Klingspor's Woodworking Shop (Festool) Ad #2
Results 1 to 13 of 13
  1. #1
    DQ
    tdukes's Avatar
    Nickname
    Eddie
    Join Date
    Nov 2017
    Location
    Lexington, SC
    Posts
    508
    Visit Freq
    0.23 visits/week
    Threads
    92
    Classifieds
    Cast iron cleaning
    Hello,
    I'm sure some, if not most, have done this before so maybe it will help someone that hasn't.
    It has been a while since I cleaned and polished my table saw's cast iron top. Glue, sweat, humidity really takes it's toll.
    Got out my ROS sander with 320 grit and WD-40 and went to work. Probably should have started with 220 grit, then 320.
    Cleaned the top with mineral spirits after the sanding and applied a coat of paste wax. Have to say, it has never been this slick when it was new.
  2. The following user says Thank You to tdukes for this useful post:
  3. #2
    DQ
    sawman101's Avatar
    Nickname
    Bruce Swanson
    Join Date
    Feb 2009
    Location
    Newton, NC
    Posts
    3,340
    Visit Freq
    6.73 visits/week
    Threads
    215
    Classifieds
    Re: Cast iron cleaning
    I like to keep my tables shiny and slick. I often use a product such as Top Saver along with a 3M green scouring pad. If it is rusted and pitted, I'll use 180 in my ROS and then the 3M pad, followed by a clean rag, then the paste wax, if the top cleaning agent isn't a final surface treatment.
    Experience is a hard teacher; she gives the test first, and the lesson later.
  4. The following 2 users say Thank You to sawman101 :
  5. #3
    Staff Advisor
    DQ
    Joe Scharle's Avatar
    Nickname
    Joe (76)
    Join Date
    Sep 2005
    Location
    New Bern, NC
    Posts
    5,568
    Visit Freq
    1.81 visits/week
    Threads
    686
    Classifieds
    I make a slurry with WD-40 and Barkeepers Friend and apply using scouring pad. Cleanup with mineral spirits.
    Always be yourself because the people that matter don't mind, and the ones who mind, don't matter.
  6. The following 2 users say Thank You to Joe Scharle :
  7. #4
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,833
    Visit Freq
    6.88 visits/week
    Threads
    661
    Classifieds
    Quote Originally Posted by Joe Scharle View Post
    Interesting concoction. Do you use the powder or the semi-liquid cream? It's less abrasive than Comet and Ajax and the primary active ingredient is oxalic acid. What the...?
    https://web.archive.org/web/20101014.../435939-1.html
    https://www.barkeepersfriend.com/abo...y-data-sheets/
  8. The following 2 users say Thank You to Jeff :
  9. #5
    Staff Advisor
    DQ
    Nickname
    Joe (76)
    Join Date
    Sep 2005
    Location
    New Bern, NC
    Posts
    5,568
    Visit Freq
    1.81 visits/week
    Threads
    686
    Classifieds
    I use the regular dry. We have used it for stainless for decades.
  10. The following 4 users say Thank You to Joe Scharle :
  11. #6
    DQ
    Gofor's Avatar
    Nickname
    Join Date
    Mar 2006
    Location
    Goldsboro, NC
    Posts
    3,278
    Visit Freq
    6.69 visits/week
    Threads
    83
    Classifieds
    If you have a hook & loop pad on your ROS, the green abrasive pads will stick to it well enough to put some mechanical action to the above method. I have just been using WD, but add the Barkeeps friend next time it needs a major workover. Thanks
    Practicing at practical woodworking
  12. The following user says Thank You to Gofor for this useful post:
  13. #7
    DQ
    petebucy4638's Avatar
    Nickname
    Pete
    Join Date
    Dec 2009
    Location
    Denver, NC
    Posts
    474
    Visit Freq
    0.12 visits/week
    Threads
    Classifieds
    I have had great luck restoring cast iron tool tops with a random orbit sander. The starting grit depends a lot on the condition of the top. The grit that you finish up with depends on how shiny you want the finished surface to be. I like to finish up with 400 grit, but I have gone as high as 1200 grit. If the rusted areas include a lot of pitting, you would probably want to use something like Evapo-Rust to get into those spots that the sander will not reach. When done sanding, I like to wipe the top down with mineral spirits on a terrycloth or microfiber rag to get rid of any sanding residue, then after the top dries, I spray it down with BoeShield. A lot of woodworkers prefer paste wax to BoeShield because the paste wax does appear to develop a more slick surface.
    Pete
    Quote Originally Posted by tdukes View Post
    Hello,
    Pete - KD4CQZ
  14. The following 2 users say Thank You to petebucy4638 :
  15. #8
    Nickname
    shawn
    Join Date
    Apr 2017
    Location
    New Bern, NC
    Posts
    61
    Visit Freq
    1.00 visits/week
    Threads
    Classifieds
    I just picked up a couple machines that had quite a bit of surface rust on the tops, one of them had a bunch on the base as well. I typically use a ROS but this time I used an angle grinder wit a wire wheel. I must say, It worked great. The wire wheel was somewhat cupped and I ran it flat for most of the cleaning, on edge for tougher stuff. Johnsons paste wax for the finish.
  16. The following user says Thank You to shawn for this useful post:
  17. #9
    Nickname
    DrBob
    Join Date
    May 2014
    Location
    Baldwin, FL
    Posts
    760
    Visit Freq
    3.73 visits/week
    Threads
    Classifieds
    Curious why do so many guys worry about this?
    That being said, I do wash my tractor now and again.......
  18. #10
    Nickname
    Join Date
    Mar 2008
    Location
    Snow Camp, NC
    Posts
    Visit Freq
    0.42 visits/week
    Threads
    Classifieds
    Don;t forget that you can buy a Scotch Brite pad for your belt sander.
    I have used this for rusty tops and for cleaning dried glue off of my cast iron glue up table.
  19. The following user says Thank You to sandfarm for this useful post:
  20. #11
    Papa Red Senior User
    DQ
    red's Avatar
    Nickname
    Red
    Join Date
    Nov 2009
    Location
    Denver, NC
    Posts
    2,356
    Visit Freq
    5.08 visits/week
    Threads
    50
    Classifieds
    Quote Originally Posted by Rwe2156 View Post
    I keep my equipment looking like new because it just makes me feel good when I see it. It also shows clients that I take care of my stuff.
    Red
    Red
  21. The following user says Thank You to red for this useful post:
  22. #12
    DQ
    Gofor's Avatar
    Nickname
    Join Date
    Mar 2006
    Location
    Goldsboro, NC
    Posts
    3,278
    Visit Freq
    6.69 visits/week
    Threads
    83
    Classifieds
    I keep the cast iron tables clean on the table saw, band saw and drill press clean of surface rust and waxed to allow the wood to move smoothly and easily across it. I don't much worry about the ascetics. Also keeps the surface rust from transferring to the wood. In the case of oak, iron oxide can deeply stain it black.
    Same goes for my hand planes.
  23. The following user says Thank You to Gofor for this useful post:
  24. #13
    DQ
    Nickname
    Join Date
    Jan 2011
    Location
    Lowesville, NC
    Posts
    177
    Visit Freq
    6.54 visits/week
    Threads
    Classifieds
    If I don't keep the base plate of my planer waxed the wood will stick and I get gouges.
  25. The following user says Thank You to Brantnative for this useful post:
Similar Threads
  1. Cast Iron Extension Table
    By JCraig in forum Where Can I Find, Buy or Sell
    Last Post: 01-08-2012, 03:02 PM
  2. Cast Iron Table
    By jhreed in forum General Woodworking
    Last Post: 05-15-2009, 06:49 PM
  3. Cleaning "Experienced" Cast Iron
    By Bigdog72 in forum Power Tools and Their Use
    Last Post: 10-16-2008, 07:02 AM
  4. Casters & Cast Iron
    By WoodWrangler in forum General Woodworking
    Last Post: 09-29-2008, 03:54 PM
  5. What do you use on cast iron...
    By pslamp32 in forum General Woodworking
    Last Post: 03-21-2007, 08:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
