Klingspor's Woodworking Shop (Festool) Ad #2
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Thread: Dovetail Jig
  1. #1
    DQ
    Nickname
    Join Date
    Jul 2016
    Location
    Greensboro, NC
    Posts
    187
    Visit Freq
    1.96 visits/week
    Threads
    Classifieds
    Dovetail Jig
    I'm building a desk and instead of traditional legs, I'm dovetailing side panels to the top (see my bad drawing). So, I decided to use a dovetail jig for the first, and hopefully only time. I just didn't trust myself to be able to pull off hand cutting DT's on the end of a 65" panel. Below is a picture of the setup I used. I tried to be as safe as possible, but using a router while standing on a chair is pretty dicey.
    So, I have finally used a dovetail jig, but I did not like it! Hopefully I won't have use it very often.
    Attached Images Attached Images
  2. #2
    DQ
    Gotcha6's Avatar
    Nickname
    Join Date
    Jan 2007
    Location
    Ivan's Corner (Monroe), NC
    Posts
    5,790
    Visit Freq
    6.85 visits/week
    Threads
    354
    Classifieds
    Re: Dovetail Jig
    It may be easier to lay the piece on its flat face and work from the end of the bench instead of standing in the chair........
    Nice design. Simplicity is its own elegance sometimes.
    WHAT BOX?
  3. The following user says Thank You to Gotcha6 for this useful post:
  4. #3
    Forum Leader Senior User
    Nickname
    Dave
    Join Date
    Aug 2013
    Location
    Rochester, MN
    Posts
    1,036
    Visit Freq
    6.50 visits/week
    Threads
    74
    Classifieds
    Re: Dovetail Jig
    So you didn't like the dovetail jig? Is that because of the jig or the floor's too high in your shop?
    I'll be watching to see how the desk turns out.
    SketchUp Authorized Training Center
  5. The following user says Thank You to Dave Richards for this useful post:
  6. #4
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    1,014
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    Re: Dovetail Jig
    I believe I'd turn it around and stand on the bench, standing on the chair is very dangerous. Other than that I'd probably just cut it by hand, trusting yourself, I think you can do it.
    Nothing beats a try but a failure, failure is an opportunity to learn.
    http://graywolfwoodworks.wordpress.com/
  7. The following user says Thank You to Graywolf for this useful post:
  8. #5
    DQ
    FredP's Avatar
    Nickname
    Fred (61)
    Join Date
    Jun 2006
    Location
    franklinton, nc
    Posts
    5,696
    Visit Freq
    6.96 visits/week
    Threads
    208
    Classifieds
    Re: Dovetail Jig
    the chair wasn't quite high enough. maybe set a drywall bucket on it to get to a comfortable height...
    fred p If it ain't broke you aint trying hard enough
  9. The following user says Thank You to FredP for this useful post:
  10. #6
    DQ
    Nickname
    Join Date
    Jul 2016
    Location
    Greensboro, NC
    Posts
    187
    Visit Freq
    1.96 visits/week
    Threads
    Classifieds
    Re: Dovetail Jig
    I don't like the jig because of the ridiculously fat pins and the setup time. The top of the desk is 1 1/8" thick, which meant I had to use a 1/2 shank bit...even fatter pins that normal!
    Thanks for the vote of confidence Richard!
  11. #7
    Nickname
    Dave
    Join Date
    Aug 2013
    Location
    Rochester, MN
    Posts
    1,036
    Visit Freq
    6.50 visits/week
    Threads
    74
    Classifieds
    Re: Dovetail Jig
    Ah... Fat pins. I got it. That's one of my complaints with carbide dovetail cutters. I've got a set of HSS steel dovetail bits that run slimmer than the carbide cutters out there.
    I suppose it's too late now. You have them all cut?
  12. #8
    DQ
    Nickname
    Join Date
    Jul 2016
    Location
    Greensboro, NC
    Posts
    187
    Visit Freq
    1.96 visits/week
    Threads
    Classifieds
    Re: Dovetail Jig
    They are all cut, but I looked and couldn't find a DT cutter with a 1/4 shank that had a cutter head long enough to cut the 1 1/8" board.
    And I should say that I don't, personally, like the jig because of the pins, but this jig (Leigh DR4 Pro) itself is top notch. Well made with great instructions and the DT's are perfect, once it's set up. i think if you used a DT jig often, this would be the one to get.
  13. #9
    Nickname
    Dave
    Join Date
    Aug 2013
    Location
    Rochester, MN
    Posts
    1,036
    Visit Freq
    6.50 visits/week
    Threads
    74
    Classifieds
    Re: Dovetail Jig
    I almost bought one of those some time back but decided I didn't like the fat pins and went a different route that is more flexible and doesn't require special dovetail bits.
    If you do another piece this way, you might consider a sort of hybrid method. Cut the sockets either traditionally by hand or at the bandsaw, mark out for the pins as you would for handcut but remove the waste between the pins with a router with a straight cutter.
  14. The following user says Thank You to Dave Richards for this useful post:
  15. #10
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    1,014
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    Re: Dovetail Jig
    Hey fat pins need love to.
  16. The following 2 users say Thank You to Graywolf :
  17. #11
    DQ
    Nickname
    Join Date
    Jul 2016
    Location
    Greensboro, NC
    Posts
    187
    Visit Freq
    1.96 visits/week
    Threads
    Classifieds
    Re: Dovetail Jig
    Richard, you should make bumper stickers!
    I always cut my DT's by hand and the whole reason for the jig was that I thought I could probably cut the tails standing on a chair, but I had no idea how to position these huge, heavy boards steady enough to transfer the tail marks onto the pin board. I find that hard to do accurately with small pieces!
    I think it's going to come out looking ok, I got them all cut and fitting very well with no tear out, so I'm happy. This desk is for my wife's office and as long as she likes it, I'm good.
  18. #12
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    1,014
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    Re: Dovetail Jig
    I look forward to seeing your progress and the finished piece. There is always a work around.
  19. The following user says Thank You to Graywolf for this useful post:
  20. #13
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,711
    Visit Freq
    6.88 visits/week
    Threads
    654
    Classifieds
    Re: Dovetail Jig
    You're satisfied with the outcome and so is your wife so a little inconvenience and hassle was worth that effort Mr. Stilt!
    Why didn't you use box joints (aka finger joints) instead of dovetails? I don't do dovetails and don't understand what a "ridiculously fat pin" is over a 20-23" width. Here's a 20" width with 2" w fingers but maybe too much visual contrast vs a "skinny" pin. Just curious why you like dovetails so much.
  21. The following user says Thank You to Jeff for this useful post:
  22. #14
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,722
    Visit Freq
    6.96 visits/week
    Threads
    749
    Classifieds
    Re: Dovetail Jig
    Quote Originally Posted by David Justice View Post
    Why not lay the boards flat on the bench and clamp the short pieces in position to mark?
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  23. The following 2 users say Thank You to Mike Davis :
  24. #15
    DQ
    Nickname
    Join Date
    Jul 2016
    Location
    Greensboro, NC
    Posts
    187
    Visit Freq
    1.96 visits/week
    Threads
    Classifieds
    Re: Dovetail Jig
    Jeff - I never considered box joints for this. I have only ever used them on....boxes :-) I do really like the aesthetics of dovetails though.
    Mike - I thought about that, but I wanted the short boards (legs) to be the tail board and the long boards (top) to be the pins and If I'm thinking about it correctly I would have to clamp the short board overlapping the end of the long board, which would mean I'd need 70" clamps. Yes, probably cheaper than the jig, but I figured I may need it again and I can cut box joints with it too.
    This is how far I got as of last night - All dovetails cut and I cut the angle joint. I plan on using floating tenons here and I'll put in a few pocket hole screws to clamp it together. All that is left is a final smoothing and breaking all the sharp corners, assembly and putting the finish on. I plan on putting a pretty hefty leg with a leveling foot on the back at the 90 degree corner, this will be my last step when installing.
Similar Threads
  1. 1.6k Dovetail Jig
    By CrealBilly in forum General Woodworking
    Last Post: 08-31-2015, 04:57 PM
  2. Dovetail Help?
    By Flute Maker in forum General Woodworking
    Last Post: 12-28-2014, 10:30 PM
  3. Dovetail box...
    By Chris C in forum Hand Tools and their Use
    Last Post: 04-09-2014, 01:53 PM
  4. Which dovetail saw to buy???
    By kooshball in forum Hand Tools and their Use
    Last Post: 06-08-2011, 08:43 PM
  5. Need help with dovetail jig
    By btdust in forum General Woodworking
    Last Post: 02-09-2008, 10:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
