Klingspor's Woodworking Shop (Festool) Ad #2
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
  1. #1
    DQ
    Wolfpacker's Avatar
    Nickname
    Brent
    Join Date
    Mar 2010
    Location
    Arden, NC
    Posts
    162
    Visit Freq
    1.69 visits/week
    Threads
    Classifieds
    Need source of hardwood flooring in WNC
    I am looking for hardwood flooring, most likely we'll go with pre-finished. Other than the local flooring stores, Lowes, Home Depot, Scroungers Paradise, does anyone know of other sources in the Asheville/Hendersonville area ? We will need somewhere in the 1900-2000 sq ft range....still need to measure. Trying to decide if I want to tackle putting it down myself or hire someone with experience. Thoughts ??
  2. #2
    Administrator Corporate Member
    DQ
    bowman's Avatar
    Nickname
    Neal (58)
    Join Date
    Apr 2017
    Location
    King, NC
    Posts
    824
    Visit Freq
    7.88 visits/week
    Threads
    Classifieds
    Re: Need source of hardwood flooring in WNC
    Check Sams Club and Costco, they offer free shipping to the warehouse in most cases.
  3. #3
    DQ
    Nickname
    Join Date
    May 2008
    Location
    Lexington, SC
    Posts
    1,571
    Visit Freq
    4.81 visits/week
    Threads
    Classifieds
    Do you have Southeastern Salvage in your area? We got about 600Ft2 of hickory from them. 2000 ft2 is a lot. I also did a decent sized area in a smaller house, maybe 500 ft2, with thin but solid oak. I had helpers with the thin stuff and did the thicker stuff by myself. The hickory boxes were 80 lbs apiece and the area was on the second floor. Both to carry materials and for other reasons a helper is very advisable for 2,000 ft2. When I was doing the thin stuff, the helper couldn't run the saw but was a big help finding pieces the size I needed to minimize cutting. If the helper can run the saw while you nail - and/or nail while you cut, it will go better. 2,000 feet for me would probably wipe out most of a week.
    My HF nailer for 3/4 material is leaking air right now but still works. It did the 600 ft or so I did plus another guys project so far. I should fix the leak but used it for about 50 ft2 recently and it worked fine. It is easily worth the $100 it costs.
    Staples cost less but hold better. I had to take up old flooring put down with nails and with staples. The flooring nailed down was often still usable but not the flooring stapled down. Either one holds well enough, however. The flooring I put down had been there for decades and in one case had ceramic tile installed on top. It didn't move enough to crack the tile despite the nails. But that is very bad practice, I would not and did not do it.
    I like the instant gratification of putting down pre-finished flooring. I would have an extra blade for your saw if you do this - the finish they use has aluminum oxide, the same material as sandpaper, in it. The thin stuff requires you to be down on the floor but you can do the 3/4 standing most of the time. But it's still a bit hard on the body working hunched over. But it can go pretty quick when you don't have to stop and cut.
  4. #4
    Nickname
    Join Date
    May 2010
    Location
    Fletcher, NC
    Posts
    Visit Freq
    3.77 visits/week
    Threads
    Classifieds
    There is a place at 195 Johnston blvd Asheville. Its close to Patton and Haywood blvd. Used to be called "Blue Ridge Surplus" but now the website looks like its called "Pops surplus" When I was building my house several years ago they had a BIG room of just pre finished and unfinished hardwood flooring, but again that was several years ago. Look them up on the net, they might be a source.
  5. #5
    DQ
    Wolfpacker's Avatar
    Nickname
    Brent
    Join Date
    Mar 2010
    Location
    Arden, NC
    Posts
    162
    Visit Freq
    1.69 visits/week
    Threads
    Classifieds
    Good info guys. Don't think there is a Southeastern Salvage in this area...looks like Nashville, TN is the closest one. I have been to Blue Ridge Surplus before and knew it had changed names, but had forgot about it....thanks for the reminder. I didn't know that Sams or Costco carried hardwood flooring, but will go look. Don't have a membership, but can get one if it's worth it. I have a couple of guys that have put down flooring before and will get one of them to help me and get it started. We'll likely swap off cutting and nailing/stapling. This is a empty house we are buying, so now's the right time to do it all and get it right.
  6. #6
    Staff Advisor
    DQ
    McRabbet's Avatar
    Nickname
    Rob (76)
    Join Date
    Nov 2005
    Location
    Hendersonville, NC
    Posts
    8,880
    Visit Freq
    6.81 visits/week
    Threads
    175
    Classifieds
    Brent,
    You might want to try Lumber Liquidators on Airport Road in Arden, just around the corner from Klingspor's Woodworking Shop.
    Every day brings a new adventure -- it is great to be retired!
  7. #7
    DQ
    bowman's Avatar
    Nickname
    Neal (58)
    Join Date
    Apr 2017
    Location
    King, NC
    Posts
    824
    Visit Freq
    7.88 visits/week
    Threads
    Classifieds
    Quote Originally Posted by bowman View Post
    This is laminate, not actual hardwood. I misread the first post. Apologies.
  8. #8
    DQ
    Wolfpacker's Avatar
    Nickname
    Brent
    Join Date
    Mar 2010
    Location
    Arden, NC
    Posts
    162
    Visit Freq
    1.69 visits/week
    Threads
    Classifieds
    Quote Originally Posted by McRabbet View Post
    Brent,
    I was wondering what the quality level of their flooring is. Can anyone say for sure ? Is it from China ?
  9. #9
    Staff Advisor
    DQ
    McRabbet's Avatar
    Nickname
    Rob (76)
    Join Date
    Nov 2005
    Location
    Hendersonville, NC
    Posts
    8,880
    Visit Freq
    6.81 visits/week
    Threads
    175
    Classifieds
    Quote Originally Posted by Wolfpacker View Post
    I believe their laminate flooring is all from Asia, but you will need to check the pricing and packaging of their hardwood flooring for quality and point of origin. I know they carry Bellawood, which is usually prefinished and may be more expensive than you want to spend. Check them out and be sure to check Scrounger's Paradise as well.
  10. #10
    DQ
    Wolfpacker's Avatar
    Nickname
    Brent
    Join Date
    Mar 2010
    Location
    Arden, NC
    Posts
    162
    Visit Freq
    1.69 visits/week
    Threads
    Classifieds
    Scrounger's seems to only have exotic hardwood flooring. We're red oak folks and they don't have much to choose from when you need 2000 sq ft.
  11. #11
    Nickname
    Join Date
    Jun 2018
    Location
    Cleveland, NC
    Posts
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Gennett Lumber Co. in Asheville......100 year old multi-generation owners....specializing in flooring....www.gennettlumber.com... Farther east in Statesville, Conley Millworks, Bill Conley specializes in moulding and can make custom floors of various widths and lengths...no website or computer...old school craftsman..704-872-0819
  12. The following user says Thank You to Steve.Twiford for this useful post:
  13. #12
    DQ
    gator's Avatar
    Nickname
    George (79)
    Join Date
    Jul 2005
    Location
    Oxford, NC
    Posts
    1,879
    Visit Freq
    6.88 visits/week
    Threads
    155
    Classifieds
    The Hardwood Store of NC in Gibsonville sells flooring. They are a sponsor of NCWW and offer a discount to members. A little far from you but with the discount and buying 2000 ft it may be worth the trip. In fact, at 2000 ft they may offer an additional discount. Worth a phone call to them at the least.
    George
    2B1ASK1
  14. The following user says Thank You to gator for this useful post:
  15. #13
    DQ
    Wolfpacker's Avatar
    Nickname
    Brent
    Join Date
    Mar 2010
    Location
    Arden, NC
    Posts
    162
    Visit Freq
    1.69 visits/week
    Threads
    Classifieds
    Quote Originally Posted by gator View Post
    George
    Finally got around to calling the Hardwood Store. They don't offer discounts on the flooring, just lumber, but he said they would try to do something if I ordered from them. Asheville Hardwood has the best price so far @ $3.45/sq ft for Grade 1 red oak.
    Here are the prices from the Hardwood Store for 3.25" flooring.
    White Oak $4.08/sf
    Red Oak $3.72/sf
    Hickory $3.76/sf
  16. #14
    Nickname
    Join Date
    Jan 2013
    Location
    Arcadia, NC
    Posts
    1,896
    Visit Freq
    3.58 visits/week
    Threads
    71
    Classifieds
    I cant help with a local source but some food for thought. Do you like the lines you get (beveled edge on most prefinished) ? . If it were me and I was doing an entire empty house, I would go with post finished flooring. First, you wont have to worry about scratching it laying it down and second, once it is layed and you do scratch it after youve finished it, you can exactly match the color and topcoat if you need to. This will invariably happen moving in. Just my $.02
  17. #15
    DQ
    Wolfpacker's Avatar
    Nickname
    Brent
    Join Date
    Mar 2010
    Location
    Arden, NC
    Posts
    162
    Visit Freq
    1.69 visits/week
    Threads
    Classifieds
    Quote Originally Posted by chris_goris View Post
    I prefer to have unfinished flooring installed since we can do it before moving in, but the wife likes the pre-finished as it will take less time and make less dust. I personally don't like the look of pre-finished with the beveled edges, but I could have lived with it had we found a house with it already installed. I know the finish on pre-finished is typically more durable than post finish, but I think it tends to be more "shiny" also, maybe not. Some brands of pre-finished supposedly have smaller bevels and thus don't show the lines as much, but until it's down on the floor, I don't think you can be sure of that.
    I would try and set up some blower fans to exhaust air out of windows during the installation to try and cut down on the dust left in the house. There is a whole house attic fan in the home, but I wouldn't want to fill up the attic with sawdust !!
Similar Threads
  1. Does anyone here make any hardwood flooring.
    By steviegwood in forum Where Can I Find, Buy or Sell
    Last Post: 02-22-2013, 11:01 PM
  2. hardwood flooring
    By taandctran in forum Where Can I Find, Buy or Sell
    Last Post: 11-20-2009, 04:48 PM
  3. Hardwood flooring
    By kenger22 in forum General Woodworking
    Last Post: 03-04-2009, 10:35 AM
  4. Hardwood Flooring
    By Jeff in forum Where Can I Find, Buy or Sell
    Last Post: 06-11-2008, 09:29 AM
  5. Mill Hardwood Flooring? or Buy it?
    By huckster in forum General Woodworking
    Last Post: 06-01-2007, 10:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
