Klingspor's Woodworking Shop (Festool) Ad #2
Results 1 to 14 of 14
  1. #1
    Returning Member tonyps's Avatar
    Nickname
    Tony
    Join Date
    Dec 2006
    Location
    Durham, NC
    Posts
    211
    Visit Freq
    0.04 visits/week
    Threads
    Classifieds
    Kitchen cabinet drawer spacing, layout
    Morning, hope this finds you all doing well!
    I am beginning the process to build a series of lower/upper cabinets for our kitchen. The cabinets will be without face frames. The uppers I think I have a handle on, pretty much.
    The lowers are where I am stuck a bit.
    We want a couple of lower cabinets with drawers. One would be with all the same size drawers. The other with drawers we would like to start with say a 6" height drawer at the top and have the remaining drawers each with a little more height.
    These are all standard height lower cabinets.
    Would making each additional drawer an inch more in height than the previous one be ok?
    Also, when mounting the drawer slides to the cabinet sides, would I measure to place them where the center of each drawer would be in the cabinet?
    It would be wonderful to get this right the first time.
    Thanks as always for all your wonderful ideas and talent.
    Tony
    Tony Strother
    SFC, USA (Ret.), DAV
    "We can generally fix ignorant. Stupid, well now that is gonna take a wee bit longer."
  2. #2
    DQ
    Skymaster's Avatar
    Nickname
    Jack (78)
    Join Date
    Aug 2009
    Location
    Zebulon, NC
    Posts
    1,885
    Visit Freq
    6.35 visits/week
    Threads
    44
    Classifieds
    Re: Kitchen cabinet drawer spacing, layout
    All depends on your drawer hardware, Have you decided on it? normally the opening for a drawer is about 1 1/2 bigger than the drawer size, height wise. reason: 1/4 clearance for bottom, 6" inside drawer, plus 1/2 for bottom, plus 1/2 for location of dado for bottom, and clearance at top.
    Willing to help you brother with whatever I can. PM with any questions
    Jack USAF
  3. #3
    Nickname
    Tony
    Join Date
    Dec 2006
    Location
    Durham, NC
    Posts
    211
    Visit Freq
    0.04 visits/week
    Threads
    Classifieds
    Afternoon Jack and thanks for the info. I did not know about the bottom and top clearance requirements so that certainly helps! I have more questions but will hit you up later.
    Regards,
    Tony
    Tony Strother
  4. #4
    DQ
    Skymaster's Avatar
    Nickname
    Jack (78)
    Join Date
    Aug 2009
    Location
    Zebulon, NC
    Posts
    1,885
    Visit Freq
    6.35 visits/week
    Threads
    44
    Classifieds
    Any time Brother, stay safe with the showers that are approaching Also the norm is biggest drawer on bottom and reduction towards the top.
  5. #5
    Nickname
    Tony
    Join Date
    Dec 2006
    Location
    Durham, NC
    Posts
    211
    Visit Freq
    0.04 visits/week
    Threads
    Classifieds
    Afternoon,
    All this info and I may learn something yet!
    Same to you and thanks again!
    Tony
    Tony Strother
  6. #6
    DQ
    Nickname
    Join Date
    May 2008
    Location
    Lexington, SC
    Posts
    1,541
    Visit Freq
    5.04 visits/week
    Threads
    Classifieds
    I like to make drawers with solid wood fronts dovetailed to 1/2 baltic birch sides and back. I do it on dressers and did it on a kitchen island. To have more space, I made the island like a dresser without drawer slides. My wife had agreed upon that plan and liked the island fine. Without slides, you just allow the clearance you select between the drawer opening and the drawer box.
    My normal dovetail jig has 7/16 spacing so drawer heights are in increments of 7/8 inch. I think it looks good to have them increasing by 7/8 going from the top to the bottom. But I almost always make a simple sketch of the project to check proportions before I start making sawdust.
    You can make drawers similar to what I do with drawer slides but will need to make the drawer front separately to hide the slides. And you have to allow for the clearance required for the hardware.
  7. #7
    DQ
    Nickname
    Phil
    Join Date
    Dec 2014
    Location
    Raleigh, NC
    Posts
    62
    Visit Freq
    3.73 visits/week
    Threads
    Classifieds
    Sorry, dovetail the fronts to the baltic birch sides? Not full baltic birch drawer attached to solid wood fronts? You use a dovetail jig for baltic birch? Always had problems with plywood and dovetail jigs.
  8. #8
    DQ
    Phil S's Avatar
    Nickname
    Phil Soper (68)
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    4,622
    Visit Freq
    7.65 visits/week
    Threads
    541
    Classifieds
    Assuming you are planning on 34 1/2" tall cabinets with a 4", I would make the drawer fronts 5, 6 1/2, 8, 11. The drawer boxes would be smaller depending on your slide choice
  9. #9
    DQ
    Nickname
    Michael (69)
    Join Date
    Nov 2009
    Location
    Boone, NC
    Posts
    59
    Visit Freq
    1.73 visits/week
    Threads
    19
    Classifieds
    Here are a couple of links about graduated drawer heights that might be of use to you.
    https://www.woodbin.com/calcs/drawer-sizer/
    https://www.popularwoodworking.com/t...orking_design/
  10. #10
    DQ
    Nickname
    Join Date
    May 2008
    Location
    Lexington, SC
    Posts
    1,541
    Visit Freq
    5.04 visits/week
    Threads
    Classifieds
    Phil,
    Yes, I dovetail baltic birch plywood and yes, I dovetail it to solid wood. The island had at least one drawer around 11 inches tall that way. I finish the drawers inside and out and have not had problems. But I am aware that joining plywood to solid wood is not advisable. But so far it has worked fine for me. I think the reason it works is the fact that the drawer, and the solid wood front in particular, is fully finished. Usually with a water borne pre-cat lacquer. That greatly retards any moisture changes and associated wood movement.
    Dovetailing baltic birch requires a little different technique. I normally back cut it. That is kind of hard on the bit but I get a lot less chip-out that way. If I cut it normally, it is sometimes not usable. I also make a light scoring cut first. With the right technique, it works.
  11. #11
    DQ
    Nickname
    Phil
    Join Date
    Dec 2014
    Location
    Raleigh, NC
    Posts
    62
    Visit Freq
    3.73 visits/week
    Threads
    Classifieds
    Quote Originally Posted by JimD View Post
    Yes, I dovetail baltic birch plywood and yes, I dovetail it to solid wood. . . .
    Different technique is right. I have been unable to dovetail baltic birch. I am going to try a lock mitre bit for a plywood box and attach the wood fronts to the box.
  12. #12
    DQ
    Nickname
    Join Date
    May 2008
    Location
    Lexington, SC
    Posts
    1,541
    Visit Freq
    5.04 visits/week
    Threads
    Classifieds
    Making a solid wood front separate from a plywood drawer box makes a lot of sense, and is really almost required if you are using a drawer slide.
    I have to make several dressers within the next year (or at least I want to) and plan to use my normal baltic birch for the drawer sides and back, at least, with my normal dovetails. I've done at least one large dresser this way and the island I mentioned earlier and was pleased with the result.
    I also normally cut drawer pieces to width but not length prior to making the initial joints. That way I can cut off a joint or even two if I don't like the results. But the other end must be on a piece cut to length so I don't get to practice forever.
  13. #13
    Nickname
    DrBob
    Join Date
    May 2014
    Location
    Baldwin, FL
    Posts
    752
    Visit Freq
    3.65 visits/week
    Threads
    62
    Classifieds
    Quote Originally Posted by tonyps View Post
    Tony
    For utility use like a kitchen, function trumps all. I'll explain in a minute.
    I leave 3/4 - 1" at the top, so lets say a standard 34 1/2" that leaves 33 1/2" total for the drawer bank.
    Lets say you go with 6" fronts for the top drawers. That leaves 27 1/2 to divide into 3 or 4 drawers.
    Something like 7, 9, 11 1/2 (not accounting for gaps) might be a starting point.
    However, if you want to store tall items like soup pots in the bottom drawer, you may need a drawer space around 12-13", which only leave room for 2 drawers below the top.
    That said, there is nothing wrong with equally spaced drawers, but in a kitchen it is dictated by use and 4 equally spaced drawers don't always work out function wise.
    For side mounts, mount the slides so the screws are above the drawer bottom groove. This will usually be about 1" from the bottom (center).
  14. #14
    Nickname
    Craft Beer Guy
    Join Date
    Sep 2015
    Location
    Cornelius, NC
    Posts
    Visit Freq
    1.04 visits/week
    Threads
    Classifieds
    Hey Tony, everyone pretty much nailed it for ideas. I've always picked up a pad of 18"x24" graph paper and drew to scale. It's amazingly helpful and you can adjust your proportions. On my last set of kitchen cabinets, I had some unusual drawer configurations plus the base cabinets look like they are on legs. So I drew a few in actual size. Wore out three erasers. Good luck.
    Attached Images Attached Images
Similar Threads
  1. Kitchen Cabinet Finishes
    By Mark Johnson in forum Finishing
    Last Post: 06-28-2017, 09:52 AM
  2. Kitchen Cabinet Recommendations
    By Durnik in forum DIY- Home improvement
    Last Post: 11-20-2014, 07:14 PM
  3. Gun cabinet spacing?
    By skeeter in forum General Woodworking
    Last Post: 10-14-2009, 09:12 PM
  4. Drawer Fronts for Kitchen>Integral or Applied
    By cc4digital in forum General Woodworking
    Last Post: 11-05-2006, 09:24 AM
  5. Kitchen Cabinet Doors
    By nelsone in forum Where Can I Find, Buy or Sell
    Last Post: 11-04-2006, 09:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
