West Penn Hardwoods (Ad 2)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
  1. #1
    DQ
    Nickname
    Wiley
    Join Date
    Jun 2018
    Location
    Waynesville, NC
    Posts
    Visit Freq
    3.77 visits/week
    Threads
    Classifieds
    Two Problems With Performax 16-32 Plus Drum Sander
    I purchased an entire shop and was so pleased to acquire 3 pieces of machinery in particular: a 5 HP Powermatic table saw, a Laguna 16" band saw, and a Performax 16-32 drum sander. I used the Performax for the 1st time and had a serious problem with it that is not covered in the troubleshooting info in the owner's manual.
    When I run the conveyor feed belt it creeps down from left to right (towards the drive motor) when you are feeding your lumber. I didn't realize it until the feed belt began to get chewed up, so now I get to buy a new belt as part of my fix, so I need parts. This issue is not covered in the troubleshooting guide. I aligned the passive roller with a micrometer on both adjustment screws, but that didn't fix it. If you own a Performax 16-32 and know how to fix this, please reply.
    My 2nd problem is finding someone on line with customer service reps who can help me. Performax Products was bought out by Jet about 14 years ago. There is no direct link on the internet to Performax customer service. If you know where I need to go, please send the link or a phone #. Thanks.
    When you're hot, you're hot. When your tool's hot, stop.
    Wiley Cotton
    Wiley's Woodworks
    Waynesville, NC
  2. #2
    Board of Directors
    Development Director
    DQ
    Jeremy Scuteri's Avatar
    Nickname
    Jeremy (37)
    Join Date
    Dec 2010
    Location
    Oak Ridge, NC
    Posts
    3,804
    Visit Freq
    6.04 visits/week
    Threads
    314
    Classifieds
    Re: Two Problems With Performax 16-32 Plus Drum Sander
    Instead of using a micrometer to decide how to set the adjustment screws, try running the belt at a slow speed and watch how the belt tracks as you adjust.
  3. #3
    DQ
    Skymaster's Avatar
    Nickname
    Jack (78)
    Join Date
    Aug 2009
    Location
    Zebulon, NC
    Posts
    1,885
    Visit Freq
    6.35 visits/week
    Threads
    44
    Classifieds
    Call Jet. Also, i have a 22 44 face your machine, at the left end of your belt should be 2 captivated little wrenches, they are for the belt adjustment, the nuts are where the wrenches are, run the belt and adjust the tracking until it runs straight.
  4. #4
    Administrator Corporate Member
    DQ
    ScottM's Avatar
    Nickname
    Join Date
    Jul 2007
    Location
    Littleton, NC
    Posts
    11,052
    Visit Freq
    6.65 visits/week
    Threads
    948
    Classifieds
    I replaced my belt with this. Love it. Well worth it.
    https://www.amazon.com/Accura-Replac.../dp/B000HTM4WG
    Maker of fine saw dust
    "Ability is what you are capable of doing. Motivation determines what you do. Attitude determines how well you do it."
    - Lou Holtz-
  5. #5
    DQ
    pcooper's Avatar
    Nickname
    Phillip Cooper (57)
    Join Date
    Dec 2006
    Location
    Maiden, NC
    Posts
    664
    Visit Freq
    6.65 visits/week
    Threads
    Classifieds
    Quote Originally Posted by ScottM View Post
    What do you like about this replacement belt over the standard one? I've had no issues with mine tracking, but occasionally mine doesn't seem to grip the wood as I'd like, blowing off the dust usually fixes that problem. For my problem (slight as it is) I can't see the price that it costs...
    Today a pile of wood, tomorrow a pile of sawdust......
  6. #6
    DQ
    Willemjm's Avatar
    Nickname
    Willem
    Join Date
    Dec 2011
    Location
    Pinehurst, NC
    Posts
    959
    Visit Freq
    6.08 visits/week
    Threads
    129
    Classifieds
    Adjust while sanding. When mine was new I had to continually tweak tracking. It took a long time to settle in. The feed belts are not joined with perfect accuracy and theybstretch with use. Attempting to adjust with measurements won’t work.
  7. The following user says Thank You to Willemjm for this useful post:
  8. #7
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,681
    Visit Freq
    6.88 visits/week
    Threads
    653
    Classifieds
    Sounds a lot like tracking/wandering on a hand held belt sander. It looks good until you begin sanding and then it has to be adjusted while sanding.
  9. #8
    DQ
    ScottM's Avatar
    Nickname
    Join Date
    Jul 2007
    Location
    Littleton, NC
    Posts
    11,052
    Visit Freq
    6.65 visits/week
    Threads
    948
    Classifieds
    Quote Originally Posted by pcooper View Post
    It seems to hold and more consistant feed speed vs the old sand paper belts. It tracks better too. I set i once and never had to adjust it like the sand paper belt.
    - Lou Holtz-
  10. The following user says Thank You to ScottM for this useful post:
  11. #9
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,681
    Visit Freq
    6.88 visits/week
    Threads
    653
    Classifieds
    I'm new to drum sanders. If the Accura belt isn't a "sand paper" belt how does it sand like sand paper?
    http://theaccessoriespartssellers.bl...lt-for-16.html
  12. #10
    DQ
    pcooper's Avatar
    Nickname
    Phillip Cooper (57)
    Join Date
    Dec 2006
    Location
    Maiden, NC
    Posts
    664
    Visit Freq
    6.65 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Jeff View Post
    The purpose of the 'sandpaper' feed belt is to move the stock, not sand. The paper on the rotating drum does the sanding. The abrasive platen belt is supposed to dig into the stock just enough to move it along but not change the face that it touches. I'd never seen another kind of drive belt before, and wondered if it held stock better or tracked better, or???? I've had no issues with tracking, but holding stock has been a slight issue. I would like to see one of these belts and put it in my hands, I've found that other materials like those on the gripper tool are fine as long as they are very clean, but once some dust gets on them, they don't hold so well either.
  13. The following 2 users say Thank You to pcooper :
  14. #11
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,681
    Visit Freq
    6.88 visits/week
    Threads
    653
    Classifieds
    I think that I understand. The Accura belt goes on the drums and the sanding belt is added on top of that?
  15. #12
    DQ
    pcooper's Avatar
    Nickname
    Phillip Cooper (57)
    Join Date
    Dec 2006
    Location
    Maiden, NC
    Posts
    664
    Visit Freq
    6.65 visits/week
    Threads
    Classifieds
    The Accura belt is an item that is below the sanding drum. It is a very wide "belt" that runs with the power feed motor (variable speed). The sanding drum takes a 3" wide by very long strip that is wrapped around the drum, and is easily changed for grit changes as desired by the finish you want. The sanding drum isn't variable speed (at least on mine) but the lower feed table belt is.
  16. #13
    DQ
    ScottM's Avatar
    Nickname
    Join Date
    Jul 2007
    Location
    Littleton, NC
    Posts
    11,052
    Visit Freq
    6.65 visits/week
    Threads
    948
    Classifieds
    Think of it more like a conveyor belt that the wood rides on as it pass under the sanding rollers.
    - Lou Holtz-
  17. The following user says Thank You to ScottM for this useful post:
  18. #14
    Nickname
    Bradley
    Join Date
    Jan 2015
    Location
    Wake Forest, NC
    Posts
    111
    Visit Freq
    3.12 visits/week
    Threads
    19
    Classifieds
    i posted about this last year under the title of problems with drum sander.
    i got the advice to crown the middle of the passive roller. this is how many belts in a variety of applications maintain their tracking. i had crowned the motor side of the roller in an attempt to push it back. that didnt work. the crowning of the middle did. however i think i had stretched it so it still walked to the motor side, just much slower. it bunched by feed belt but seems to have found some equilibrium.
    try crowning the middle of the passive roller with some tape.
  19. #15
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,681
    Visit Freq
    6.88 visits/week
    Threads
    653
    Classifieds
    I'm unfamiliar with Drum Sanders. What is the passive roller and where is it located? TIA.
    Quote Originally Posted by BKHam View Post
Similar Threads
  1. Jet Performax Drum Sander $300 Ral CL -
    By Splint Eastwood in forum Found for Sale/Hot Deals
    Last Post: 06-13-2013, 04:26 PM
  2. Performax 22-44 Plus Drum Sander CLT CL
    By timf67 in forum Found for Sale/Hot Deals
    Last Post: 08-06-2009, 02:32 PM
  3. Performax 16-32 drum sander - $350 (Durham nc)
    Last Post: 07-15-2009, 09:51 PM
  4. Has anyone seen this yet? Performax Drum Sander
    By Jim M. in forum Found for Sale/Hot Deals
    Last Post: 04-25-2008, 09:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
