West Penn Hardwoods (Ad 1)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 29
  1. #1
    User Flute Maker's Avatar
    Nickname
    Join Date
    Jun 2009
    Location
    Laurinburg, NC
    Posts
    639
    Visit Freq
    6.54 visits/week
    Threads
    264
    Classifieds
    Lighthouse Build Ideas?
    I have a neighbor/friend who him and his wife love Christmas.He likes to build stuff for Christmas.he is not really a woodworker but is a smart guy ,great mechanic.Anyhow I received this message from him ....(How hard would it be to build a 3-4ft lighthouse?) I would love to do this for him..I havent talked with yet about specific ideas.I am a woodturner...I have a Jet 1642 but not sure I could make it....Any ideas at all? Another way besides turning? It would be simple turning, but I dont have any wood big enough so would have to glue pieces together ...Im looking for a simple idea.Thanks in advance!
  2. #2
    Forum Leader Senior User
    Nickname
    Dave
    Join Date
    Aug 2013
    Location
    Rochester, MN
    Posts
    1,036
    Visit Freq
    6.50 visits/week
    Threads
    74
    Classifieds
    Re: Lighthouse Build Ideas?
    Lighthouses don't have to be round. You could make an octagonal one.
    SketchUp Authorized Training Center
  3. The following user says Thank You to Dave Richards for this useful post:
  4. #3
    User TENdriver's Avatar
    Nickname
    TENdriver
    Join Date
    Nov 2012
    Location
    Wdbg, VA
    Posts
    802
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    Mike, I went down this path several years ago. Fortunately, the project didn’t go forward.
    There are plans for building simple outdoor yard displays that may be suitable and for me, maybe they were the best option.
    Dave’s octagon was another option, but it can involve some complicated angled cuts to get the tapered octagon shape.
    Turning was my first choice. I looked at creating a staved tapered octagon or greater multi-sided form, and then mounting it between centers. I believe you would need to use heavier stock to have enough material to turn into a round. I decided not to try turning a heavy, staved piece that was constructed with complicated angles. If you go down that path, there are some safety concerns along with methods to mitigate some of the risks. I chose not to undertake this.
    Ironically, the yard display plans may have been my best option but I was trying for a lighthouse with a base covered in sisal, so it would be a cat scratcher! The wood working/joinery in the base could have been a little sloppy and still worked out fine.
    I was planning on turning the top lighted portion out of various colors of hardwood. Relatively simple stuff for any turner.
  5. #4
    Nickname
    Dave
    Join Date
    Aug 2013
    Location
    Rochester, MN
    Posts
    1,036
    Visit Freq
    6.50 visits/week
    Threads
    74
    Classifieds
    If you do opt for an octagonal lighthouse, you can make the construction fairly simple using a birdsmouth on one edge of each stave. This avoids the need to sort out some hard to measure bevel angle. Make the tapered staves based on the desired width at the top and bottom and cut the birdsmouth with a dado stack titled at 45. The birdsmouth method also makes it easy to assemble when it's time to glue up. If you want help with it, let me know.
  6. #5
    User Pop Golden's Avatar
    Nickname
    Pop (78)
    Join Date
    Jul 2011
    Location
    Charlotte, NC
    Posts
    918
    Visit Freq
    4.38 visits/week
    Threads
    Classifieds
    Hi Dave, I'm not building a lighthouse, but what's a birdsmouth? I've been in woodworking for more than 60 years and never heard that term before.
    Pop
  7. #6
    Nickname
    Dave
    Join Date
    Aug 2013
    Location
    Rochester, MN
    Posts
    1,036
    Visit Freq
    6.50 visits/week
    Threads
    74
    Classifieds
    Hi Pop,
    A birdsmouth is a V-groove cut in one edge of a stave for a round or tapered thing. It's much easier than beveling the edges of the staves and it makes the assembly much easier to hold together. Once the staves are aligned, you can drop straps or zip ties if they'll fit an pull them up tight to clamp it. This method has been used for many years by boatbuilders for making hollow spars--booms, sprits, gaffs, yards, and even masts. It gained popularity in the general woodworking community maybe 10 years ago and some of the router bit companies now make router bits to cut the grooves. For an 8-sided structure, it's easy enough to cut them on the table saw. Tapered shapes like the lighthouse or even double tapered things like a yard for a square rigged vessel are just about as simple as a straight cylinder. You can also create oval cross sections by making staves on opposite sides of the assembly wider than the rest.
    Here's the start of a lighthouse for Mike showing the birdsmouth.
  8. The following 2 users say Thank You to Dave Richards :
  9. #7
    DQ
    Nickname
    Roy
    Join Date
    Apr 2010
    Location
    Apex, NC
    Posts
    943
    Visit Freq
    6.58 visits/week
    Threads
    54
    Classifieds
    I made my granddaughter a lighthouse dollhouse a few years ago. It had to have a removable side so she could arrange furniture and dolls inside. It wasn't that difficult to cut the joints, just figure out the angle necessary based on the number of sides you want.The picture that Dave posted is similar to what I made, only I had to have 3 floors inside. And then you have to make the bit up top where the light is supposed to go. Use pine and paint it, no need for hardwood here.
    Roy G
  10. #8
    DQ
    Phil S's Avatar
    Nickname
    Phil Soper (68)
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    4,622
    Visit Freq
    7.65 visits/week
    Threads
    541
    Classifieds
    Here is one I made probably 20 years ago. Easy to turn and fairly simple to light up
  11. The following 2 users say Thank You to Phil S :
  12. #9
    Nickname
    Dave
    Join Date
    Aug 2013
    Location
    Rochester, MN
    Posts
    1,036
    Visit Freq
    6.50 visits/week
    Threads
    74
    Classifieds
    That looks lovely, Phil. Does the light or the reflector go around?
  13. #10
    DQ
    Nickname
    Charley (76)
    Join Date
    May 2008
    Location
    Kannapolis, NC
    Posts
    1,028
    Visit Freq
    4.81 visits/week
    Threads
    Classifieds
    A Google search for "Lighthouse Plans" brought this up quickly https://www.pinterest.com/pin/91197961189435152/
    There are more, but this one is a free download.
    Charley
  14. #11
    DQ
    Phil S's Avatar
    Nickname
    Phil Soper (68)
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    4,622
    Visit Freq
    7.65 visits/week
    Threads
    541
    Classifieds
    Quote Originally Posted by Dave Richards View Post
    No it does not but version two will. I will also make sure the Google assistant can control the light and rotation
  15. #12
    Nickname
    Join Date
    Jun 2009
    Location
    Laurinburg, NC
    Posts
    639
    Visit Freq
    6.54 visits/week
    Threads
    264
    Classifieds
    Thanks Guys...Some good ideas,plans and pics! ( I was a little fuzzy on the birdsmouth too lol) Thanks for clearing that up to Dave! Thanks everybody!
  16. #13
    Nickname
    Pop (78)
    Join Date
    Jul 2011
    Location
    Charlotte, NC
    Posts
    918
    Visit Freq
    4.38 visits/week
    Threads
    Classifieds
    Thanks Dave for the birdsmouth explanation .
    Pop
  17. The following user says Thank You to Pop Golden for this useful post:
  18. #14
    Nickname
    Dave
    Join Date
    Aug 2013
    Location
    Rochester, MN
    Posts
    1,036
    Visit Freq
    6.50 visits/week
    Threads
    74
    Classifieds
    FWIW, there are some different online calculators that allow you to enter things like the number of staves, diameter of the finished turned spar and the desired wall thickness and get the required stave dimensions and other information. These are useful when you need to make round things like spars for boats. I made one years ago in Excel. Was thinking of remaking it.
    It's easier for the lighthouse if it is to remain octagonal.
  19. #15
    DQ
    Nickname
    Jim (71)
    Join Date
    Feb 2013
    Location
    Durham, NC
    Posts
    1,562
    Visit Freq
    7.00 visits/week
    Threads
    86
    Classifieds
    Another type of joint for 8-sided glue-ups can be made with a 22-1/2 degree lock miter router bit set. MLCS and Infinity both sell them with MLCS being about half the price of Infinity.
    MLCS also sells bird's mouth bits for 6 or 12, 8, and 16 side glue joints.
Similar Threads
  1. Lighthouse
    By Dee2 in forum Woodturning
    Last Post: 03-13-2017, 05:41 PM
  2. Need ideas on how to build a bench vise for a kids workbench
    By cyclopentadiene in forum "How To" Forum
    Last Post: 12-05-2013, 12:37 AM
  3. Lighthouse Clock
    By Hook in forum Scrollsaw Work
    Last Post: 06-06-2010, 05:00 PM
  4. Hatteras Lighthouse box
    By wdkits1 in forum Scrollsaw Work
    Last Post: 09-27-2009, 06:59 PM
  5. Need Plans For Lighthouse!
    By helmswatch in forum Where Can I Find, Buy or Sell
    Last Post: 11-12-2006, 12:07 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
