Klingspor's Woodworking Shop (Locations) Ad #1
Results 1 to 7 of 7
  1. #1
    Nickname
    Jacob
    Join Date
    May 2017
    Location
    Salisbury, NC
    Posts
    Visit Freq
    6.50 visits/week
    Threads
    Classifieds
    Will freezing ruin Arm R Seal?
    I've had some arm r seal in the shop for a while, which is just an outbuilding, so I'm certain it has frozen before. It says on the can to not allow it to freeze. I'm planning on using it on a project here soon.
    Will freezing temperatures ruin Arm R Seal?
    Will freezing temperatures compromise the strength of Titebond I, II, or III?
    Thanks
  2. #2
    Co-director of Outreach Corporate Member
    DQ
    golfdad's Avatar
    Nickname
    Dirk (63)
    Join Date
    Oct 2005
    Location
    Clayton, NC
    Posts
    2,902
    Visit Freq
    6.65 visits/week
    Threads
    141
    Classifieds
    Re: Will freezing ruin Arm R Seal?
    If it has frozen I would toss it. Maybe find a niche in the house you can store finish's through the cold months or rig up an old cooler with a light bulb in it forthose cold nights. The same with all glues you have
  3. The following 2 users say Thank You to golfdad :
  4. #3
    Nickname
    Jacob
    Join Date
    May 2017
    Location
    Salisbury, NC
    Posts
    Visit Freq
    6.50 visits/week
    Threads
    Classifieds
    Thank you, that is very unfortunate as neither of them have been opened.
  5. #4
    DQ
    Nickname
    Charley (76)
    Join Date
    May 2008
    Location
    Kannapolis, NC
    Posts
    1,032
    Visit Freq
    5.08 visits/week
    Threads
    Classifieds
    Your rechargeable batteries need to be kept from freezing too. My shop is heated and set to about 40 when I'm not in there during the cold months to keep my finishes, glue, batteries, and water lines from freezing.
    Since it's above freezing during the day here and only goes below freezing for a few hours during the night, just keeping these items in a sealed insulated container like an old unused refrigerator or ice chest should delay the below freezing temperatures inside to avoid problems. With good insulation, the average temperature inside should stay well above freezing since the inside temperature would be more of an average of the low and high temperatures outside the insulated container. You would then only need to do something else if the temperatures will be below freezing for longer periods. I can't remember days here where it stayed below freezing for a whole day and night. In more Northern climates the rules would be different.
    Charley
  6. The following 3 users say Thank You to Charles Lent :
  7. #5
    DQ
    Nickname
    Daniel
    Join Date
    Apr 2015
    Location
    Clayton, NC
    Posts
    823
    Visit Freq
    6.04 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Charles Lent View Post
    Charley
    Last year January 2018 we went close to 7 days below freezing day and night in the Raleigh area, I lost some yard chemicals and cleaning supplies I forgot about in my shed from freezing.
    https://www.wral.com/raleigh-breaks-...emps/17238393/
  8. The following user says Thank You to tri4sale for this useful post:
  9. #6
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,832
    Visit Freq
    6.88 visits/week
    Threads
    661
    Classifieds
    I'd try the Arm-R-Seal on some scrap wood applied as the manufacturer recommends and see what happens. Stir it well.
    I'm a chemist; it's oil based and oil doesn't freeze so I don't understand the "keep from freezing" warning.
  10. The following 2 users say Thank You to Jeff :
  11. #7
    DQ
    Gofor's Avatar
    Nickname
    Join Date
    Mar 2006
    Location
    Goldsboro, NC
    Posts
    3,277
    Visit Freq
    6.65 visits/week
    Threads
    83
    Classifieds
    I spent a lot of years working in aircraft corrosion control. In many (most) locations, the paints and chemicals were stored in outside metal sheds or cabinets without climate control, and were subjected to freezing as well as +100 degree temps. We also had to keep check on shelf life. As with any government operation, there were set procedures for evaluating paints/chemicals that were either past shelf-life or subjected to temp extremes.
    For paints, the procedure was:
    1. Open container and thoroughly stir the contents. If it blended well (in the case of pigmented paints that would normally separate in storage) and was free of lumps, it passed test one. If not it was disposed of.
    2. Apply the coating to a clean dry surface. If it separated, or would not go evenly, it failed.
    3. Let cure. If it dried within the normal drying time, and had the gloss/flatness and hiding characteristic is was supposed to, it passed, and we could use it. If it didn't cure, or was sticky or soft, it was disposed of.
    For shelf life purposes, we were allowed to extend the shelf life 50% of the original for two times maximum.
    We used this method on lacquers, enamels, polyurethanes and epoxy coatings. I have subsequently used it also for varnishes and enamels that have skinned over, being careful not to get the skin pieces in the paint, or straining it afterwards, all with good results. (This includes Behlens Rock Hard Table Top finish, which is notorious for skinning over within hours of opening the can).
    We didn't use latex paint in my work there, but I have used a lot of it since. With latex, if it mixes up well, I use it, and have used some up to ten years old. I have touched up repairs on both the interior and exterior of my house over five years after the original painting, using paint out of the original containers, with excellent color and gloss match.
    The one coating that in my experience does survive extended storage much past the shelf life is shellac in solution.
    Key is to try some on a test piece. If it covers well, flows out, and dries like it's supposed to, it will be fine.
    jmtcw
    PS. As previously stated, an old refrigerator or freezer makes an excellent storage container for coatings in this climate, to help mitigate the temperature swings.
    Practicing at practical woodworking
  12. The following 3 users say Thank You to Gofor :
Similar Threads
  1. Removing Anchor Seal ...or Whatever
    By CommGuy107 in forum Woodturning
    Last Post: 05-04-2015, 11:59 AM
  2. Varnish to seal MDF?
    By kooshball in forum Finishing
    Last Post: 03-10-2013, 08:53 PM
  3. Firefox trick, fixes freezing.....
    By froglips in forum "How To" Forum
    Last Post: 08-25-2009, 02:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
