    Classifieds
    Waterlox loss
    Had 3-4 year old Waterlox Original Sealer/Finish (about 1/2 quart) turn to a gel despite using Bloxygen religiously. I thought that I had resealed the original container well enough after the Bloxygen but apparently not.
    Waterlox and Bloxygen are both excellent products that I've used for several years without problems but my bad this time!
  2. #2
    DQ
    frankc4113's Avatar
    Nickname
    Frank (77)
    Join Date
    Jan 2011
    Location
    Pinehurst, NC
    Posts
    259
    Visit Freq
    7.04 visits/week
    Threads
    Classifieds
    Re: Waterlox loss
    Sorry you lost that Waterlox. It's not cheap.
    After losing some paints and varnishes, now if I don't know how soon I'm going to use whatever finishes, etc., I put them in a plastic vacuum seal bag, remove the air with the vacuum sealer and also store the vacuum sealed containers upside down. It's a good idea to store all the shop liquids upside down whether in cans or bottles.
    With bottles of CA glue, I place them in a vacuum sealed bag and store in the freezer. It does keep quite a long time. Also, if you don't have a heated shop (I don't), when cold weather begins, bring glues, varnishes, etc. in the house when not using.them
  3. The following 2 users say Thank You to frankc4113 :
  4. #3
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,952
    Visit Freq
    6.85 visits/week
    Threads
    532
    Classifieds
    Re: Waterlox loss
    That is why I prefer the Tried & True brand of Varnish Oil. It does not go to gel after opening the can. I've put it in a plastic container to use and that is still good a year later. It's expensive but well worth the price if for no other reason than it doesn't go bad over time.
    I don't believe in Astrology. I'm a Sagittarius and we're skeptical.
    "May the grain be with you" - Roy Underhill
  5. #4
    Co-Director of Outreach Corporate Member
    DQ
    Barry W's Avatar
    Nickname
    Barry
    Join Date
    Oct 2014
    Location
    Lawsonville, NC
    Posts
    883
    Visit Freq
    5.15 visits/week
    Threads
    80
    Classifieds
    Re: Waterlox loss
    I used Waterlox for the first time this week (over gel stain) and was very pleased with the results after only one coat. Jeff, thanks for the tip to be extra careful in storing the remaining Waterlox. I have also used Tried and True and was pleased withe results. Ken, thanks for sharing your knowledge regarding Tried and True's long shelf life.
    "Nihil est melius quam vita diligentissima" (Nothing is better than a most diligent life.)
    -James Murray
  6. #5
    User cyclopentadiene's Avatar
    Nickname
    Join Date
    May 2006
    Location
    Greensboro, NC
    Posts
    707
    Visit Freq
    3.92 visits/week
    Threads
    126
    Classifieds
    Re: Waterlox loss
    I have had the same problem. They seem to have changed the formulation about 4-5 years ago. I noticed that the smell had changed and looked at a Headspace GC/MS scan at work. The solvents present and quantities changed considerably. This was about the time California EPA came out with their new and “improved” carcinogen list. I assume Waterlox made the changes th their product nationwide in order to comply. The shelf stability has not been the same since. I just purchase smaller containers now and try to consume in in a few months. It used to be my go to finish but i have recently been spraying water based lacquer with moderate success. It takes more tine to learn and my first few pieces had orange peel but I am improving
    FYI. My shop is not heated or cooled and waterlox has poor temperature stability as well. I store it inside the house.
  7. #6
    Nickname
    Join Date
    Jul 2017
    Location
    Apex, NC
    Posts
    78
    Visit Freq
    6.08 visits/week
    Threads
    Classifieds
    Re: Waterlox loss
    Same thing happened to me with the last quarter of a quart. Dan (danmart77) told me to fill the can with marbles after each use and that has worked out well so far.
  8. The following user says Thank You to Melinapex for this useful post:
  9. #7
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,811
    Visit Freq
    6.88 visits/week
    Threads
    661
    Classifieds
    Re: Waterlox loss
    How did you observe this? I've kept mine in the unconditioned garage for years without a problem.
    Note: Waterlox contains cobalt naphthenate which catalyzes the formation of oxygen free radicals leading to the polymerization (gelling) of the tung oil. Bloxygen is argon gas which is heavier than air and protects the tung oil from oxygen and polymerization. Bloxygen works very well at that.
    Don't put unused Waterlox back in the original container!
    Where? The smallest that I've found is quarts for about $27.
  10. #8
    Nickname
    Chilihead
    Join Date
    Feb 2013
    Location
    Asheville, NC
    Posts
    137
    Visit Freq
    2.31 visits/week
    Threads
    Classifieds
    Re: Waterlox loss
    I really like using Waterlox. I've found though that it is more prone to gel in the can than anything else I've used. I've had some success with Bloxygen yet that is unpredictable. I'v switched to Stop Loss Bags - https://www.stoplossbags.com or you can get them from Lee Valley too. I've found these to be excellent, and they keep the Waterlox fresh longer than Bloxygen ever did for me.
  11. #9
    Nickname
    Join Date
    May 2006
    Location
    Greensboro, NC
    Posts
    707
    Visit Freq
    3.92 visits/week
    Threads
    126
    Classifieds
    Re: Waterlox loss
    I purchase the quarts. These are typically enough for two projects. I purchased a gallon many years ago and learned it was a mistake
    The temperature instability claim is a new can that was in my shop last winter during the really cold stretch. It was gel when opened. This could have been a poorly sealed can but i assumed it was the prolonged cold.
    I typically take opened cans to work and bubble nitrogen through them and use a parafilm (relatively inert sealing material) under the metal cap to seal the can. I have not found a good way to remove the lid and typically disfigure it so an improved seal helps.
Similar Threads
  1. Weight loss update
    By toolferone in forum User Announcements
    Last Post: 10-07-2011, 08:54 PM
  2. Acceptable PSI Loss?
    By buildintechie in forum Workshop Discussion
    Last Post: 09-20-2011, 02:18 AM
  3. Weight Loss Update
    Last Post: 06-05-2011, 08:41 PM
  4. New tool for weight loss
    Last Post: 02-25-2011, 07:42 PM
  5. Loss of signal
    By Gofor in forum Help Desk
    Last Post: 02-18-2011, 09:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
