West Penn Hardwoods (Ad 1)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 30
  1. #1
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,797
    Visit Freq
    6.92 visits/week
    Threads
    753
    Classifieds
    Trend sharpening kit
    https://www.woodworkingshop.com/product/td20065/
    I finally got to try out my trend sharpening kit from Klingspor's Woodworking Shop and I am a convert.
    I have used and recommended DMT diamond stones for that last 15 years, that is what I knew and all I
    had experience with. Well, I had tried a couple other's but they were no where near as good.
    I was reluctant to try Trend even though several of my friend's use them and like them.
    For a while they only had 300 and 1000 grit and I didn't think that was enough.
    So I got this kit with two double sided stones, a leather strop, stropping compound, honing fluid for the stone, and a neat case to keep it all in one place. The stones are double sided with 180/600 grit on one stone and 300/1000 grit on the other. I think the perfect progression from extra coarse to extra fine.
    There is a slight learning curve with these stones, the instructions included with the kit recommend a break in period of light use to even the surface. I found this to be particularly needed on the 1000 grit which seemed very coarse until it was broken in. Then it performed much better than my DMT.
    Overall I am very pleased with this kit and it contains everything needed to sharpen most of the hand tools used in woodworking.
    The only thing I added is a couple of these stone holders to get the stones up off the bench a little.
    https://www.woodworkingshop.com/product/bh19048/
    As you can see I modified my case to hold the stones with the holders in place.
    Attached Images Attached Images
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  2. #2
    Nickname
    DrBob
    Join Date
    May 2014
    Location
    Baldwin, FL
    Posts
    760
    Visit Freq
    3.73 visits/week
    Threads
    Classifieds
    Re: Trend sharpening kit
    I've been thinking about the Trends appreciate the review. Are you stopping at 1000?
    I've also been using DMT, also, both DiaSharp and the Duo mesh plates (not super happy with the mesh).
    I found these which look identical to Trend but haven't gotten one yet.
  3. The following 2 users say Thank You to Rwe2156 :
  4. #3
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,797
    Visit Freq
    6.92 visits/week
    Threads
    753
    Classifieds
    No, I stop after the leather strop.
    WWFD
  5. The following user says Thank You to Mike Davis for this useful post:
  6. #4
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    1,035
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    I got to try Mikes Trend kit while at Bills and at the sharpening workshop. I have the DMT stones and I like then very much so I'm not likely to drop one for the other. However, if I was starting from scratch or are moving away from water, or oil stones I would totally recommend the trend kit Mike has. These stones cut fast and are easy to maintain. You'll not likely to find another system that will handle old steels and the newer steel combinations that are being sold.
    Nothing beats a try but a failure, failure is an opportunity to learn.
    http://graywolfwoodworks.wordpress.com/
  7. The following user says Thank You to Graywolf for this useful post:
  8. #5
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,954
    Visit Freq
    6.85 visits/week
    Threads
    532
    Classifieds
    I've used the Trend Diamonds for a while now and also prefer them to any others. I also have some of their diamond files and find them extremely useful. And it is good that you can purchase their entire line from Klingspor.
    I don't believe in Astrology. I'm a Sagittarius and we're skeptical.
    "May the grain be with you" - Roy Underhill
  9. The following user says Thank You to KenOfCary for this useful post:
  10. #6
    Board of Directors
    Secretary
    DQ
    Hmerkle's Avatar
    Nickname
    Join Date
    Jul 2013
    Location
    Greer, SC
    Posts
    5,637
    Visit Freq
    2.58 visits/week
    Threads
    317
    Classifieds
    Mike,
    What led you to purchase the Trend kit?
    Have you ever used Shapton "stones"?
    Curious on the Trend vs. Shapton...
    People are amazed as a shaving rises from the throat of a plane as if it’s a spell plucked from a sorcerer’s hand – Paul Sellers
  11. The following user says Thank You to Hmerkle for this useful post:
  12. #7
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,797
    Visit Freq
    6.92 visits/week
    Threads
    753
    Classifieds
    Since I demo and teach at Klingspor sometimes I feel like I should at least try their products. The kit made sense since it has everything needed to sharpen plane blades and chisels in one package. And Ken had been telling for several years that they are better than DMT. I have watched the price steadily increase and the quality go down so it seemed like time to switch.
    Yes, I have a set of Shapton glass stones. A little less expensive since half the thickness is glass compared to solid stone.
    The Shaptons are very fine I have up to 16,000 grit and have used them only a few times. In my opinion they are too slow, messy since they have to be sprayed with water every few minutes, and excessively fine. I can get back to work quicker with a very serviceable edge using diamonds and a leather strop.
    People take sharpening too far or they don't understand the basic principle. I guess once they learn what sharp is they want to go further and further into that hole. I just want to get a sharp edge and get back to work.
    WWFD
  13. The following 3 users say Thank You to Mike Davis :
  14. #8
    Administrator Corporate Member
    DQ
    MarkE's Avatar
    Nickname
    Mark (64)
    Join Date
    Dec 2009
    Location
    Willow Spring, NC
    Posts
    4,450
    Visit Freq
    6.88 visits/week
    Threads
    293
    Classifieds
    Quote Originally Posted by Mike Davis View Post
    100% agree with this!!!!
    “I know you believe you understand what you think I said, but I am not sure you realize that what you heard is not what I meant.”
  15. The following user says Thank You to MarkE for this useful post:
  16. #9
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,797
    Visit Freq
    6.92 visits/week
    Threads
    753
    Classifieds
    Right?! It's not something I'm only going to do once in my life.
    WWFD
  17. The following user says Thank You to Mike Davis for this useful post:
  18. #10
    Board of Directors
    Secretary
    DQ
    Hmerkle's Avatar
    Nickname
    Join Date
    Jul 2013
    Location
    Greer, SC
    Posts
    5,637
    Visit Freq
    2.58 visits/week
    Threads
    317
    Classifieds
    Mike,
    It is really funny that you posted this today as I received the Rob Cosman newsletter and there is a link to his sharpening:
    https://www.youtube.com/watch?v=ZLobikOSftY
    (Just another method) but he states the same thing - if it is not quick and efficient, "you" won't do it and hand tool woodworking REQUIRES sharp tools! I am not the first to state this, but "Many people don't know what "sharp" is... once they see it and understand what they are working toward it becomes much easier...
    in another video he promotes sharpening using a 16,000 grit stone - but I notice he doesn't hone, and I think that is the difference in your (Mike Davis' sharpening teaching and a shout out to Paul Sellers - who (I think) is the "Someone who says you don't need to sharpen your plane beyond 300 grit"
    But he demonstrates the "ruler trick" I don't use it, but may try it one day soon. It seems like rather than creating a "Bevel" or "back bevel" you CAN use to simply remove the wire edge and ensure the bevel plane and the "flat back" of the blade are coming to a single point.
    https://www.youtube.com/watch?v=wWX2ursXfqw
  19. The following user says Thank You to Hmerkle for this useful post:
  20. #11
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,797
    Visit Freq
    6.92 visits/week
    Threads
    753
    Classifieds
    You have to realize he is working with brand new high quality blades and he sharpens often to avoid having to go back to the coarser stones. 1000 and 16,000 as a pair make sense. As to the ruler it is no trick. Simply sharpening less material by making a back bevel on the blade. Sharpen less area and it goes more quickly. As to the 30 seconds... maybe 30 on each side and on each stone, so 2 minutes of actual sharpening but look at the clock almost 4 minutes total time away from planing. That is reasonable and I would say normal.
    WWFD
  21. The following user says Thank You to Mike Davis for this useful post:
  22. #12
    DQ
    MarkE's Avatar
    Nickname
    Mark (64)
    Join Date
    Dec 2009
    Location
    Willow Spring, NC
    Posts
    4,450
    Visit Freq
    6.88 visits/week
    Threads
    293
    Classifieds
    The (ruler trick) back bevel works well if there is some very light pitting on the back side of the iron. Only time I use it. It saves a lot of time (and length of the iron) due to not having to grind past the back side pitting.
  23. The following user says Thank You to MarkE for this useful post:
  24. #13
    User Pop Golden's Avatar
    Nickname
    Pop (78)
    Join Date
    Jul 2011
    Location
    Charlotte, NC
    Posts
    930
    Visit Freq
    4.31 visits/week
    Threads
    Classifieds
    Mike, Looked at the kit. What's the sand block used for?
    Pop
  25. #14
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,797
    Visit Freq
    6.92 visits/week
    Threads
    753
    Classifieds
    In mine? That’s not part of the kit, I was cleaning an old plane.
    WWFD
  26. #15
    DQ
    Rushton's Avatar
    Nickname
    Rush
    Join Date
    Mar 2017
    Location
    Richmond, VA
    Posts
    107
    Visit Freq
    0.15 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Hmerkle View Post
    Not quite. Paul Sellers has said that 300 grit can get to "carpenter's sharp" (his phrase), but for joinery work, he recommends sharpening through the grits and finishing with a strop loaded with buffing compound.
Similar Threads
  1. Hot deal on Trend Air Pro
    By ScottM in forum Found for Sale/Hot Deals
    Last Post: 07-19-2013, 10:54 AM
  2. Trend T4 at Peachtree
    By Joe Scharle in forum Found for Sale/Hot Deals
    Last Post: 03-27-2012, 10:01 AM
  3. Tried The Trend Pro Butttttttt!! HELP !
    By Flute Maker in forum Woodturning
    Last Post: 08-14-2010, 10:53 PM
  4. Trend Airshield Pro $299
    By WoodWrangler in forum Found for Sale/Hot Deals
    Last Post: 08-18-2009, 07:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
