Klingspor's Woodworking Shop (Locations) Ad #1
Results 1 to 11 of 11
  1. #1
    Administrator Corporate Member
    DQ
    Nickname
    Neal (58)
    Join Date
    Apr 2017
    Location
    King, NC
    Posts
    744
    Visit Freq
    8.46 visits/week
    Threads
    Classifieds
    Possible Outreach project?
    A few weeks ago, Mike was asking for ideas that could be used for Outreach turners that were older than the light saber group. I just got a piece of lacewood and wanted to see what it looked like in a non-flat form. I had no idea what it could become when I put it on the lathe, and after a couple of minutes i decided it was now a key ring fob. Drilled a small hole through one end. total time spent 10 minutes including a little sanding and finish.
    The designs are limited by how far the split ring needs to spread to thread through the hole in the end. Just throwing this out for discussion.
    Attached Images Attached Images
  2. The following 9 users say Thank You to bowman :
  3. #2
    Co-Director of Outreach Corporate Member
    DQ
    Barry W's Avatar
    Nickname
    Barry
    Join Date
    Oct 2014
    Location
    Lawsonville, NC
    Posts
    861
    Visit Freq
    5.08 visits/week
    Threads
    79
    Classifieds
    Re: Possible Outreach project?
    I like it. Seems simple enough for a beginner and results in a useable, handsome product. Also, it doesn't take much wood. Great idea!
    "Nihil est melius quam vita diligentissima" (Nothing is better than a most diligent life.)
    -James Murray
  4. #3
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,631
    Visit Freq
    6.96 visits/week
    Threads
    742
    Classifieds
    If you added a screw eye and a cap nut you could do any sort of design on there.
    i like it for an outreach project.
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  5. The following 2 users say Thank You to Mike Davis :
  6. #4
    DQ
    sawman101's Avatar
    Nickname
    Bruce Swanson
    Join Date
    Feb 2009
    Location
    Newton, NC
    Posts
    3,124
    Visit Freq
    6.62 visits/week
    Threads
    191
    Classifieds
    Key ring kits are on the shelf at Klingspors. I have turned quite a bunch, but it would require a pen mandrel and the bushings.
    Experience is a hard teacher; she gives the test first, and the lesson later.
  7. The following 2 users say Thank You to sawman101 :
  8. #5
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,865
    Visit Freq
    6.81 visits/week
    Threads
    526
    Classifieds
    We have a pen mandrel on the trailer, BTW (3 in fact). Neal, did you turn it between centers and then part it off?
    I don't believe in Astrology. I'm a Sagittarius and we're skeptical.
    "May the grain be with you" - Roy Underhill
  9. The following user says Thank You to KenOfCary for this useful post:
  10. #6
    DQ
    Nickname
    Neal (58)
    Join Date
    Apr 2017
    Location
    King, NC
    Posts
    744
    Visit Freq
    8.46 visits/week
    Threads
    Classifieds
    Ken,
    This one was not on any mandrel, but chucked up with tailstock support. I used my skew chisel to pare it off.
    This was just an end product, an idea for future projects. Details for implementation and modifications can be discussed for efficiency and safety of the participants, if elected to go forward.
  11. The following user says Thank You to bowman for this useful post:
  12. #7
    DQ
    Nickname
    Roy
    Join Date
    Apr 2010
    Location
    Apex, NC
    Posts
    932
    Visit Freq
    6.69 visits/week
    Threads
    54
    Classifieds
    Bottle stoppers are easy to make. Drill a hole in the wood, insert the dowel, turn the stopper, finish and glue on the cork. Really inexpensive material-wise and nice to have.
    Roy G
  13. The following 2 users say Thank You to Roy G :
  14. #8
    Board of Directors
    Secretary
    DQ
    Hmerkle's Avatar
    Nickname
    Join Date
    Jul 2013
    Location
    Greer, SC
    Posts
    5,607
    Visit Freq
    4.23 visits/week
    Threads
    313
    Classifieds
    Great idea as an alternative to the light saber.
    (and a more "adult" project - most kids don't have keys, and we have a number of adults that want to "learn to turn!"
    People are amazed as a shaving rises from the throat of a plane as if itís a spell plucked from a sorcererís hand Ė Paul Sellers
  15. The following user says Thank You to Hmerkle for this useful post:
  16. #9
    DQ
    Phil S's Avatar
    Nickname
    Phil Soper (68)
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    4,605
    Visit Freq
    8.65 visits/week
    Threads
    539
    Classifieds
    Here is a suggestion based on my remembering how much I liked turning an angled inlay that turned into an oval - I guess I knew it would but sure was fun watching it happen.
    This suggestion is also based in teaching/introducing a number of woodworking skills
    - Have each participant cut a blank at a 45 angle (the exact angle is not really important). A small wooden miter box and a saw and maybe a clamp to keep hands away is all we would need
    - Give the student a contrasting thin wood and have them glue it all together. clamp it with some rubber bands and put it away to dry
    - Give the student a pre-glued blank and have them turn and finish it on the lathe
    We did something similar in a project called Hope Bracelets and it seemed to work well. Of course we had to make up and glue some blanks together prior to the event, but that would not take very long. If the student glued piece was done poorly, which will happen, we just throw those away at the end of the event
    This teaches: how to cut wood, how to glue wood together, how to turn and finish
    phil
  17. The following 5 users say Thank You to Phil S :
  18. #10
    DQ
    sawman101's Avatar
    Nickname
    Bruce Swanson
    Join Date
    Feb 2009
    Location
    Newton, NC
    Posts
    3,124
    Visit Freq
    6.62 visits/week
    Threads
    191
    Classifieds
    The bottle stopper adult type project is very doable. Again, Klingspors carry a neoprene type bottle stopper on a dowel; they are less than a buck a piece in bags of 10. Purchase the inexpensive mandrel and thread the piece to be turned, on to it, after drilling the appropriate sized hole in the stock. The dowel of the stopper end slides into the hole, with glue applied. A beautiful bottle stopper for under 90 cents per piece!
  19. The following user says Thank You to sawman101 for this useful post:
  20. #11
    DQ
    Bear Republic's Avatar
    Nickname
    Steve (53)
    Join Date
    Apr 2017
    Location
    Raleigh, NC
    Posts
    585
    Visit Freq
    3.96 visits/week
    Threads
    Classifieds
    For whatever is decided, if help us needed in prep work, I'm game.
    - Not living life till you're part of the Food Chain
Similar Threads
  1. Possible Outreach project - V2 update 9/3
    By Phil S in forum NCWW Outreach
    Last Post: 09-04-2017, 10:13 AM
  2. Bee Houses - new outreach project
    By tri4sale in forum NCWW Outreach
    Last Post: 03-01-2016, 12:59 PM
  3. New Outreach Project - Need Supplies - Peg Game
    By KenOfCary in forum NCWW Outreach
    Last Post: 04-30-2015, 04:23 PM
  4. Outreach project suggestions
    Last Post: 10-31-2012, 06:34 PM
  5. Outreach project suggestions
    By Phil S in forum Staff Announcements
    Last Post: 10-31-2012, 04:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
