West Penn Hardwoods (Ad 2)
Results 1 to 10 of 10
  1. #1
    Nickname
    tom
    Join Date
    Oct 2009
    Location
    Clayton, NC
    Posts
    220
    Visit Freq
    6.81 visits/week
    Threads
    Classifieds
    When did paint get so expensive?
    I need to paint a few things and when i got the old can out it looked horrible so I thought I'd just run over to Sherwin Williams and pick up a gallon. I asked for a recommendation to paint a small bench, a couple of wood rocking chairs and a shed door. He said, with a big smile, the really good stuff is what you need and then with a frown he said you could just go with house paint. 80 bucks for the good stuff and 60 for house paint! When did that happen? I know it's been awhile since I had to buy a gallon of paint but 80 dollars a gallon! I guess it's great quality and expensive. I'm looking for reasonable quality and reasonable price. White, semi gloss, probably latex - any recommendations? The bench and chairs will be on a covered porch and I will be using a brush.
  2. #2
    DQ
    Nickname
    Daniel
    Join Date
    Apr 2015
    Location
    Clayton, NC
    Posts
    806
    Visit Freq
    5.96 visits/week
    Threads
    52
    Classifieds
    Re: When did paint get so expensive?
    Quote Originally Posted by Tom from Clayton View Post
    Unless you have a coupon or are a contractor, SW prices are crazy. They regularly run 30 to 40% off coupons, thats the only time I buy from them, unless I can buy under a contractors account. BORG prices aren't much better.
  3. #3
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,711
    Visit Freq
    6.88 visits/week
    Threads
    654
    Classifieds
    Yes, crazy prices! I guess you want to use an exterior latex enamel for your projects even on a covered porch area. Interior latex enamel paints are cheaper but they don't have to be made to withstand the everyday changes in heat and humidity. Your call for your dollars.
    https://www.sherwin-williams.com/hom...e:&pageSize:9&
  4. #4
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,722
    Visit Freq
    6.96 visits/week
    Threads
    749
    Classifieds
    The short answer to your question is... When they took the lead out. It has been steadily increasing since then.
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  5. The following user says Thank You to Mike Davis for this useful post:
  6. #5
    DQ
    Gofor's Avatar
    Nickname
    Join Date
    Mar 2006
    Location
    Goldsboro, NC
    Posts
    3,253
    Visit Freq
    6.65 visits/week
    Threads
    83
    Classifieds
    Valspar exterior at Lowe's is about $40/gal. It is very good paint when using two full coats. Not cheap,but I have found it every bit as durable as SW at about 1/2 the $$.
    Practicing at practical woodworking
  7. The following user says Thank You to Gofor for this useful post:
  8. #6
    Board of Directors
    Events Director
    DQ
    Berta's Avatar
    Nickname
    Roberta
    Join Date
    Oct 2008
    Location
    Cameron, NC
    Posts
    3,211
    Visit Freq
    6.08 visits/week
    Threads
    293
    Classifieds
    I also use the Valspar,from Lowe’s. They just had a $10 rebate per gallon!
    Berta
  9. The following user says Thank You to Berta for this useful post:
  10. #7
    DQ
    Stuart Kent's Avatar
    Nickname
    Stuart
    Join Date
    Sep 2012
    Location
    Ayden, NC
    Posts
    511
    Visit Freq
    2.85 visits/week
    Threads
    Classifieds
    have you talked to the folks at Wurth about what options they have? I buy some products from them often for less than SW and they are higher quality.
    Stuart Kent
    Founding Director of the North Carolina Furniture School
    Robust, Rikon, Oneida, Harvey, & Easy Wood Tools Dealer
    503 Second St, Ayden, NC 28513
    252-916-8226
    http://ncfurnitureschool.com/
    https://twitter.com/@tweetncfs
    https://www.facebook.com/northcarolinafurnitureschool
  11. #8
    DQ
    Nickname
    Join Date
    May 2008
    Location
    Lexington, SC
    Posts
    1,541
    Visit Freq
    5.04 visits/week
    Threads
    Classifieds
    The limited areas of my house exterior that are painted were painted with a mid-grade SW paint in 2013 right before we bought it. I know because they left part of a gallon. The largest surface is two sides of clapboard siding on the dining room. It was peeling badly in spots this spring so I sanded to bare wood, primed, and painted with the best Behr exterior paint, tinted to match the SW color. It was $50 for the gallon. In part of the area, I put a coat of the SW paint on first to use it up. The Behr was thicker and seemed stickier. We'll see how it holds up.
    I believe Consumer Reports rates Behr exterior paint higher than Lowe's and SW. I like my local SW store, it is well stocked with good items, but I hate their prices. Most SW paint is at least OK but it is heavily tilted to what contractors want. The interior primer, for instance, goes on easily and is easily sanded. But if you use it on softwood, as the contractor that built my former house did, all the knots bleed through. I tried to get him to use Kilz and he said the painting contractor wanted some huge premium. So I had to deal with the bleed through later. I should have just paid the premium. On drywall it is fine but on wood it is not. Kilz total one goes on almost as easily, doesn't sand well at all, but hides knots. My latest project got a no-bleed spray primer from Hood Industries under Resisthane. That is expensive too but is really durable.
    I think $50/gallon is plenty for really good paint. It still seems very expensive to me. But I don't like to paint and if it lasts longer it is worth a few more dollars. I've repainted my entire interior and now some exterior of the current house. I use Zinseer ceiling paint (the kind that goes on with a pink tint then turns white), Valspar mid or high level interior paint (not much difference but high grade is supposed to be mold resistant so I used it in a bathroom), and Behr Ultra exterior paint. When I prime, I use Kilz total one. Too early to tell about durability but they all go on well and clean up well. I'll probably switch to Behr interior when the current gallons run out (Valspar was the wife's choice).
  12. #9
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,924
    Visit Freq
    6.85 visits/week
    Threads
    530
    Classifieds
    Sign up for Sherwin Williams email list. They send out coupons for 30-40 percent off regularly.
    I don't believe in Astrology. I'm a Sagittarius and we're skeptical.
    "May the grain be with you" - Roy Underhill
  13. #10
    Nickname
    tom
    Join Date
    Oct 2009
    Location
    Clayton, NC
    Posts
    220
    Visit Freq
    6.81 visits/week
    Threads
    Classifieds
    Signed up for the email list. Hope it's not a mistake because they asked for everything except my credit rating. Also found out the 40% sale is this weekend through Monday.
Similar Threads
  1. Paint Stripping, Paint Removal needed for old Kitchen cabinet frame
    By cynthia in forum Where Can I Find, Buy or Sell
    Last Post: 05-10-2016, 07:34 AM
  2. Replies: 4
  3. Replies: 9
    Last Post: 07-31-2015, 02:53 PM
  4. Why is the Tormek so Expensive???
    By Alan in Little Washington in forum Power Tools and Their Use
    Last Post: 01-12-2008, 04:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
