West Penn Hardwoods (Ad 2)
Results 1 to 12 of 12
  1. #1
    DQ
    Nickname
    Mike (64)
    Join Date
    Aug 2013
    Location
    Cary, NC
    Posts
    1,523
    Visit Freq
    6.04 visits/week
    Threads
    295
    Classifieds
    Dado Clean-out Bit
    Is there any reason not to use this bit to create shallow dadoes? My collection of (sharp) router bits is somewhat slim at the moment, but I already have one of these that I've never used. The bearing would cause it to work well with my router dado jig I'm trying to make.
    Attached Images Attached Images
  2. #2
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,377
    Visit Freq
    7.00 visits/week
    Threads
    727
    Classifieds
    Re: Dado Clean-out Bit
    Looks like that is 1/2"? is that the size of the wood to be inserted or will you make two passes?
    If two be sure to cut in the correct direction each time.
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  3. #3
    Papa Red Senior User
    DQ
    red's Avatar
    Nickname
    Red
    Join Date
    Nov 2009
    Location
    Denver, NC
    Posts
    2,310
    Visit Freq
    4.00 visits/week
    Threads
    Classifieds
    It will work fine.
    Red
    Red
  4. #4
    DQ
    Nickname
    Join Date
    May 2008
    Location
    Lexington, SC
    Posts
    1,379
    Visit Freq
    4.62 visits/week
    Threads
    19
    Classifieds
    I agree with Red. I have a similar router bit I use to make shallow dados with a router jig. One side of the jig moves so you can set it to the piece that will go into the dado. Works well. The dados I make with this are 1/8 or less deep. Their main purpose is to align the parts during assembly. I would use a more robust bit to make a deeper dado but for a shallow one, that sort of bit is what I use.
  5. #5
    DQ
    Nickname
    Mike (64)
    Join Date
    Aug 2013
    Location
    Cary, NC
    Posts
    1,523
    Visit Freq
    6.04 visits/week
    Threads
    295
    Classifieds
    Mike, it will be two passes with cuts in the right direction.
    Thanks.
  6. #6
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,377
    Visit Freq
    7.00 visits/week
    Threads
    727
    Classifieds
    I always mark my jig so I cut into the cut, when I first started using a router I didn't mark my jig and accidentally made a climb cut and the router got away from me.
    WWFD
  7. #7
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,129
    Visit Freq
    6.92 visits/week
    Threads
    617
    Classifieds
    Why don't you make dados by cross cutting the board with a dado blade and your new SawStop? Just curious but the router bit and your jig should work too.
    https://www.amanatool.com/45460-s-ca...l?ff=1&fp=8395
  8. #8
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,377
    Visit Freq
    7.00 visits/week
    Threads
    727
    Classifieds
    Long boards are a little hard to handle and can slip ruining the dado. Really need a sliding table for that. A sled will work if it is pretty wide.
    WWFD
  9. #9
    DQ
    Nickname
    Join Date
    May 2008
    Location
    Lexington, SC
    Posts
    1,379
    Visit Freq
    4.62 visits/week
    Threads
    19
    Classifieds
    I've found a jig for my tracksaw track to be a great way to make longer dados. It holds my PC690 router well, even has micro adjustment, and it is nice because, just like the tracksaw, the router cannot deviate from the line of the track. If you clamp the track, the router is going to follow the line. I guess if you have an automatic feeder for your table saw it might do the same but I don't and having the material move slightly away from the fence is a risk. My track saw and the jig were made by DeWalt.
    Climb cutting is sometimes a good thing but it can make control difficult. It is not a way to cut away much wood. A shallow climb cut pass can minimize fuzziness along the cut line. It it happens unexpectedly, it is not hard to ding your jig or workpiece.
    My bit like that has a 1/4 shank and that is one of the reasons I take only shallow cuts with it. Even a good collet can slip on a 1/4 shank bit. So I do not try to take deep cuts. A lot of the time the dado is part of a glued and screwed joint and I want adequate material at the bottom of the dado for the screw to go through.
  10. #10
    DQ
    Nickname
    Mike (64)
    Join Date
    Aug 2013
    Location
    Cary, NC
    Posts
    1,523
    Visit Freq
    6.04 visits/week
    Threads
    295
    Classifieds
    I was milling a slot in a piece of plywood last night using my router table and fence. Part of the cut requires doing a climb cut. Sure enough, the board moved a little, so the slot has some variability to it. It doesn't matter in this case since it's just a utility clip idea that I decided to use. The next time I have to do a climb cut, I will hopefully use some sort of guide that keeps the board from moving away from the fence.
  11. #11
    Staff Advisor
    DQ
    Joe Scharle's Avatar
    Nickname
    Joe (75)
    Join Date
    Sep 2005
    Location
    New Bern, NC
    Posts
    5,539
    Visit Freq
    6.19 visits/week
    Threads
    685
    Classifieds
    Mike, I use a dado cleanout bit mostly for hinge mortises. They work nicely if the hinge corners are 1/2 " radia. However, I setup my large dado jigs to use 3/8" or 1/2" spiral downcut bits. Downcut spiral leave a crisp entry edge. And I always use the jig that will require at least 2 passes for the desired dado width. So if I had only one jig, it would be the one that uses a 3/8" bit.
    The face of my jigs show which router, which bit and which directions to push the router. These pics may give you some ideas...
    Always be yourself because the people that matter don't mind, and the ones who mind, don't matter.
  12. The following 3 users say Thank You to Joe Scharle :
  13. #12
    Nickname
    DrBob
    Join Date
    May 2014
    Location
    Baldwin, FL
    Posts
    675
    Visit Freq
    3.62 visits/week
    Threads
    60
    Classifieds
    You can use it, just be ware of tear out.
    This can be alleviated by pre-scoring the dado with a sharp knife.
  14. The following user says Thank You to Rwe2156 for this useful post:
Similar Threads
  1. Shop is CLEAN
    By CrealBilly in forum General Woodworking
    Last Post: 09-28-2012, 09:03 AM
  2. Another scofflaw comes clean.
    By jazzflute in forum Who We Are
    Last Post: 03-09-2012, 04:18 PM
  3. Keeping' it clean (the air)
    By CarvedTones in forum Safety & Health
    Last Post: 08-20-2008, 06:38 PM
  4. Clean-up CA Glue?
    By WoodWrangler in forum General Woodworking
    Last Post: 11-20-2007, 05:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
