Klingspor's Woodworking Shop (Festool) Ad #2
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 51
  1. #1
    Administrator Corporate Member
    DQ
    bowman's Avatar
    Nickname
    Neal (58)
    Join Date
    Apr 2017
    Location
    King, NC
    Posts
    820
    Visit Freq
    8.00 visits/week
    Threads
    Classifieds
    Whistle, idea from Stokes Stomp
    While working the Outreach trailer at the recent Stokes Stomp event, Richard pulled a turned whistle from his magic bag of tools. We worked on it during a couple of slow times and walked away with a couple of working models.
    Today, I took a blank that was about 1" across, and 4-5" long. I drilled a 3/8" hole that was around 3" deep. From there, a quick trip to the bandsaw to cut away the section where the sound would exit. Next up, I turned a dowel that was 3/8" diameter to act as a jam chuck of sorts. Putting the blank on the dowel, and bringing up the tailstock for required support, I began turning it down into the shape you see below.
    Afterwards, i took a 3/8" poplar dowel and flattened one side less than 1/16" to allow for the air to pass into the whistle. The first attempt failed and wound up drilling that one out, then took the flat side to about 1/8". Inserting this into the whistle, i left about 1/2" on the outside so i could grab to remove for further "tuning".
    The ones we did at Stomp were not very loud, and you had to hold it in a certain way to get any sound at all. This one worked much better. So I took a small dab of TB, and applied to one side of the insert. While I had the insert long enough to use to hold, I rubbed on some Tung Oil finish.. After the finish and glue dried, I cut off the insert to the end of the whistle.
    Not factoring in the time to cut the blank and section out, nor the time to make the jam chuck, flattening the dowel (multiple times), I spent about 15 minutes creating this one whistle. That also included applying a finish. I took it very slow as I used some burled cherry stock, so I did not want to blow it out by being aggressive with my turning. I did not use carbide tools, and I did not have to sand after using the skew chisel.
  2. The following 13 users say Thank You to bowman :
  3. #2
    DQ
    Phil S's Avatar
    Nickname
    Phil Soper (68)
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    4,649
    Visit Freq
    7.42 visits/week
    Threads
    544
    Classifieds
    Re: Whistle, idea from Stokes Stomp
    I am glad to see you working on this. This looks like a workable project. Suggestion - make a few more and then have a few members make one and hopefully the design will evolve into a very kid friendly project. The light sabers, that Outreach has probably helped kids of all ages make upwards of a thousand, started out this same way. The light saber is a simple project but I must have made at least ten before I showed it to the group and then they improved it to what it is today - same can happen here
    Thanks for doing this Neal
  4. The following 6 users say Thank You to Phil S :
  5. #3
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    1,035
    Visit Freq
    6.96 visits/week
    Threads
    Classifieds
    I think that's great. Thanks for picking up on this Neal. If you would like we could get together at my place one day and I'll show you how I produced mine and maybe we can come up with some new ideas.
    Nothing beats a try but a failure, failure is an opportunity to learn.
    http://graywolfwoodworks.wordpress.com/
  6. The following 3 users say Thank You to Graywolf :
  7. #4
    DQ
    jcz's Avatar
    Nickname
    Johnny
    Join Date
    Mar 2011
    Location
    Pinetops, NC
    Posts
    252
    Visit Freq
    6.58 visits/week
    Threads
    Classifieds
    I have made a pile of whistles. Mine are designated as duck calls and I drill the air hole instead of cutting it. They can be a simple project but I go the extra mile and make them very complicated. But I tend to overthink things.
    Try drilling your next one with 1/2 instead of 3/8.
  8. The following 2 users say Thank You to jcz :
  9. #5
    DQ
    bowman's Avatar
    Nickname
    Neal (58)
    Join Date
    Apr 2017
    Location
    King, NC
    Posts
    820
    Visit Freq
    8.00 visits/week
    Threads
    Classifieds
    I drilled with a 10mm bit, and the fit is much better.
    I broke 2 in the process of turning them, i changed the jam chuck, and one snapped while in the process of turning. The 2nd broke when trying to fit the dowel in before changing to the 10mm bit.
    I had cut the slot both times. I turned a 4th after channing the bit and jam chuck and it came out much better. The jam chuck moved in the process, and presented some wobble, so it is off center. I used a Japanese pull saw to cut the section out. For these, i did not precut the section out, used the carbide tools, and this seems to be a safer option for kids.
  10. #6
    DQ
    bowman's Avatar
    Nickname
    Neal (58)
    Join Date
    Apr 2017
    Location
    King, NC
    Posts
    820
    Visit Freq
    8.00 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Graywolf View Post
    Thanks Richard, that sounds like a good plan. I'll get with you for a time that works for both of us.
  11. #7
    DQ
    bowman's Avatar
    Nickname
    Neal (58)
    Join Date
    Apr 2017
    Location
    King, NC
    Posts
    820
    Visit Freq
    8.00 visits/week
    Threads
    Classifieds
    Quote Originally Posted by jcz View Post
    I'll give that a try as well.
  12. #8
    DQ
    jcz's Avatar
    Nickname
    Johnny
    Join Date
    Mar 2011
    Location
    Pinetops, NC
    Posts
    252
    Visit Freq
    6.58 visits/week
    Threads
    Classifieds
    I like the 1/2” because I have a 1/2” expanding mandrel in my collet chuck. Makes turning them much easier.
  13. The following user says Thank You to jcz for this useful post:
  14. #9
    Co-director of Outreach Corporate Member
    DQ
    golfdad's Avatar
    Nickname
    Dirk (63)
    Join Date
    Oct 2005
    Location
    Clayton, NC
    Posts
    2,901
    Visit Freq
    6.65 visits/week
    Threads
    141
    Classifieds
    Neal I have a whole bucketfull of blanksforthese...Iwill bring them to King next Sat
  15. The following user says Thank You to golfdad for this useful post:
  16. #10
    DQ
    bowman's Avatar
    Nickname
    Neal (58)
    Join Date
    Apr 2017
    Location
    King, NC
    Posts
    820
    Visit Freq
    8.00 visits/week
    Threads
    Classifieds
    Can you point me to the collet and mandrel you use?
  17. #11
    DQ
    jcz's Avatar
    Nickname
    Johnny
    Join Date
    Mar 2011
    Location
    Pinetops, NC
    Posts
    252
    Visit Freq
    6.58 visits/week
    Threads
    Classifieds
    Collet chuck is from Penn state industries. The mandrel is from river mallard. Webfoot also has a mandrel. Or a cheaper but shorter mandrel can be found at enco in their arbor set. I can post links this evening if needed. A quick google of webfoot and river mallard should yield results. They are both geared towards the call making world.
  18. The following 4 users say Thank You to jcz :
  19. #12
    DQ
    bowman's Avatar
    Nickname
    Neal (58)
    Join Date
    Apr 2017
    Location
    King, NC
    Posts
    820
    Visit Freq
    8.00 visits/week
    Threads
    Classifieds
    Took Phil's advice, created a few more whistle style's, some turned out better than others. All were cut with carbide tools from the Outreach trailer (except for the very first one- cherry burl). Due to differing wall thicknesses, cutting the section was difficult for me.
    The actual turning is not difficult, and goes faster than the light sabers. Depending on a wooden jam chuck could present issues as it allows the piece to slip while turning. Not giving up yet.
  20. The following 2 users say Thank You to bowman :
  21. #13
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    1,035
    Visit Freq
    6.96 visits/week
    Threads
    Classifieds
    I think I can help you with that. But it'll be easier to show you. I'll try and post something on Sunday, I'm getting ready for my workshop this morning.
    by the way, those look cool!
  22. The following 3 users say Thank You to Graywolf :
  23. #14
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,793
    Visit Freq
    6.96 visits/week
    Threads
    753
    Classifieds
    The Deweys use hot glue to hold small pieces onto jam chucks. Then a heat gun to remove it. That could work for gluing in the thistles too.
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  24. The following user says Thank You to Mike Davis for this useful post:
  25. #15
    DQ
    sawman101's Avatar
    Nickname
    Bruce Swanson
    Join Date
    Feb 2009
    Location
    Newton, NC
    Posts
    3,309
    Visit Freq
    6.69 visits/week
    Threads
    209
    Classifieds
    There are a some You Tube videos on turning whistles. Here is one link;
    https://www.youtube.com/watch?v=gje-QmwUaFQ
    What a great new idea! Y'all are awesome!
    Experience is a hard teacher; she gives the test first, and the lesson later.
  26. The following user says Thank You to sawman101 for this useful post:
Similar Threads
  1. Stokes Stomp in two weeks.
    By Mike Davis in forum NCWW Outreach
    Last Post: 09-03-2018, 02:31 PM
  2. Stokes Stomp
    By golfdad in forum NCWW Outreach
    Last Post: 09-12-2016, 04:52 PM
  3. Stokes Stomp
    Last Post: 09-09-2016, 12:32 PM
  4. Help at Stokes Stomp
    Last Post: 09-08-2016, 01:53 PM
  5. Stokes Stomp
    Last Post: 06-02-2016, 07:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
