West Penn Hardwoods (Ad 1)
View Poll Results: Who uses a bowl scraper?
Voters
14. You may not vote on this poll
  • Yes
    12 85.71%
  • No
    2 14.29%
Results 1 to 11 of 11
  1. #1
    Newbie
    Nickname
    Blackhawk
    Join Date
    Jan 2019
    Location
    Fairlawn, VA
    Posts
    Visit Freq
    3.00 visits/week
    Threads
    Classifieds
    Poll: Who uses a bowl scraper?
    I'm fairly new to bowl turning and I was just wondering how many people utilize bowl scrapers. My biggest problem right now is cleaning up the ridges from my bowl gouge. Just wondering if a scraper is worth the $100+ price tag to get a super smooth finish.
  2. #2
    DQ
    gritz's Avatar
    Nickname
    Robert
    Join Date
    Jan 2009
    Location
    Jasper, GA
    Posts
    504
    Visit Freq
    5.12 visits/week
    Threads
    Classifieds
    Re: Poll: Who uses a bowl scraper?
    "Super smooth finish" may be a reach too far. Normal flat scrapers can be pretty aggressive, especially since they are generally used near the end of the turning process and the piece may have gone out of round. They can also leave you with nasty tearout on softer woods. A catch can make a nearly complete bowl into firewood pretty quickly.
    I would suggest two things...(1) work on your gouge sharpening and positioning, plus be sure you have a continuous pass from beginning to end...(2) go on E-bay and look for negative rake scrapers.
    There are some Hurricane, etc. brand flat scrapers on Amazon and E-bay for less than $60. They can be ground as negative rake scrapers. As long as it is HSS steel, they will work OK. Easy wood tools is now marketing a negative rake carbide replacement tip for their tools in case you have one of theirs.
    Tomcat90501 in Ca. grinds really nice looking negative rake scrapers from used flat scrapers and apparently prices them based on brand, width and thickness, plus a fee for grinding. You can get a 1" wide Craftsman for bowls up to 8" or so for less than $40 delivered. The thicker, wider ones are about $100 delivered.
    While flat scrapers with a negative burr are possible to form and maintain, the rational behind negative rake scraping is that it uses a fairly large turned burr on the edge (like a cabinet scraper,) plus it is negatively pitched, making it less aggressive. The burr is consumed pretty quickly, so be prepared to re-form the burr edge frequently with a tool steel rod, and re-grind after it after it no longer forms a nice burr.
    I copied the following from his page. I assume he won't mind since this information is on each page of his scraper sales, and he states that he and his Dad learned this from someone else. There is some good information here...
    Negative rake scrapers will cut the wood much cleaner than standard flat top scrapers, but will dull much faster. They are not a replacement for good tool technique. They are not a bulk wood removal tool. They’re a finesse tool used to clean up/touch up the interior or exterior of bowls or other turned projects by removing small micro lines, torn grain or making the final finishing or shaping cuts.. The scraper will cleanly cut very small amounts of wood leaving the surface ready for 150 to 220 grit sanding. They also work very well on plastics and acrylics cutting cleanly with a lot less chip-out. The scrapers also work very well on segmented turnings and stabilized materials. It takes me more than one hour to properly regrind / re-profile a scraper of this size and thickness.
    Lastly, these negative rake scrapers don’t tend to get catches, very user friendly chisels. I personally have half a dozen of these types of chisels in different profiles in my own tool collection. Negative rake scraping is a technique dad and I learned from Stuart Batty. I’m told that it’s a very old technique that was used in the production of Ivory billiard balls in England.
    A note on sharpening:
    I recommend you sharpen the small micro bevel. Small bevels sharpen faster and that is the point of this suggestion. The micro bevel also allows the bottom of the scraper to have a wider foot print for stability on the tool rest. The location of the cutting edge in the body of the tool steel doesn’t affect its performance. Use a good quality Aluminum Oxide wheel H, I, J hardness on the grinder and keep it dressed and clean. A dirty wheel won't raise a good burr. the softer wheels like the Norton ceramic jell wheels are what I ground this scraper on.
  3. #3
    Newbie
    Nickname
    Blackhawk
    Join Date
    Jan 2019
    Location
    Fairlawn, VA
    Posts
    Visit Freq
    3.00 visits/week
    Threads
    Classifieds
    Thanks for the detailed info, I have a lot yet to learn. How do I get to Tomcat90501's page?
  4. #4
    DQ
    gritz's Avatar
    Nickname
    Robert
    Join Date
    Jan 2009
    Location
    Jasper, GA
    Posts
    504
    Visit Freq
    5.12 visits/week
    Threads
    Classifieds
    just search for negative rake scrapers...
  5. #5
    DQ
    beloitdavisja's Avatar
    Nickname
    James Davis
    Join Date
    May 2016
    Location
    Charlotte, NC
    Posts
    233
    Visit Freq
    7.27 visits/week
    Threads
    33
    Classifieds
    I have a bowl scraper and I use it occasionally. It's a smaller scraper (3/4" curved, link) and I have the Robert Sorby Sovereign handle system that it goes into.
    Having just bought a CBN setup, I can tell you that I now get a MUCH better finish before the bowl scraper with sharp tools.
    That said, a large bowl scraper is on my future tool list as I can't go too deep with my current one.
    "Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life."
    https://www.facebook.com/knottyscot
  6. #6
    Board of Directors
    Vice President
    DQ
    Michael Mathews's Avatar
    Nickname
    Michael (56)
    Join Date
    Mar 2012
    Location
    Chapel Hill, NC
    Posts
    1,573
    Visit Freq
    4.65 visits/week
    Threads
    151
    Classifieds
    Blackhawk, where are you getting the ridges? are they in the sides of the bowl or more towards the bottom of the bowl?
    Are you rubbing the bevel of the bowl gouge? If you're rubbing the bevel, you really shouldn't be getting ridges. Watch some more YT videos about how to use the bowl gouge. Here's one by Mike Waldt that's pretty good:
    https://youtu.be/nlSd7ZXAVoM
    Michael
  7. #7
    Newbie
    Nickname
    Blackhawk
    Join Date
    Jan 2019
    Location
    Fairlawn, VA
    Posts
    Visit Freq
    3.00 visits/week
    Threads
    Classifieds
    Michael - I get more ridges in the side of the bowl (on the inside). I am rubbing the bevel, but I think I just still need more practice to get good tool control. I think my ridges come from breaking out of the cut. I need to get better at holding the cut all the way to the bottom.
    Brad
  8. #8
    Returning Member
    Nickname
    Join Date
    Jun 2014
    Location
    Harrisburg, NC
    Posts
    56
    Visit Freq
    0.23 visits/week
    Threads
    Classifieds
    These got good reviews form quite a few turners (one is an instructor at J C Campbell).
    At 1.5 wide and 3/8 thick it should do the job well. $37
    https://www.pennstateind.com/store/LX130.html
    Brian Havens has a very good video on the negative rake scraper
  9. The following user says Thank You to Mike Mills for this useful post:
  10. #9
    Newbie
    Nickname
    Blackhawk
    Join Date
    Jan 2019
    Location
    Fairlawn, VA
    Posts
    Visit Freq
    3.00 visits/week
    Threads
    Classifieds
    Mike - Thanks for the link. I ended up watching several of Brian's videos.
  11. #10
    DQ
    gritz's Avatar
    Nickname
    Robert
    Join Date
    Jan 2009
    Location
    Jasper, GA
    Posts
    504
    Visit Freq
    5.12 visits/week
    Threads
    Classifieds
    Also...think about learning shear scraping to get a better final finish.
    And finally...if you have a skew that is wider than 1/2", that grind is basically a negative rake scraper...practice with that to learn the technique.
  12. #11
    DQ
    smallboat's Avatar
    Nickname
    smallboat
    Join Date
    Jan 2011
    Location
    Clemmons, NC
    Posts
    1,500
    Visit Freq
    6.69 visits/week
    Threads
    Classifieds
    I find that if I don't let oatmeal or eggs dry in the bowl there's no need to scrape.
    The dog is a big help with that.
    (sorry, I've resisted this as long as I could)
Similar Threads
  1. Poll: How many use this DT jig
    By Joe Scharle in forum General Woodworking
    Last Post: 07-08-2013, 01:22 PM
  2. Scraper Burnisher
    By rick7938 in forum Hand Tools and their Use
    Last Post: 06-30-2009, 04:44 PM
  3. Must be a trick to using a bowl scraper
    By Rob in forum Woodturning
    Last Post: 05-26-2008, 12:28 PM
  4. Poll - What do you do when you build something?
    By clowman in forum General Woodworking
    Last Post: 11-30-2006, 10:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
