West Penn Hardwoods (Ad 1)
Results 1 to 12 of 12
  1. #1
    Nickname
    Join Date
    Jul 2017
    Location
    Apex, NC
    Posts
    Visit Freq
    6.31 visits/week
    Threads
    Classifieds
    Delta drill press stop won't stop
    Using the drill press tonite and suddenly the depth stop won't stop. I hear something rolling around and from the diagram it looks like an Allen screw came loose inside. Should be an easy fix but I cannot figure out how to get the cap off/mechanism opened up. I took a pic of the part that needs to come of and did not want to disassemble the whole shaft mechanism before checking to see if anyone has been there done that first. Thanks all.
    model 11-990
    Attached Images Attached Images
  2. #2
    Administrator Corporate Member
    DQ
    ehpoole's Avatar
    Nickname
    Ethan (47)
    Join Date
    Oct 2009
    Location
    Anderson, SC
    Posts
    6,102
    Visit Freq
    6.62 visits/week
    Threads
    207
    Classifieds
    Re: Delta drill press stop won't stop
    I can't speak for your model, but often times breaking down the pinion/depth assembly requires removing the coiled spring pack (something to be very careful of when doing) so that you can then pull the complete pinion gear and shaft assembly clear through (realizing you will need to either lock the quill in place or capture and cushion it as it falls free when the spring tension is removed and the pinion and shaft pulled out of the rack (the rack is part of the quill column) since there will be nothing supporting it against gravity at that point.
    You may be able to find some how-to advice if you search Google and YouTube, or at least find a similar style of drill press and use their breakdown info to at least help advise you as to what to expect, as well as downloading the exploded parts diagram for your specific drill press model, which can be most helpful when it comes to both disassembly and reassembly. There tends to be a lot of copying among many of the drill press models on the market over the years, so odds are reasonably well in your favor of finding something potentially helpful.
    Best of luck!
  3. #3
    Nickname
    Greg
    Join Date
    Jun 2015
    Location
    Raleigh, NC
    Posts
    199
    Visit Freq
    1.88 visits/week
    Threads
    Classifieds
    I did a quick search and found a place that sells parts for delta drill presses -- it has some exploded diagrams and parts lists for a large number of models. This may not give you exact directions, but the exploded diagrams may help understand the mechanism w/o having to disassemble it. I noted it had links to a few videos -- nothing specific for your problem, but might help you locate others.
    https://www.ereplacementparts.com/de...3275_3279.html
    Note: I've never ordered from this site, it just showed up at top of Googles list when I did the search.
  4. The following user says Thank You to JGregJ for this useful post:
  5. #4
    DQ
    Nickname
    Gene
    Join Date
    Oct 2016
    Location
    Winterville, NC
    Posts
    450
    Visit Freq
    6.31 visits/week
    Threads
    85
    Classifieds
    FWIW, I've ordered from ereplacements and have had reasonable service; meaning, I would order from them again.
    YMMV
  6. #5
    Nickname
    Join Date
    Jul 2017
    Location
    Apex, NC
    Posts
    Visit Freq
    6.31 visits/week
    Threads
    Classifieds
    Thanks all. I have the original manual and parts diagram. Have been all over utube & google, and have been to eraplacements (also had good service in the past), and a few other tool sites. So far I have struck out- so I think I am going to take it apart and figure it out.
    If it goes badly, I guess you'll see some used drill press parts for sale next week!
  7. #6
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,718
    Visit Freq
    6.88 visits/week
    Threads
    654
    Classifieds
    Have you called Delta tech support for their advice on your model 11-90.
    I don't use the depth stop on my Craftsman because it never has held the setting. Mark the depth of cut on the side edge of the workpiece and raise the dp table to that depth with the quill extended to full depth and lock the table.
  8. #7
    Board of Directors
    Events Director
    DQ
    Berta's Avatar
    Nickname
    Roberta
    Join Date
    Oct 2008
    Location
    Cameron, NC
    Posts
    3,211
    Visit Freq
    6.04 visits/week
    Threads
    293
    Classifieds
    Quote Originally Posted by Jeff View Post
    I have used hat very same method!
    Berta
  9. #8
    Nickname
    Join Date
    Jul 2017
    Location
    Apex, NC
    Posts
    Visit Freq
    6.31 visits/week
    Threads
    Classifieds
    I had not thought of that - thanks!
  10. #9
    Nickname
    Join Date
    Jul 2017
    Location
    Apex, NC
    Posts
    Visit Freq
    6.31 visits/week
    Threads
    Classifieds
    Ok I took it apart and it was easy - maybe took ten minutes
    Shaft comes out and the hole in the upper right of the circle is lonely
    The offending part was kind enough to fall right on the table. Usually they try to escape under the bench or other hiding places....
    A little loctite and hopefully we're good for another decade or two......
  11. The following 4 users say Thank You to Melinapex :
  12. #10
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,718
    Visit Freq
    6.88 visits/week
    Threads
    654
    Classifieds
    Quote Originally Posted by Melinapex View Post
    Pictures didn't come through. BTW, what was the offending part that fell out of the lonely hole? Gotta be a reason why it simply and suddenly fell out! ?????? It wasn't installed at the factory with LocTite.
    Part #50 (threaded stop pin) in the schematics...
    https://www.ereplacementparts.com/st...crcb2c8u7as7a7
  13. #11
    Nickname
    Join Date
    Jul 2017
    Location
    Apex, NC
    Posts
    Visit Freq
    6.31 visits/week
    Threads
    Classifieds
    Yup that was the part. It must've unscrewed itself over the past 20 or so years I have had this tool, so am not complaining. Now it's in for good.
  14. The following user says Thank You to Melinapex for this useful post:
  15. #12
    Nickname
    Greg
    Join Date
    Jun 2015
    Location
    Raleigh, NC
    Posts
    199
    Visit Freq
    1.88 visits/week
    Threads
    Classifieds
    Happy to see you got it working. I noticed from the pics (and the exploded diagram of the 11-090) that your delta looks a lot like my Craftsman (vintage late 1980's) any know if Sears had delta build their tools back then?
Similar Threads
  1. DIY Drill press depth stop
    By Mr Woodie in forum Power Tools and Their Use
    Last Post: 12-15-2014, 08:30 AM
  2. Drill Press Depth Stop
    By ErnieM in forum Power Tools and Their Use
    Last Post: 11-04-2014, 03:11 PM
  3. Century Drill and Tool 73512 Adjustable Drill Stop, 2 Piece
    By BKind2Anmls in forum Found for Sale/Hot Deals
    Last Post: 03-24-2014, 01:07 PM
  4. Replace drill press return spring (and depth stop)?
    By eyekode in forum Power Tools and Their Use
    Last Post: 03-15-2011, 07:25 PM
  5. Delta bandsaw lower thrust bearing stop
    By sasjzl in forum General Woodworking
    Last Post: 08-19-2009, 12:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
