Klingspor's Woodworking Shop (Festool) Ad #2
Results 1 to 9 of 9
  1. #1
    DQ
    Nickname
    Join Date
    Mar 2015
    Location
    Anderson, SC
    Posts
    197
    Visit Freq
    4.12 visits/week
    Threads
    19
    Classifieds
    Work Shop Noise Measurements
    Now that the house is finally finished, I have started to put together my basement shop. This is a first for me as all prior work was done outside or in a garage that shared space with everything else we owned. Part of my effort is to reduce noise in the shop space for myself because I spent a summer in while in college counting the blows underneath a pile driver (which about like being beside a cannon when it goes off). My hearing took a beating out of that summer. Even though I always wear hearing protection (if I am going to spend much time cutting using both ear plugs and muffs), reducing noise is a big deal. Here are measurements from my equipment and results of some attempts to reduce noise levels. All measurements were made at my ear level when I am operating a piece of equipment with the exception of the dust collector where I measured at the table saw location.
    Table Saw ( Hammer K-3) Concrete floor- sheetrock and block walls
    On wheels & standard front feet - 88 dba
    Vibration dampers under wheels and feet - 84.7 dba
    10 inch blade 84.7 dba
    12 inch Silent Power blade 84.7 dba
    added a horse stall mat under the saw 84.7 dba I was surprised at this making no difference
    lining the saw cabinet with noise dampening material (like used in cars) NO DIFFERENCE
    I made no attempt to surround the saw exterior with a noise blanket because there are just too many places for noise to leak out that really do require access.
    Jointer Planer (Hammer 16 inch) 71.8 dba running no wood, 78 with dust collection & jointing in progress
    Band saw
    Running 83 dba, cutting 85 dba
    Installed stall mat under the saw 81 dba
    Installed noise dampening material on saw door 80 dba
    Dust Collector - Onedia V system 3 hp - 74 dba (nothing else running)
    Miter Saw
    Away from the wall 90 dba
    Next to the wall 92 dba
    Obviously I need to look at materials on the wall s that absorb sound, but that don't collect dust!
    Hope this helps someone else.
  2. The following user says Thank You to Mark Johnson for this useful post:
  3. #2
    DQ
    Raymond's Avatar
    Nickname
    Raymond (65)
    Join Date
    Jul 2012
    Location
    Charlotte, NC
    Posts
    2,109
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    Re: Work Shop Noise Measurements
    Mark, what about the ceiling above your head? What is insulating noise from your basement and the house above? That is something that will make a difference to your wife.
    I like making things. I have a wood shop at home. I am a terrible carpenter but I love doing it. Raymond - Charlotte, NC
  4. #3
    DQ
    Nickname
    Join Date
    Mar 2015
    Location
    Anderson, SC
    Posts
    197
    Visit Freq
    4.12 visits/week
    Threads
    19
    Classifieds
    The sheet rock is hung on a spring channel and there is fiberglass insulation (R 13 I think). That noise is actually not a problem, not is noise to neighbors as most of the shop is underground with the only exterior opening outside at the back of the house toward the woods.
  5. #4
    Recovering tool addict Corporate Member
    DQ
    Bas's Avatar
    Nickname
    Bas (45)
    Join Date
    Aug 2007
    Location
    Raleigh, NC
    Posts
    7,010
    Visit Freq
    6.23 visits/week
    Threads
    357
    Classifieds
    Thanks Mark - good info. One thing to consider is putting the dust collector in a separate closet, to reduce the cumulative effect of the DC and the tool. Also, sound absorption is highly dependent on the frequency. For example, the low rumbling of a DC requires mass, such as a double layer of sheetrock, which doesn't attract too much dust fortunately.
    Finding material to address high pitched sounds without attracting dust, that'll be an interesting challenge.
    Bas.
    "I don't need it. I just want it."
    How to add a picture to your post
  6. The following user says Thank You to Bas for this useful post:
  7. #5
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,818
    Visit Freq
    6.88 visits/week
    Threads
    661
    Classifieds
    Those are typical decibel noise levels for many things in everyday life besides the wood shop. Your hearing protection helps but I wouldn't go overboard with the other noise reduction measures.
    https://www.healthlinkbc.ca/health-topics/tf4173
  8. The following user says Thank You to Jeff for this useful post:
  9. #6
    DQ
    Willemjm's Avatar
    Nickname
    Willem
    Join Date
    Dec 2011
    Location
    Pinehurst, NC
    Posts
    972
    Visit Freq
    6.08 visits/week
    Threads
    130
    Classifieds
    I always wear Bluetooth hearing protection. I got a 3M set at Lowes, it filters the sound out pretty good, allows incoming calls and I can listen to anything through my Iphone.
  10. The following user says Thank You to Willemjm for this useful post:
  11. #7
    DQ
    Gofor's Avatar
    Nickname
    Join Date
    Mar 2006
    Location
    Goldsboro, NC
    Posts
    3,276
    Visit Freq
    6.65 visits/week
    Threads
    83
    Classifieds
    Egg flats may work to diffuse the noise, eliminating a lot of reflection. A quick search showed them to be available for about $.20 each for a 30 egg flat if bought in quantity ($7 for 35 flats)
    Practicing at practical woodworking
  12. The following 2 users say Thank You to Gofor :
  13. #8
    DQ
    Nickname
    Join Date
    Mar 2015
    Location
    Anderson, SC
    Posts
    197
    Visit Freq
    4.12 visits/week
    Threads
    19
    Classifieds
    High pitched sounds are tough because the sound wave is so short that any opening allows it to escape. This makes point of origin elimination dependent on full enclosure which is not practical for any woodworking tool I know of except a CNC. Best adsorption materials are open cell foams with as many variations in surface as possible (like pyramids); however these are major dust collectors and present a fire hazard unless you use a melamine foam. At this point, that is too expensive for me to try as a single sheet can be $300.
  14. #9
    DQ
    Phil S's Avatar
    Nickname
    Phil Soper (68)
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    4,647
    Visit Freq
    7.42 visits/week
    Threads
    544
    Classifieds
    I use the Bose noise canceling wireless headphones - they are incredible
  15. The following user says Thank You to Phil S for this useful post:
Similar Threads
  1. Basement shop noise
    By Tom from Clayton in forum General Woodworking
    Last Post: 05-08-2017, 07:03 PM
  2. A funny noise in the shop?
    By danmart77 in forum General Woodworking
    Last Post: 08-27-2016, 11:36 AM
  3. how wood measurements work....
    By mbeach in forum Wood
    Last Post: 01-22-2009, 08:44 PM
  4. So, I heard a strange noise in the shop tonight...
    By Monty in forum Power Tools and Their Use
    Last Post: 12-15-2006, 12:11 PM
  5. Router noise?
    By froglips in forum Power Tools and Their Use
    Last Post: 11-08-2006, 01:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
