Festool (Ad #2)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
  1. #1
    Nickname
    Adam
    Join Date
    Jun 2014
    Location
    Pittsboro, NC
    Posts
    56
    Visit Freq
    1.35 visits/week
    Threads
    Classifieds
    Wonky counter top
    So my wife wanted me to build her a stove top cover. It basically creates an elevated countertop over the stove to add some counter space. I edge glued some of what i believe is fir using some biscuits. After sanding the seams i noticed its not perfectly flat. Its about 1/4 off on one corner.
    I am planning on making a 1 standoff in the shape of a rectangle to elevate it over the stove. My theory is if i go ahead and continue assembly, the whole piece will be wobbly. And the top is too wide for the planer.
    This wood was my grandfathers and i would love to salvage the project if possible. Does anyone have any ideas?
    Sent from my iPhone using Tapatalk Pro
  2. #2
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,532
    Visit Freq
    7.00 visits/week
    Threads
    734
    Classifieds
    Re: Wonky counter top
    Find a friend (lots of us here) with a wide planer or drum sander to take the 1/4 inch off.
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  3. #3
    DQ
    Nickname
    bash (55)
    Join Date
    Apr 2010
    Location
    Apex, NC
    Posts
    198
    Visit Freq
    3.81 visits/week
    Threads
    Classifieds
    When you say 1/4" off in one corner, is it because an edge board is warped, or did you go overboard sanding at that corner when evening seams, or other? If one face is flat, I would make the off corner a back bottom corner and custom fit the standoff to make it level. Not sure this helps as not sure what your panel currently looks like.
  4. #4
    Nickname
    Adam
    Join Date
    Jun 2014
    Location
    Pittsboro, NC
    Posts
    56
    Visit Freq
    1.35 visits/week
    Threads
    Classifieds
    I believe it may be from clamping. I clamped in opposing directions but i guess not well enough. Overall dimensions are 34 20 3/4
  5. #5
    Nickname
    Adam
    Join Date
    Jun 2014
    Location
    Pittsboro, NC
    Posts
    56
    Visit Freq
    1.35 visits/week
    Threads
    Classifieds
    I guess this is more common of an issue with thinner stock. Using regular 2-by stock may not have this much of an issue. This was my first edge glue and biscuit joint by the way
  6. #6
    DQ
    Nickname
    bash (55)
    Join Date
    Apr 2010
    Location
    Apex, NC
    Posts
    198
    Visit Freq
    3.81 visits/week
    Threads
    Classifieds
    Could you fix it by cutting the last two boards off through the glue joint and re-glue? It would cost you a bit of width, but for this application probably not critical. If you do, trim all edges that will see glue again (4 total) by ripping on the table saw, turning the middle board upside down when ripping it's 2 edges. Or if you have a jointer … Then if needed attach cross pieces on bottom to help pull level (perhaps light angle).
    Or do what Mike said.
  7. #7
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,532
    Visit Freq
    7.00 visits/week
    Threads
    734
    Classifieds
    Those two end pieces that are plain sawn may have contributed to the warping. Always look at the grain and try to get all quarter sawn, failing that then alternate the plain and quartered.
    WWFD
  8. #8
    Nickname
    Adam
    Join Date
    Jun 2014
    Location
    Pittsboro, NC
    Posts
    56
    Visit Freq
    1.35 visits/week
    Threads
    Classifieds
    So bash if i understand correctly, i should rip the last two off on the glue joint and rebiscuit it back?
  9. #9
    DQ
    Nickname
    bash (55)
    Join Date
    Apr 2010
    Location
    Apex, NC
    Posts
    198
    Visit Freq
    3.81 visits/week
    Threads
    Classifieds
    If you think cutting them off will let them lay flat again, yes. After that, rip the 4 edges that will glue together one more time. Make sure your middle board is upside down during this process ensuring supplemental angles at your glue joints just in case your saw blade is slightly off 90 degrees.
    If you do not think the boards will lay flat after being ripped off, my suggestion will not help you. It just looks from your pictures that the angle on one of your boards at joint 3-4 'might' not be 90 degrees contributing to the raised corner.
    Others may have better input.
  10. #10
    Nickname
    shawn
    Join Date
    Apr 2017
    Location
    New Bern, NC
    Posts
    41
    Visit Freq
    0.65 visits/week
    Threads
    Classifieds
    It's possible one or more of your boards are twisted slightly. You may have to rip them apart, set them one a flat surface, i.e. table saw top, and check for any teetering. Pass the offending board/boards over jointer to flatten then through planer to get parallel faces, re-square the edges and glue. Otherwise, what Bash said. Making custom legs easiest solution.
    I always check for twist, no matter how little, and face plane. In fact, I'll face plane regardless.
  11. #11
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    919
    Visit Freq
    7.00 visits/week
    Threads
    Classifieds
    I'm with Shawn on this one. I think you need to cut it apart and create a flat face and a square edge to reference from. Power tools or hand tools the same rules for flat, square, and co-planner apply. I like your idea for adding a work surface in your kitchen. I just think you may have jumped ahead of yourself and didn't prepare your materials properly for that glue up. Of course I'm looking at pictures and can't see everything but what I am seeing is twist, which means there is twist in several if not all those pieces. With that said, not all is lost, the piece is salvageable you just need to back up and start again.
    Nothing beats a try but a failure, failure is an opportunity to learn.
    http://graywolfwoodworks.wordpress.com/
  12. #12
    Nickname
    Adam
    Join Date
    Jun 2014
    Location
    Pittsboro, NC
    Posts
    56
    Visit Freq
    1.35 visits/week
    Threads
    Classifieds
    I made all cuts using a table saw, so i had a fairly good 90 degree edge to glue to. I think i may have clamped a little too tight and it twisted or bowed a little. I have a local shop that has a large planner. Do you think that would be the easiest solution?
  13. #13
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    919
    Visit Freq
    7.00 visits/week
    Threads
    Classifieds
    If the shop you're going to has a plane bed that will support that piece like it is now, then you will be ok. If not then the rollers will press it down flat and take off a little wood and it will still be twisted when it comes out the other side.
  14. #14
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,388
    Visit Freq
    6.92 visits/week
    Threads
    637
    Classifieds
    Are pics #1 and 3 of your panel laying over the top of the stove? Is it wobbly as it sits now on that surface? Why don't you simply make the standoff frame as planned and add 1/4" shims to the wonky corner and be done with it? You're overthinking this project so relax, it's just a little added surface area as a counter top.
  15. #15
    Nickname
    Join Date
    Jan 2013
    Location
    Mc Leansville, NC
    Posts
    1,840
    Visit Freq
    4.19 visits/week
    Threads
    70
    Classifieds
    Quote Originally Posted by The A Train View Post
    I hate to be a kiljoy here, but this sounds like a terrible idea from a safety/ fire standpoint.
Similar Threads
  1. Why did my planed counter top cup?
    By lostwarden in forum "How To" Forum
    Last Post: 06-27-2015, 07:43 AM
  2. Counter top gloat
    By Trent Mason in forum Workshop Discussion
    Last Post: 12-01-2009, 07:53 AM
  3. Counter tops
    By Gotcha6 in forum Found for Sale/Hot Deals
    Last Post: 04-22-2009, 09:28 PM
  4. Counter top installer
    By Kicbak in forum DIY- Home improvement
    Last Post: 06-03-2008, 10:59 AM
  5. Kitchen Counter Laminate
    By John Reeves in forum Where Can I Find, Buy or Sell
    Last Post: 10-30-2006, 09:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
