West Penn Hardwoods (Ad 1)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
  1. #1
    DQ
    Willemjm's Avatar
    Nickname
    Willem
    Join Date
    Dec 2011
    Location
    Pinehurst, NC
    Posts
    959
    Visit Freq
    6.08 visits/week
    Threads
    129
    Classifieds
    Installing cabinets
    Question for the cabinet installers:
    My GC wants the cabinets in before flooring, which I agree with.
    Flooring will be 3/8" engineered wood flooring.
    How do you folks lift the cabinets, or shim them? 3/8" Hardwood strips, with a some leveling shims underneath the cabinet bottom edges? Shims directly on the LP sub floor?? What about the tiled areas like the bathrooms, how much lift there or nothing?
  2. #2
    Nickname
    Join Date
    Mar 2008
    Location
    Snow Camp, NC
    Posts
    Visit Freq
    0.65 visits/week
    Threads
    Classifieds
    Re: Installing cabinets
    You can use hardwood on all cabinet floor contact surfaces. You can also use plywood to cover the whole floor under the cabinet exactly where the cabinet will set
    Only the outside (fronts and exposed ends) edges need to be flush.
  3. #3
    DQ
    danmart77's Avatar
    Nickname
    Dan (66)
    Join Date
    Oct 2007
    Location
    Durham, NC
    Posts
    1,771
    Visit Freq
    6.77 visits/week
    Threads
    315
    Classifieds
    [QUOTE=Willemjm;615643]Question for the cabinet installers:
    I guess it's a choice you make. I do it the other way. There again, I still varnish my floors with oil based varnish and not water borne. I like the convenience and no odor of the water based on some things but for durability on a floor I have found it doesn't match the oil varnish.
    If you get close with 3/8 ply or something similar, the shimming to level/plumb with a laser is a breeze.
    At some point on this project I am doing at home, I have decided I just want to get this done. Delays on deliveries, workers with headaches, and even inventory differences make progress illusive at times.
    Lots of photos to upload but it sounds like the Gallery might go the way of the Concorde??
  4. #4
    DQ
    Skymaster's Avatar
    Nickname
    Jack (78)
    Join Date
    Aug 2009
    Location
    Zebulon, NC
    Posts
    1,885
    Visit Freq
    6.35 visits/week
    Threads
    44
    Classifieds
    Morning, IMHO, being an installer I want the flooring in before the cabinets, reason is in the future if there is a cabinet change it avoids the nightmare of trying to repair,
    For shimming, find a bundle of under coursing shingles, I will look also, you can use good cedar shakes they just cost more. NOTE!!!!!! ALSO IMPORTANT by NOT flooring under cabinets you run a very good chance of real problems installing your dishwasher or any other under counter appliance. Map your walls for stud locations. Hang your walls first, 54" to the bottom of the cabinets FROM THE FINISHED FLOOR, so 54 3/8" in your case. Are you hanging them yourself?
    In fact if you would please call me, way way easier than all this typing? 973 945 6686
  5. #5
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    1,007
    Visit Freq
    6.96 visits/week
    Threads
    Classifieds
    I do this all the time. With 3/8" flooring I just set the cabinets and level normally. There would be no need to raise the cabinets for the flooring and or for the appliances. Flooring above the thickness of 3/8" then you have to raise the cabinets, when I do I usually rip strips of poplar to the appropriate thickness and attach to the bottom of each cabinet and then set accordingly. I hope this helps, and good luck
    Nothing beats a try but a failure, failure is an opportunity to learn.
    http://graywolfwoodworks.wordpress.com/
  6. The following 2 users say Thank You to Graywolf :
  7. #6
    DQ
    Willemjm's Avatar
    Nickname
    Willem
    Join Date
    Dec 2011
    Location
    Pinehurst, NC
    Posts
    959
    Visit Freq
    6.08 visits/week
    Threads
    129
    Classifieds
    Quote Originally Posted by sandfarm View Post
    Thanks Joe,
    I was stressing about this as I have not done it before. 3/8 ply sounds like a great idea!!!
  8. #7
    DQ
    Willemjm's Avatar
    Nickname
    Willem
    Join Date
    Dec 2011
    Location
    Pinehurst, NC
    Posts
    959
    Visit Freq
    6.08 visits/week
    Threads
    129
    Classifieds
    Quote Originally Posted by Graywolf View Post
    Thanks that sure will make things easy. I will ask the GC, see what he says.
  9. #8
    DQ
    Nickname
    Join Date
    May 2008
    Location
    Lexington, SC
    Posts
    1,539
    Visit Freq
    5.12 visits/week
    Threads
    Classifieds
    I installed my new kitchen last year on the finished floor. We moved several equipment locations so the floor had to be patched since the old cabinets went to the sub-floor. On one fairly long run, we ran enough 3/4 oak flooring to get under the cabinet and then stopped and put a few pieces where the sides of the cabinet would go to the subfloor. That got the cabinets up to the right level but didn't waste a lot of flooring.
    I would not want to fit the floor around the cabinets but you could. I would put it in first and just not put it unnecessarily under the cabinets. That will save a bunch of cutting and may not use any more flooring.
    I also installed the lowers first and used home made cabinet jacks that use pipe clamps to install the uppers. Went well.
  10. #9
    Nickname
    DrBob
    Join Date
    May 2014
    Location
    Baldwin, FL
    Posts
    752
    Visit Freq
    3.65 visits/week
    Threads
    62
    Classifieds
    On kitchen cabs I usually use levelling feet (to which the toe kick is attached).
    I find this is so much faster and easier than what you're planning to do.
    That said, when I don't use them, I build the toe kick base and level that by shimming, then screwing a piece of wood to the inside of the frame that touches the floor, then remove the shims. Once you've got that base established, it makes the going a lot easier. In your case, just make it 3/8" higher.
    The only problem I see with installing before floors, is you'll need a shoe moulding.
  11. #10
    DQ
    Willemjm's Avatar
    Nickname
    Willem
    Join Date
    Dec 2011
    Location
    Pinehurst, NC
    Posts
    959
    Visit Freq
    6.08 visits/week
    Threads
    129
    Classifieds
    Quote Originally Posted by Rwe2156 View Post
    Yep I will do a shoe molding. GC now wants 1/2” off floor in kitchen and 3/4” in bathrooms. I will just add strips to the cabinet bottoms.
  12. #11
    DQ
    FredP's Avatar
    Nickname
    Fred (61)
    Join Date
    Jun 2006
    Location
    franklinton, nc
    Posts
    5,694
    Visit Freq
    6.96 visits/week
    Threads
    208
    Classifieds
    I really wouldn't care how the builder wants it. I would tell him how it's going to be. As others have said, if you ever decide to change things around you'll be glad the flooring is already there. A patch will always show.
    fred p If it ain't broke you aint trying hard enough
  13. The following user says Thank You to FredP for this useful post:
  14. #12
    DQ
    Willemjm's Avatar
    Nickname
    Willem
    Join Date
    Dec 2011
    Location
    Pinehurst, NC
    Posts
    959
    Visit Freq
    6.08 visits/week
    Threads
    129
    Classifieds
    Quote Originally Posted by FredP View Post
    This is the second house he is building for me, hands-on guy. The first house he did his own thing as I was working. This time I am on site all the time and I must say that every time I asked him to do things my way it would have turned out better if I just left him alone. We are in the Sandhills and before final landscaping there is sand all over the place. Once the floors are in, he wants no one and no traffic on them. His rationale for lifting the cabinets is to allow replacing them if needed in future as well as the correct height.
  15. #13
    Nickname
    Chuck
    Join Date
    Jan 2018
    Location
    Lowgap, NC
    Posts
    Visit Freq
    6.00 visits/week
    Threads
    Classifieds
    I have to agree not flooring under the cabs is a bad idea. Most of my customers will not have
    shoe mold they want more of a furniture feel. so that means scribed to the floor. As far as protecting the floor there are several roll flooring protection products, such as ram board. I have been installed a lot of cabs on finished floors with flooring protection with no problems.
  16. The following 2 users say Thank You to Ecr1 :
  17. #14
    DQ
    Willemjm's Avatar
    Nickname
    Willem
    Join Date
    Dec 2011
    Location
    Pinehurst, NC
    Posts
    959
    Visit Freq
    6.08 visits/week
    Threads
    129
    Classifieds
    Quote Originally Posted by Ecr1 View Post
    I’ll post pictures when done. I’m probably not familiar with the term “shoe mold”
    I built these custom, once the flooring is in, then I scribe a board against all the toes. Then follows furniture grade molding looking almost like bracket feet which goes around all the cabinets. Those are on the finished floors.
  18. #15
    Nickname
    Join Date
    Jan 2013
    Location
    Mc Leansville, NC
    Posts
    1,866
    Visit Freq
    3.73 visits/week
    Threads
    70
    Classifieds
    Quote Originally Posted by Willemjm View Post
    Shoe mould is similar to quarter round (many "finish" carpenters today use quarter round in place of it, SMH) but true shoe moulding is taller than wide and has a round at the top but actually has a vertical straight section. I think the typical measurements are 5/8 x 1 tall with a a 5/8 R on the top. Shoe moulding should NEVER be used at the base of cabinets IMO, its architecturally wrong as it was originally intended for floor to baseboard gap coverage. Cabinets should have NO gaps at the floor if properly installed.
Similar Threads
  1. Installing baseboard
    By JimD in forum DIY- Home improvement
    Last Post: 11-17-2014, 11:10 AM
  2. Help Installing Jointer Knives
    By llucas in forum Power Tools and Their Use
    Last Post: 12-10-2010, 07:26 AM
  3. Installing a Dust Collector
    By Dudelive in forum Workshop Discussion
    Last Post: 03-07-2010, 02:11 PM
  4. installing a power feeder
    By William Roscoe in forum Power Tools and Their Use
    Last Post: 12-18-2007, 01:07 PM
  5. Installing Mortised Hinges
    By rick7938 in forum General Woodworking
    Last Post: 06-15-2006, 08:43 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
