West Penn Hardwoods (Ad 1)
Results 1 to 8 of 8
  1. #1
    Nickname
    Bradley
    Join Date
    Jan 2015
    Location
    Wake Forest, NC
    Posts
    111
    Visit Freq
    3.08 visits/week
    Threads
    19
    Classifieds
    Feed Belt Tracking on Drum Sander
    i have a performax 16-32 i bought used recently. a real good deal but it needs a little tuning. you can see on the right side of the brand new feed belt, it tracks toward the motor side where it gets bunched and wears out that side.
    the provided tracking adjustments don't seem to get the job done. if i get it tight enough to hold the belt snug there isn't enough play to get it to track.
    so i thought i would make the troublesome side larger with tape and get it to taper a little.
    i kept adding and adding tape. still it walks right up the tape and bunches.
    i'm out of ideas. maybe just let it bunch up until finally it stops? not a great solution. anybody run into this?
    Attached Images Attached Images
  2. #2
    Board of Directors
    Development Director
    DQ
    Jeremy Scuteri's Avatar
    Nickname
    Jeremy (37)
    Join Date
    Dec 2010
    Location
    Oak Ridge, NC
    Posts
    3,809
    Visit Freq
    6.04 visits/week
    Threads
    314
    Classifieds
    Re: Feed Belt Tracking on Drum Sander
    Are you making adjustments to both sides? Loosen the right side and tighten the left side. You should be able to make it want to go to the other side and then find the happy setting where it stays in the middle.
  3. #3
    Nickname
    Bradley
    Join Date
    Jan 2015
    Location
    Wake Forest, NC
    Posts
    111
    Visit Freq
    3.08 visits/week
    Threads
    19
    Classifieds
    my process is to adjust both sides until the feed belt lays pretty flat. then i'm making adjustments / expanding the motor side while leaving the open side un-adjusted. i have it really tight on the motor side to try and push it back to the middle / keep it in the middle. it just doesn't feel like its got enough room for expansion in order to do that. even if i have the open side totally loose, it walks toward the motor side.
    i have taken the entire feed belt assembly off this morning to try and fresh approach and see if i can get at the root cause
  4. #4
    DQ
    Skymaster's Avatar
    Nickname
    Jack (78)
    Join Date
    Aug 2009
    Location
    Zebulon, NC
    Posts
    1,886
    Visit Freq
    6.35 visits/week
    Threads
    44
    Classifieds
    If you have the manual read thru the process, it is tricky. If you have tried all you can CALL Jet they have the most awesome customer service you can ask for, dont do anything further until you call.
  5. #5
    User Pop Golden's Avatar
    Nickname
    Pop (78)
    Join Date
    Jul 2011
    Location
    Charlotte, NC
    Posts
    918
    Visit Freq
    4.38 visits/week
    Threads
    Classifieds
    Several years ago when I did the set-up on my new 16-32 my son used a caliper and adjusted both sides of the belt within a couple of thousands. Haven't touched it again in years.
    Pop
  6. #6
    DQ
    Phil S's Avatar
    Nickname
    Phil Soper (68)
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    4,622
    Visit Freq
    7.65 visits/week
    Threads
    541
    Classifieds
    Back in my days as an equipment service rep where I serviced high-speed paper transports using wide belts, I learned that flat belts would self-center over crowned rollers - rollers that had a larger diameter in the center. If the equipment service documentation and help do not correct the issue, I would add some tape to the center of the roller
    Hope this helps
  7. #7
    Nickname
    Bradley
    Join Date
    Jan 2015
    Location
    Wake Forest, NC
    Posts
    111
    Visit Freq
    3.08 visits/week
    Threads
    19
    Classifieds
    Quote Originally Posted by Phil S View Post
    Hope this helps
    i will try that at my next adjustment. i've got it pretty stable for now. the box housing the electric components for the feed motor has set screws where it attaches to the roller bed. its definitely not an obvious item to tune up but seemed to do the trick. i think it will still walk but i've slowed it down. i'll try centering the tape next time.
  8. #8
    Master of None Corporate Member
    DQ
    CDPeters's Avatar
    Nickname
    Chris (55)
    Join Date
    Oct 2010
    Location
    Windsor, VA
    Posts
    895
    Visit Freq
    1.35 visits/week
    Threads
    Classifieds
    We deal with conveyors of all sorts in my paid job, dealing with side travel is a regular occurrence for us. The very first thing to do is check that the rollers are co-planar horizontally - even a slight twist in the bed will be problematic. If they are not co-planer, you will fight side travel until you're blue in the face with no satisfactory result.
    "Remember - If the women don't find ya handsome, they should at least find ya handy!" - Red Green
    "Always take hold of things by the smooth handle." - Thomas Jefferson
Similar Threads
  1. Wide Planer, Belt Sander or Drum Sander
    By mayszs in forum Where Can I Find, Buy or Sell
    Last Post: 01-25-2016, 08:59 PM
  2. Drum/belt sander on Thursday?
    By eyekode in forum General Woodworking
    Last Post: 06-27-2012, 06:39 PM
  3. Questions about drum sander feed angle.
    By Ben325e in forum Power Tools and Their Use
    Last Post: 06-13-2012, 11:10 AM
  4. Feed direction relative to drum rotation in drum sander
    By BrianInChatham in forum Power Tools and Their Use
    Last Post: 04-05-2011, 12:32 AM
  5. Drum sander feed belt
    By cyclopentadiene in forum Where Can I Find, Buy or Sell
    Last Post: 03-22-2010, 09:12 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
