West Penn Hardwoods (Ad 1)
Results 1 to 12 of 12
Thread: Humidity?
  1. #1
    DQ
    tdukes's Avatar
    Nickname
    Eddie
    Join Date
    Nov 2017
    Location
    Lexington, SC
    Posts
    508
    Visit Freq
    1.35 visits/week
    Threads
    92
    Classifieds
    Humidity?
    Got started on a bathroom wall cabinet a couple days ago made from white oak.
    Made some dados and grooves. Everything seemed to fit fine. Not sure what a good fit is but was able to put a piece in a dado and groove by hand and could pick up the piece without falling out. Now, I have to take a dead blow to it and have to knock it loose with a dead blow. Seems too tight.
    Thinking I could make a pass to two through my planer or drum sander. Should I?
    TIA
  2. #2
    User TENdriver's Avatar
    Nickname
    TENdriver
    Join Date
    Nov 2012
    Location
    Wdbg, VA
    Posts
    802
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    Re: Humidity?
    I rely more on hand tools, so it’s very easy to make a final adjustment in thousands of an inch. Power planers and drum sanders usually won’t afford that level of control or precision, so I would be concerned about altering the dimensions too far towards a looser joint.
    But more importantly, are you finished milling the parts for that assembly?
    Are you ready for the final dry-fit and then assembly with glue?
  3. The following user says Thank You to TENdriver for this useful post:
  4. #3
    DQ
    tdukes's Avatar
    Nickname
    Eddie
    Join Date
    Nov 2017
    Location
    Lexington, SC
    Posts
    508
    Visit Freq
    1.35 visits/week
    Threads
    92
    Classifieds
    Re: Humidity?
    The test pieces I cut fit fine. I knew I had cut the shelves a little long so I could sneak up on the length. I haven't made the final dry fit yet but everything has been milled.
    Its the shelves I was thinking about making a skim pass on. I doubt I could line things back up to widen the grooves and dados.
    Thanks
  5. #4
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,711
    Visit Freq
    6.88 visits/week
    Threads
    654
    Classifieds
    Re: Humidity?
    You've got the fit just about right. Did the shelves come out fairly easy before needing the dead blow a day later? Higher humidity, which is inevitable in the Carolinas, probably swelled the width of the dadoes. You may want to hand sand a hair off of the shelf ends (3/4" t x 1/2" l?).
  6. The following user says Thank You to Jeff for this useful post:
  7. #5
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,924
    Visit Freq
    6.85 visits/week
    Threads
    530
    Classifieds
    Re: Humidity?
    I would just hand sand the edges that are tight until they have the fit you're after. Too easy to go too far with a power planer or sander. A tiny, tiny bevel on the edges won't show especially on the under or inside.
    I don't believe in Astrology. I'm a Sagittarius and we're skeptical.
    "May the grain be with you" - Roy Underhill
  8. The following user says Thank You to KenOfCary for this useful post:
  9. #6
    DQ
    Bill Clemmons's Avatar
    Nickname
    Bill (70)
    Join Date
    Mar 2010
    Location
    Liberty, NC
    Posts
    6,214
    Visit Freq
    6.88 visits/week
    Threads
    265
    Classifieds
    Re: Humidity?
    Quote Originally Posted by KenOfCary View Post
    +1. This is exactly the way I would do it. Your fit sounds about right. Now just tweak the ends w/ sanding until each piece fits perfectly. Leave the dados alone.
    I'll gladly tell you how I do something. Just please don't confuse that with the right way to do it, and almost certainly not the only way.
  10. #7
    Nickname
    DrBob
    Join Date
    May 2014
    Location
    Baldwin, FL
    Posts
    752
    Visit Freq
    3.69 visits/week
    Threads
    62
    Classifieds
    Re: Humidity?
    Ever heard of "killing the wood"? By using a hammer to compress the fibers of the shelf until it fits (might be a bit harder to do on white oak, but something to consider).
    Once its in there, its in there.
  11. The following user says Thank You to Rwe2156 for this useful post:
  12. #8
    Nickname
    TENdriver
    Join Date
    Nov 2012
    Location
    Wdbg, VA
    Posts
    802
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    Re: Humidity?
    DrBob, Interesting what new ideas you can learn. I probably wouldn’t use a hammer myself, but I’ve used a machinist vise to lightly compress the fibers and then expected the glue moisture would cause the fibers to expand. The problem for me was predictability and precision.
    A properly used basic hand plane would turn this into a very simple task. Spot sanding is probably a good alternative, but I will do just about anything to avoid more dust.
  13. The following user says Thank You to TENdriver for this useful post:
  14. #9
    DQ
    Nickname
    HenryW
    Join Date
    Aug 2005
    Location
    Raleigh, NC
    Posts
    1,362
    Visit Freq
    6.23 visits/week
    Threads
    267
    Classifieds
    Re: Humidity?
    Quote Originally Posted by tdukes View Post
    TIA
    Or you could wait until the humidity drops - say mid-January 2019 ?!?!
    Signed - NOT a fan of the humidity typical to NC; mourning the passing of winter.
    Henry W
    Prolific creator of sawdust, and sometimes shavings - with the occasional completed project.
  15. The following user says Thank You to Henry W for this useful post:
  16. #10
    User CrealBilly's Avatar
    Nickname
    Join Date
    Feb 2009
    Location
    Creal Springs, IL
    Posts
    10,230
    Visit Freq
    0.42 visits/week
    Threads
    976
    Classifieds
    Re: Humidity?
    I found it best to mill/shape/glue as I go. The longer a piece of wood sits milled and shaped without being in glue, the more it's going to move around. Usually in ways I don't want it too.
    #ArmOurTeachers
    #SchoolConsealedCarry
  17. The following user says Thank You to CrealBilly for this useful post:
  18. #11
    DQ
    danmart77's Avatar
    Nickname
    Dan (66)
    Join Date
    Oct 2007
    Location
    Durham, NC
    Posts
    1,774
    Visit Freq
    6.69 visits/week
    Threads
    316
    Classifieds
    Re: Humidity?
    Touching up the edge is the quickest and the least risky way to get a nice fit with a board fitting in a dado or "routed channel."
    My technique is to use a card scraper near the edges to remove a little bit.
    Why the scraper? It leaves a nice crisp surface and it is easier to keep it square-- no rounding over.
    Just another approach to getting a good fit.
    If you don't keep a card scraper in your back pocket, maybe its time to give it a try.
  19. The following user says Thank You to danmart77 for this useful post:
  20. #12
    DQ
    tdukes's Avatar
    Nickname
    Eddie
    Join Date
    Nov 2017
    Location
    Lexington, SC
    Posts
    508
    Visit Freq
    1.35 visits/week
    Threads
    92
    Classifieds
    Re: Humidity?
    Got the to fit.
    I hadn't done my final sanding and still had pencil and chalk marks to remove. So I did that and then took a piece if 3/4" plywood, slapped a piece of self adhesive 120 grit paper on it. A couple light passes through the dados. Now a little fist bump seats them.
    Thanks!!
Similar Threads
  1. What's the humidity???
    By ErnieM in forum Workshop Discussion
    Last Post: 03-21-2015, 11:17 AM
  2. Humidity Issues
    By Touchwood in forum General Woodworking
    Last Post: 02-06-2013, 11:55 PM
  3. Humidity in the shop
    By Bugle in forum Workshop Discussion
    Last Post: 09-06-2011, 06:34 AM
  4. Humidity and finishing
    By BWSmith in forum Finishing
    Last Post: 07-07-2011, 03:17 PM
  5. Humidity in shop FYI
    By ebarr in forum General Woodworking
    Last Post: 07-31-2006, 10:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
