West Penn Hardwoods (Ad 1)
Results 1 to 8 of 8
Thread: Which Oil
  1. #1
    Nickname
    Pete
    Join Date
    Oct 2012
    Location
    N Topsail Bch, NC
    Posts
    338
    Visit Freq
    5.62 visits/week
    Threads
    82
    Classifieds
    Which Oil
    My boiled Linseed is past using, and want to try another Oil, Mid priced, suggestions?
    Just for mostly smaller projects I dont make furniture, Thanks.
  2. #2
    DQ
    Nickname
    Roy
    Join Date
    Apr 2010
    Location
    Apex, NC
    Posts
    939
    Visit Freq
    6.58 visits/week
    Threads
    54
    Classifieds
    Re: Which Oil
    Formby's Tung Oil finish gives good results for me. Also builds up on the surface so you can get a nice shine. Waterlox works too but it's much more expensive. Formby's is a wiping varnish and your boiled linseed oil is a penetrating oil.
    Roy G
  3. The following 3 users say Thank You to Roy G :
  4. #3
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,686
    Visit Freq
    6.88 visits/week
    Threads
    653
    Classifieds
    Re: Which Oil
    Do you like the finish that you were getting with the BLO? If so, try pure tung oil instead. They're both penetrating oils and not a wiping varnish. A small sample is $3.50 if you want to try it first (also 1/2 pint and a pint are cheap).
    https://www.realmilkpaint.com/shop/o...ung-chinawood/
  5. The following 2 users say Thank You to Jeff :
  6. #4
    User CrealBilly's Avatar
    Nickname
    Join Date
    Feb 2009
    Location
    Creal Springs, IL
    Posts
    10,229
    Visit Freq
    0.42 visits/week
    Threads
    976
    Classifieds
    Re: Which Oil
    My son makes up mineral oil & beeswax finish, lots of recipes on Google about how to mix mineral oil into bees wax.
    His finishing schedule is:
    1) Flood wood with just mineral oil and allow to soak in for 24 hours. Then wipe off any access with a soft lint free rag.
    2) apply mineral beeswax mixture and buff with a lint free rag.
    The finish is supper easy and non-toxic. I'll slowly coming around to the finish but I still like 50/50 gloss oil based Polyurethane/Acetone, I don't like gas off period at all. So I've been using mineral oil beeswax finish more and more.
    #ArmOurTeachers
    #SchoolConsealedCarry
  7. The following user says Thank You to CrealBilly for this useful post:
  8. #5
    Administrator Corporate Member
    DQ
    ScottM's Avatar
    Nickname
    Join Date
    Jul 2007
    Location
    Littleton, NC
    Posts
    11,054
    Visit Freq
    6.65 visits/week
    Threads
    948
    Classifieds
    Re: Which Oil
    Pete like me I know you do a lot of scroll saw work. I use WATCO Danish Oil or a similar product made by Deft called DEFTOIL. They contain BLO, poly and other ingredients. Unlike plain BLO they dry fully. Normally one or two coats are all I need. If I want more gloss I spray a light cost of rattle can lacquer after they dry.
    Maker of fine saw dust
    "Ability is what you are capable of doing. Motivation determines what you do. Attitude determines how well you do it."
    - Lou Holtz-
  9. The following user says Thank You to ScottM for this useful post:
  10. #6
    Nickname
    Pete
    Join Date
    Oct 2012
    Location
    N Topsail Bch, NC
    Posts
    338
    Visit Freq
    5.62 visits/week
    Threads
    82
    Classifieds
    Re: Which Oil
    Scott just finished Last supper scroll will post in Scrolling
  11. #7
    DQ
    sawman101's Avatar
    Nickname
    Bruce Swanson
    Join Date
    Feb 2009
    Location
    Newton, NC
    Posts
    3,180
    Visit Freq
    6.62 visits/week
    Threads
    194
    Classifieds
    Re: Which Oil
    Pete, on scroll saw work I will sometimes use Old English Lemon Oil, purchased at the grocery store. I flood it on and let it dry overnight. A light wiping and then usually apply 3 light coats of semi-gloss lacquer. Other times I spray on a coat of rattle can Bulls Eye Shellac, then the lacquer. Most always lightly sand with 320 or 400 grit between 2nd and 3rd coats of lacquer. The shellac is a sealer coat that promotes an even finish. Happy sawdusting!
    Experience is a hard teacher; she gives the test first, and the lesson later.
  12. The following user says Thank You to sawman101 for this useful post:
  13. #8
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,920
    Visit Freq
    6.85 visits/week
    Threads
    530
    Classifieds
    Re: Which Oil
    My goto Oil finish is Varnish Oil by Tried & True brand. Not exactly cheap, but it wipes on and you wipe off excess - very forgiving finish - it it gets scuffed just sand and re-apply. I use it on small pieces like scrollings and large furniture. A pint will last you forever on small pieces. One advantage of it is that it doesn't harden in the can like a lot of oil finishes do once opened.
    I don't believe in Astrology. I'm a Sagittarius and we're skeptical.
    "May the grain be with you" - Roy Underhill
  14. The following 2 users say Thank You to KenOfCary :
Posting Permissions
  • You may not post replies
  • You may not edit your posts
