West Penn Hardwoods (Ad 1)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
  1. #1
    DQ
    Phil S's Avatar
    Nickname
    Phil Soper (68)
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    4,622
    Visit Freq
    7.65 visits/week
    Threads
    541
    Classifieds
    Design Help Request
    I have agreed to outfit our Outreach lathes with spectator shields. I will be fabricating these shields out of polycarbonate sheeting like Lexan. Size will be 30" high and 36 wide, but I am not sure how thick the plastic needs to be. I tend to lean to the when in doubt, make it stout theory but thicker gets costly. Any expert help on this would be nice. Thanks in advance
  2. #2
    DQ
    FredP's Avatar
    Nickname
    Fred (61)
    Join Date
    Jun 2006
    Location
    franklinton, nc
    Posts
    5,696
    Visit Freq
    6.96 visits/week
    Threads
    208
    Classifieds
    Re: Design Help Request
    1/8" should be fine. Lexan is tough stuff.
    fred p If it ain't broke you aint trying hard enough
  3. The following user says Thank You to FredP for this useful post:
  4. #3
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,722
    Visit Freq
    6.96 visits/week
    Threads
    749
    Classifieds
    Agree, we used to make sign faces with Lexan, 1/4 inch was standard for 4x6 foot electric signs. Anything smaller would get 1/8.
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  5. The following user says Thank You to Mike Davis for this useful post:
  6. #4
    Administrator Corporate Member
    DQ
    ehpoole's Avatar
    Nickname
    Ethan (47)
    Join Date
    Oct 2009
    Location
    Anderson, SC
    Posts
    6,102
    Visit Freq
    6.65 visits/week
    Threads
    207
    Classifieds
    A lot will depend upon how the Lexan is supported. If it is rigidly mounted on al four sides then I would be pretty comfortable with 1/8” as well unless you will be turning very large off-center/balance pieces, n which case I would go with 1/4”. If not well supported on all four sides then I would go with 1/4” to be safe. If the Lexan will only be supported by a rabetted edge and not through bolted then you will want a large overlap area as Lexan can bend tremendously if impacted hard — ideally you will want a large overlap area and through booting around the edges. That tendency to bend, and even distort, on severe impact rather than shatter or snap, like acrylic, is part of what gives Lexan its extreme strength, it is very hard to actually pierce or otherwise “break” through Lexan.
    If you do go with 1/4” and you have any scraps left over that are at least 4”x4” to 5”x5” then I would be interested in possibly buying some of the scrap as I need to make a few guy rings for a 50ft temporary antenna mast. Assuming that this is to be done soone, otherwise I will probably go shopping for what I need over the next week or two.
    When designing the rest of the shield you will want to build it fairly heavily out of either wood or steel and you will likely want to be able to stack some real mass (such as sand bags or 5 gallon buckets filled with water, on the lathe side of the shield to help the shield assembly absorb and deflect a severe impact. There is a good chance it may still get knocked over if hit especially hard with a very large piece, but that added mass will help it to absorb and dampen most of the force and deflect it before it falls so that it is only the weight of the shield itself falling into the audience. Legs extending out and into the audience side would greatly reduce the risk of it falling over.
  7. The following user says Thank You to ehpoole for this useful post:
  8. #5
    DQ
    Phil S's Avatar
    Nickname
    Phil Soper (68)
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    4,622
    Visit Freq
    7.65 visits/week
    Threads
    541
    Classifieds
    I will not be making these until Jan. Ethan thanks for the input, it has me thinking as I need to make these portable and light while also being strong enough to serve the intended purpose. We only do small spindle turning.
    I am now wondering if there is an official design spec we must adhere to.
  9. #6
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    1,014
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    Phil, just a short web search I found no specifications and very few ideas. I have seen these shields employed at demos before, I think for what we do the 1/8" material will work with a full frame.
    Nothing beats a try but a failure, failure is an opportunity to learn.
    http://graywolfwoodworks.wordpress.com/
  10. #7
    DQ
    bowman's Avatar
    Nickname
    Neal (58)
    Join Date
    Apr 2017
    Location
    King, NC
    Posts
    781
    Visit Freq
    8.35 visits/week
    Threads
    67
    Classifieds
    With the small items that are turned on these, I feel 1/8 will be sufficient.
    At 30x36, how are you planning to secure these to the lathes?
  11. #8
    DQ
    Nickname
    Gene
    Join Date
    Oct 2016
    Location
    Winterville, NC
    Posts
    449
    Visit Freq
    6.31 visits/week
    Threads
    85
    Classifieds
    AAW has guides/plans and videos. PM if you want the links. I meant to give you copies and forgot. Or send me a fax number. It may be Monday before and I can send a fax, however.
    AAW plans call for 1/4" polycarbonate.
    We may have a capstone project next semester for a design. I'll have the students develop launch trajectories, forces, etc. for a reasonable sized wooden missile. Or maybe a sensitivity analysis across a range of parameters. Testing should be fun. LOL.
    Lawyers will want analysis or (AAW?) standards, not gut feel or experience.
  12. The following 2 users say Thank You to Dee2 :
  13. #9
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,711
    Visit Freq
    6.88 visits/week
    Threads
    654
    Classifieds
    Quote Originally Posted by Dee2 View Post
    I was curious so I went to the American Association of Woodturners (AAW) website and searched for lexan safety shields and lathes, etc. No hits despite several iterations of the safety idea. I'm not an AAW member and maybe its member only content.
  14. #10
    DQ
    Nickname
    Runk
    Join Date
    Feb 2014
    Location
    Supply, NC
    Posts
    44
    Visit Freq
    1.85 visits/week
    Threads
    Classifieds
    You might want to look at grinding wheel safety. Shields used to protect the user from a wheel that breaks in use which sends pieces in all directions. Shields have to protect against the impact of the flying projectile. Mass is taken into consideration when doing the calculation. NIOSH will have written standards for this since this is a work place hazard. When looking for safety standards on almost any hazard that could be work place related, NIOSH will have written a standard that has been tested.
  15. #11
    DQ
    Nickname
    Gene
    Join Date
    Oct 2016
    Location
    Winterville, NC
    Posts
    449
    Visit Freq
    6.31 visits/week
    Threads
    85
    Classifieds
    Jeff, et al.,
    Here are some links
    Cheap version: https://cdn.ymaws.com/aaw.site-ym.co...Safety_060.pdf
    Sophisticated - I think the TAW uses those - and materials cost about $800. It includes structures for mounting various cameras. Here's the link:
    https://cdn.ymaws.com/www.woodturner...fetyShield.pdf
    and the video
    https://vimeo.com/72198125
    Now a question for all of you, for marketing our presence at the AAW next year, please send me a quote about why NCWW is important to you.
    Thank you
  16. The following 2 users say Thank You to Dee2 :
  17. #12
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,711
    Visit Freq
    6.88 visits/week
    Threads
    654
    Classifieds
    Thanks Gene, I found your last 2 links earlier this morning and watched the assembly video. I imagine that Phil is interested in the cheap version and both use 1/4" Lexan.
    Jeff, et al.,
    Here are some links
    and the video
    Thank you
  18. #13
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,711
    Visit Freq
    6.88 visits/week
    Threads
    654
    Classifieds
    How long have the lathes been used at Outreach events without shields and what prompted this request? Aren't the Outreach demonstrations mainly small spindle turnings like the light sabers? Just curious.
  19. #14
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,924
    Visit Freq
    6.85 visits/week
    Threads
    530
    Classifieds
    Quote Originally Posted by Jeff View Post
    We are attending an AAW event as a demonstrator and they have standards that must be followed is what prompted this effort. And yes we only do small spindle turnings.
    Answer to first question is since Outreach began.
    I don't believe in Astrology. I'm a Sagittarius and we're skeptical.
    "May the grain be with you" - Roy Underhill
  20. #15
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,711
    Visit Freq
    6.88 visits/week
    Threads
    654
    Classifieds
    Thanks. Where and when is this AAW event?
    Quote Originally Posted by KenOfCary View Post
Similar Threads
  1. Bed Design
    By Plunkett in forum Project Design
    Last Post: 07-16-2018, 02:57 PM
  2. Design your own?
    By Jeff in forum Project Design
    Last Post: 01-10-2015, 12:11 PM
  3. Design help please
    By Joe Scharle in forum DIY- Home improvement
    Last Post: 10-15-2012, 01:26 PM
  4. Some design help
    By eyekode in forum General Woodworking
    Last Post: 01-21-2012, 10:38 AM
  5. Box Design
    By Arcrist in forum General Woodworking
    Last Post: 03-01-2006, 11:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
