Klingspor's Woodworking Shop (Festool) Ad #2
Results 1 to 6 of 6
  1. #1
    User Pop Golden's Avatar
    Nickname
    Pop (78)
    Join Date
    Jul 2011
    Location
    Charlotte, NC
    Posts
    918
    Visit Freq
    4.31 visits/week
    Threads
    Classifieds
    motor rotation question
    Hi folks! Pop needs some help. I bought 3 motors from WT Tool. The price was right. The problem is they only rotate clockwise. I designed a jackshaft to reverse the rotation. This rig saps power. Here is the question: if I rotate these motors 1800 will the shaft rotate counter clockwise? Nothing will change but the orientation of the motor to the power tool. I found out that most power tools need a counter clockwise rotation.
    Pop
  2. #2
    Senior User LastChanceWoodshop's Avatar
    Nickname
    Jason
    Join Date
    Dec 2017
    Location
    Graham, NC
    Posts
    Visit Freq
    6.08 visits/week
    Threads
    Classifieds
    Re: motor rotation question
    Pop, usually you can swap supply wires on your motor to change the direction. Can you post a picture of the rating plate?
    There's never enough time to do it right, but there's always enough time to do it over.
  3. The following user says Thank You to LastChanceWoodshop for this useful post:
  4. #3
    Nickname
    Pop (78)
    Join Date
    Jul 2011
    Location
    Charlotte, NC
    Posts
    918
    Visit Freq
    4.31 visits/week
    Threads
    Classifieds
    ​No Jason, There is no way to reverse rotation by swapping supply wires. That's the reason I got these motors for $50 each. They were made for HVAC use.
    I designed a jack shaft system to provide a counter clockwise rotation. The jack shaft design is simple, motor pulley to jack shaft pulley, jack shaft pulley to machine. The system saps power from the 3/4 hp. motors. My idea is if I turn the motor 180 degrees I will have a counter clockwise rotation.
    Pop
  5. #4
    DQ
    Nickname
    Gene
    Join Date
    Oct 2016
    Location
    Winterville, NC
    Posts
    448
    Visit Freq
    6.31 visits/week
    Threads
    Classifieds
    draw a circle. put an arrow on it somewhere. turn the paper over. hold it up to a light. and you know.
  6. The following user says Thank You to Dee2 for this useful post:
  7. #5
    Nickname
    Join Date
    Nov 2005
    Location
    Apex, NC
    Posts
    6,094
    Visit Freq
    4.77 visits/week
    Threads
    1014
    Classifieds
    Quote Originally Posted by Pop Golden View Post
    Pop
    If the motors are PSC (permanent split capacitor,) then they are reversible. These motors usually have a 2 - 5 MF run capacitor, externally connected to motor thru two brown leads. Because they are PSC, they don't have start switches. You remove the end bells, turn rotor around in case and reverse the end bells. These motors don't come with any kind of mounting plate, as they are held in by either bolts thru end bells, or and clamps. A picture would be worth a thousand words.
  8. The following 2 users say Thank You to junquecol :
  9. #6
    Nickname
    Pop (78)
    Join Date
    Jul 2011
    Location
    Charlotte, NC
    Posts
    918
    Visit Freq
    4.31 visits/week
    Threads
    Classifieds
    Hi Gene, The simplest solutions for a problem works every time. THANKS!
    Pop
Similar Threads
  1. AC motor question
    By smallboat in forum Power Tools and Their Use
    Last Post: 07-04-2014, 10:25 PM
  2. Buffing motor rotation problem...
    By Woodman2k in forum Woodturning
    Last Post: 07-09-2010, 09:21 AM
  3. Shopsmith motor question
    By clawofthebear in forum Power Tools and Their Use
    Last Post: 03-25-2010, 06:26 PM
  4. 220 Motor wire up question
    By boxxmaker in forum Power Tools and Their Use
    Last Post: 07-02-2009, 05:54 AM
  5. AC Electric Motor Question
    By Jeff in forum Power Tools and Their Use
    Last Post: 12-24-2008, 04:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
