Klingspor's Woodworking Shop (Locations) Ad #1
Results 1 to 9 of 9
  1. #1
    Nickname
    Join Date
    Jul 2016
    Location
    Four Oaks, NC
    Posts
    460
    Visit Freq
    5.38 visits/week
    Threads
    107
    Classifieds
    What are the chances this falls apart
    What are the chances this falls apart? Started this last weekend. I know this isn't the best joinery work, but, well, I just did it anyway.
    Joints glued up and used brads to hold together till dry, then drilled 3/8" holes and added 2 dowels per joint.
    Just curious what your thoughts are on how this will hold up as a base for a 1 seat bench.
    Original plan was to use this piece of Walnut as the seat, but the base seemed oversized for the seat.
    So I made a new one with my white oak stock and some thin strips of walnut glued up on the edges.
  2. #2
    DQ
    Nickname
    Jim (71)
    Join Date
    Feb 2013
    Location
    Durham, NC
    Posts
    1,562
    Visit Freq
    7.00 visits/week
    Threads
    86
    Classifieds
    Re: What are the chances this falls apart
    How are you going to prevent the legs from racking? That's really the only thing I see.
  3. The following 2 users say Thank You to nn4jw :
  4. #3
    Nickname
    Bob Vaughan
    Join Date
    Sep 2009
    Location
    Roanoke, VA
    Posts
    Visit Freq
    5.27 visits/week
    Threads
    Classifieds
    I've done a few things that way and they held up quite well. Your project should hold up as well as long as it doesn't get wet or left outside.
  5. The following 2 users say Thank You to bob vaughan :
  6. #4
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,691
    Visit Freq
    6.88 visits/week
    Threads
    653
    Classifieds
    It should be fine, David. Curious. What are the dimensions (l x w) of the bench and what will it be used for?
  7. #5
    DQ
    Bill Clemmons's Avatar
    Nickname
    Bill (70)
    Join Date
    Mar 2010
    Location
    Liberty, NC
    Posts
    6,214
    Visit Freq
    6.88 visits/week
    Threads
    265
    Classifieds
    The butt joints w/ dowels will be fairly strong. My only concern is the same as Jim's: racking. Depending on how much actual use this piece gets, that may or may not be an issue. The only option at this point would be to add some type of corner bracing, and that would distract from the otherwise clean lines.
    One option if you were doing it again is some type of inter-locking joints (e.g. dovetails, finger joints, etc.). That might give a little more side-to-side stability.
    I'll gladly tell you how I do something. Just please don't confuse that with the right way to do it, and almost certainly not the only way.
  8. The following user says Thank You to Bill Clemmons for this useful post:
  9. #6
    Nickname
    Join Date
    Jul 2016
    Location
    Four Oaks, NC
    Posts
    460
    Visit Freq
    5.38 visits/week
    Threads
    107
    Classifieds
    Quote Originally Posted by nn4jw View Post
    Assume you are talking about left to right movement? Hadn't really thought about that as an issue, but now see the potential. The 'legs' are about 3.5" wide. Thickness is 7/8" or there about. Bench top is about 1.25" thick.
    On securement to prevent the racking, I'm open to suggestions. Was planning to use 3-4 heavy gauge screws that are offset to provide more strength.
  10. #7
    Nickname
    Join Date
    Jul 2016
    Location
    Four Oaks, NC
    Posts
    460
    Visit Freq
    5.38 visits/week
    Threads
    107
    Classifieds
    Quote Originally Posted by Jeff View Post
    The top is about 16-17" deep and 30"-36" long. Honestly, I just grabbed two pieces and glued them up. Didn't even measure.
    Was planning to take it to work and put it in my office space. It is fairly narrow (about 8'). I have a side chair, and it takes a lot of room, so thought this could sit closer to the wall and provide a little more space to walk around. It's not going to get a lot of use, but will be used daily.
  11. #8
    DQ
    Gofor's Avatar
    Nickname
    Join Date
    Mar 2006
    Location
    Goldsboro, NC
    Posts
    3,253
    Visit Freq
    6.65 visits/week
    Threads
    83
    Classifieds
    You could always use these to strengthen the joint. https://www.lowes.com/pd/National-Ha...ack/1000357661
    Practicing at practical woodworking
  12. The following user says Thank You to Gofor for this useful post:
  13. #9
    Nickname
    Join Date
    Jul 2016
    Location
    Four Oaks, NC
    Posts
    460
    Visit Freq
    5.38 visits/week
    Threads
    107
    Classifieds
    Quote Originally Posted by Gofor View Post
    Hmmm... I actually have some of those! Good idea. Will have to bend them a bit to fit the angle. Can't hurt anything.
Similar Threads
  1. Miller's Falls #2-01 rehab
    By Chris C in forum Hand Tools and their Use
    Last Post: 10-14-2018, 06:43 PM
  2. $5 ReStore Millers Falls No 10
    By beloitdavisja in forum Hand Tools and their Use
    Last Post: 07-03-2018, 09:49 AM
  3. A big day for Millers Falls eggbeaters...
    Last Post: 06-17-2018, 09:09 AM
  4. New guy from Granite Falls
    By dave421 in forum Who We Are
    Last Post: 08-29-2017, 08:54 PM
  5. Hello from Granite Falls
    By 708custom in forum Who We Are
    Last Post: 02-10-2015, 08:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
