West Penn Hardwoods (Ad 1)
Results 1 to 9 of 9
  1. #1
    Nickname
    Join Date
    Nov 2005
    Location
    Apex, NC
    Posts
    6,028
    Visit Freq
    5.35 visits/week
    Threads
    1002
    Classifieds
    Winterizing the Power Washer
    It's getting to be the time to winterize the power washer. You buy premade mixes to run thru the pump. My favorite is shop made. Combine RV antifreeze, and mineral oil, shake well, and run thru pump. I use about 25% mineral oil, and the rest is RV antifreeze. The first time I did this, I bought a bottle of "Pump Saver" from Northern. Now I just refill bottle with shop made mixture. Mineral oil is sold as a laxative. Don't have to worry, as it's "food grade."
  2. The following 5 users say Thank You to junquecol :
  3. #2
    Nickname
    joe
    Join Date
    Dec 2008
    Location
    Wilmington, NC
    Posts
    204
    Visit Freq
    4.19 visits/week
    Threads
    Classifieds
    Re: Winterizing the Power Washer
    I just bought a nice pressure washer along with a premade mixture of pump winterize fluid. I had a hard time when I experimented with getting the fluid into the pump. The instructions said screw the plastic bottle into the intake side and squeeze the bottle while pulling the cord. It did not work very well. How do you get your homemade fluid into the pump?
  4. #3
    Nickname
    Michael
    Join Date
    Nov 2005
    Location
    Winterville, NC
    Posts
    357
    Visit Freq
    1.88 visits/week
    Threads
    Classifieds
    Don't neglect the fuel and carbs. I made the mistake of prepping the pump but not the carbs. The stuff that is called gasoline will gunk up a carb if left sitting all winter. I now use the gas sold in the gallon cans from the Stihl dealer; it has no ethanol and has a fuel stabilizer mixed in. The big box stores sell it also.
    Had to take the pressure washer to the dealer to have the carb professionally cleaned. When I started using the purchased fuel, I was able to start the unit on the second pull after the winter nap.
  5. #4
    Nickname
    tom
    Join Date
    Oct 2009
    Location
    Clayton, NC
    Posts
    210
    Visit Freq
    6.73 visits/week
    Threads
    Classifieds
    I'm swearing off gas with alcohol in it for my small engines. I'm tired of cleaning out carbs or having to swap them out so i can get something to run. I need to research where to find the good stuff but am pretty sure I'm not going to buy it by the gallon at the borg - way too pricey for me.
  6. #5
    DQ
    sawman101's Avatar
    Nickname
    Bruce Swanson
    Join Date
    Feb 2009
    Location
    Newton, NC
    Posts
    3,087
    Visit Freq
    6.65 visits/week
    Threads
    187
    Classifieds
    Due to not being able to find non-ethanol gas in my area, I have used Stabil and Sea Foam in my gas cans. I've only had one failure and had to have the carb replaced on my Stihl leaf blower. I have around 10 small engines I keep running. I always fill my cans with the highest octane gas at the pump, which also helps and the Stabil to keep the gas from breaking down, while the Sea Foam helps to keep the fuel system clean and running more efficiently.
    Experience is a hard teacher; she gives the test first, and the lesson later.
  7. #6
    Nickname
    Bob Vaughan
    Join Date
    Sep 2009
    Location
    Roanoke, VA
    Posts
    568
    Visit Freq
    5.08 visits/week
    Threads
    Classifieds
    I guess that not all pressure washers are the same. The pump on the one I have slides right off after four bolts are removed. I'll put the pump in a plastic bag and store it in the basement for the winter. I think that might be faster than all of that fluid fool around and probably less risk. I'll blow it out with compressed air at low pressure. It seems to work over the years I've been doing it.
  8. #7
    Administrator Corporate Member
    DQ
    ScottM's Avatar
    Nickname
    Join Date
    Jul 2007
    Location
    Littleton, NC
    Posts
    10,950
    Visit Freq
    6.27 visits/week
    Threads
    946
    Classifieds
    Quote Originally Posted by sawman101 View Post
    Bruce try checking gas stations near the lake. Lake Hickory and others. Many boat owners won't use ethanol either so many stations near lakes carry it. Now expect to pay more.
    Maker of fine saw dust
    "Ability is what you are capable of doing. Motivation determines what you do. Attitude determines how well you do it."
    - Lou Holtz-
  9. #8
    DQ
    Gotcha6's Avatar
    Nickname
    Join Date
    Jan 2007
    Location
    Ivan's Corner (Monroe), NC
    Posts
    5,739
    Visit Freq
    6.85 visits/week
    Threads
    349
    Classifieds
    Try the website puregas.org to locate ethanol free gas in your area. They can even give you directions to them on a smartphone. As for stations around the lake,w hen I bought gas in Rock Hill near Lake Wylie, the receipts for ethanol free always described it as 'boat gas'.....
    WHAT BOX?
  10. #9
    DQ
    Nickname
    Mike (65)
    Join Date
    Aug 2013
    Location
    Cary, NC
    Posts
    1,712
    Visit Freq
    6.85 visits/week
    Threads
    324
    Classifieds
    Due to not being able to find non-ethanol gas in my area...
    According to this list, there are three stations in Newton that have non-ethanol gas.
  11. The following user says Thank You to patlaw for this useful post:
Similar Threads
  1. Washer for Delta shaper
    By Mike Wilkins in forum Where Can I Find, Buy or Sell
    Last Post: 05-02-2018, 08:29 PM
  2. Pressure washer specs
    By redknife in forum DIY- Home improvement
    Last Post: 09-19-2016, 11:59 AM
  3. Winterizing the Pressure Washer
    By junquecol in forum DIY- Home improvement
    Last Post: 10-02-2011, 09:19 PM
  4. Pressure Washer Pump Failure
    Last Post: 07-21-2011, 07:14 PM
  5. Looking for a power washer I can borrow or buy?
    By Marlin in forum Where Can I Find, Buy or Sell
    Last Post: 04-23-2007, 10:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
