Klingspor's Woodworking Shop (Locations) Ad #1
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 28
  1. #1
    DQ
    Nickname
    Mike (65)
    Join Date
    Aug 2013
    Location
    Cary, NC
    Posts
    1,830
    Visit Freq
    6.92 visits/week
    Threads
    339
    Classifieds
    Saw Table Discoloration
    I'm still in the trying-to-keep-it-looking-new phase with my SawStop, but I'm losing the battle quickly. Last night, I set a board on one of the cast iron wings. That board, unbeknownst to me, had some wet glue on it. A few minutes later, when I picked up the board, I was unpleasantly surprised to see this discoloration in the top. Keep in mind that this discoloration is what remains after I tried cleaning it with Bar Keeper's Friend, Brasso, and 409. While I'm sure the table will become further discolored over time, I sure don't understand how yellow glue can cause such an unsightly appearance on a cast iron table top. Didn't SawStop know that the saw was likely to be used around wood glue? (Ignore the light reflection at the bottom of the photo.)
    Attached Images Attached Images
  2. #2
    DQ
    Nickname
    Jim (71)
    Join Date
    Feb 2013
    Location
    Durham, NC
    Posts
    1,534
    Visit Freq
    6.96 visits/week
    Threads
    85
    Classifieds
    Re: Saw Table Discoloration
    I'd try some 000 steel wool and WD-40 to get that off. Then treat the top with CRC 3-36 as needed. I use CRC 3-36 on everything cast iron in my shop and have zero rust.
  3. #3
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,662
    Visit Freq
    6.96 visits/week
    Threads
    746
    Classifieds
    Cast Iron oxidizes very quickly with the slightest moisture. It must be chemically protected with oil or wax.
    Be sure NOT to use silicone because it will attach to wood fibers and make any attempt at finishing horrible.
    Many automotive waxes and some furniture paste waxes contain silicone.
    But, I am reminded of my art supplier when I complained about the paint cracking and peeling on some very expensive paint brushes. His reply was; Are you gonna use it or look at it?
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  4. The following user says Thank You to Mike Davis for this useful post:
  5. #4
    Administrator Corporate Member
    DQ
    ScottM's Avatar
    Nickname
    Join Date
    Jul 2007
    Location
    Littleton, NC
    Posts
    11,003
    Visit Freq
    6.65 visits/week
    Threads
    948
    Classifieds
    File it under stuff happens. Had a similar experience when my Saw Stop was new. Mine was caused by daughter's idiot boy friend working on his r/c car. Spilled something. Thankfully she finally dumped him. The stain is still there but it cuts fine.
    Maker of fine saw dust
    "Ability is what you are capable of doing. Motivation determines what you do. Attitude determines how well you do it."
    - Lou Holtz-
  6. The following user says Thank You to ScottM for this useful post:
  7. #5
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    982
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    I know it's like a new car, but at the end of the day it's a tool to be used and not a fine piece of art. Treat it as such, use it, but don't abuse it.
    Nothing beats a try but a failure, failure is an opportunity to learn.
    http://graywolfwoodworks.wordpress.com/
  8. #6
    DQ
    Nickname
    Mike (65)
    Join Date
    Aug 2013
    Location
    Cary, NC
    Posts
    1,830
    Visit Freq
    6.92 visits/week
    Threads
    339
    Classifieds
    Quote Originally Posted by Graywolf View Post
    But it costs as much as a fine piece of art...
  9. #7
    DQ
    Nickname
    Mike (65)
    Join Date
    Aug 2013
    Location
    Cary, NC
    Posts
    1,830
    Visit Freq
    6.92 visits/week
    Threads
    339
    Classifieds
    Quote Originally Posted by nn4jw View Post
    I'll try that. By the way, I neglected to mention that it WAS treated with CRC 3-36. I spray some on every day or two and wipe it down. Maybe the WD40 will help.
  10. #8
    DQ
    Skymaster's Avatar
    Nickname
    Jack (78)
    Join Date
    Aug 2009
    Location
    Zebulon, NC
    Posts
    1,875
    Visit Freq
    6.54 visits/week
    Threads
    Classifieds
    top cote
  11. #9
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,662
    Visit Freq
    6.96 visits/week
    Threads
    746
    Classifieds
    Oh, one other thing. Cast Iron is porous so rubbing the surface will not remove stains. You have to dissolve the rust with a mild acid like vinegar. Then neutralize the acid with baking soda. Then treat with oil or wax.
    WWFD
  12. The following 2 users say Thank You to Mike Davis :
  13. #10
    DQ
    Nickname
    Mike (65)
    Join Date
    Aug 2013
    Location
    Cary, NC
    Posts
    1,830
    Visit Freq
    6.92 visits/week
    Threads
    339
    Classifieds
    Quote Originally Posted by Mike Davis View Post
    Is this discoloration actually rust? What vinegar? Rub it on? Let it soak? Thanks.
  14. #11
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,662
    Visit Freq
    6.96 visits/week
    Threads
    746
    Classifieds
    Yes, black iron oxide. Apple cider vinegar. best to let it soak over night, maybe soak a small sponge and lay it on the rust spot...
    Here are some other methods to try.
    https://www.wikihow.com/Remove-Rust-and-Corrosion#
    WWFD
  15. The following 4 users say Thank You to Mike Davis :
  16. #12
    DQ
    tdukes's Avatar
    Nickname
    Eddie
    Join Date
    Nov 2017
    Location
    Lexington, SC
    Posts
    508
    Visit Freq
    2.81 visits/week
    Threads
    92
    Classifieds
    I think glue is worse than sweat. You can wipe off both as they happen but I think glue must be more corrosive.
  17. #13
    User WoodWrangler's Avatar
    Nickname
    Jeremy (40)
    Join Date
    Mar 2006
    Location
    Bradenton, Fl
    Posts
    5,281
    Visit Freq
    1.04 visits/week
    Threads
    572
    Classifieds
    RustFree and you should be good as new
  18. #14
    DQ
    Nickname
    Mike (65)
    Join Date
    Aug 2013
    Location
    Cary, NC
    Posts
    1,830
    Visit Freq
    6.92 visits/week
    Threads
    339
    Classifieds
    Quote Originally Posted by WoodWrangler View Post
    Applied in what fashion?
  19. #15
    Nickname
    Join Date
    Jan 2013
    Location
    Mc Leansville, NC
    Posts
    1,852
    Visit Freq
    3.85 visits/week
    Threads
    70
    Classifieds
    What is it? a Harley? LMBO!
Similar Threads
  1. Latest projects, Film School, Clock Table and Platter table
    By cyclopentadiene in forum General Woodworking
    Last Post: 10-07-2013, 07:36 PM
  2. Replies: 1
    Last Post: 09-16-2011, 08:43 PM
  3. Incra table saw/router table joinery system
    By joec in forum Power Tools and Their Use
    Last Post: 04-12-2011, 11:20 AM
  4. Curly Wormy Maple End Table and Coffee Table
    By blbradford in forum General Woodworking
    Last Post: 01-20-2011, 10:51 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
