Festool (Ad #1)
Results 1 to 12 of 12
  1. #1
    DQ
    Nickname
    Join Date
    Jul 2016
    Location
    Greensboro, NC
    Posts
    187
    Visit Freq
    2.73 visits/week
    Threads
    Classifieds
    A Nod to Hand Tools and Router Help
    I am building a new workbench and finally received my vises to install. I had a pretty large cavity to excavate for the wagon vise, and I spent what seems like forever getting the router set up. I don't use the router a lot, but I thought I was doing things right, it just seemed to be taking a very long time to get it done and the router really seemed to be struggling. It'sa Dewalt 618 2 1/4HP and I was only taking 1/4" deep passes at a time.
    I finally got sick of how long it was taking and the huge mess, and got out my biggest chisel and mallet and in less time that it took me to set up the router I had the wood gone. I cleaned up with the router in one pass. The picture is before cleaning it up with the router.
    This is a lesson I have learned a few times. Machine setup sometimes just is not worth it. Hand tools can sometimes be much faster.
    With that said, anyone know why my router was struggling so badly? This is just construction 2x6's. I'd hate to see how it would have been with hard Maple! Is the router not powerful enough? Is 1/4 deep passes too much? I was using a 3/4" straight bit, would another bit have been better?
    Thanks.
    Attached Images Attached Images
  2. #2
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,660
    Visit Freq
    6.96 visits/week
    Threads
    746
    Classifieds
    Re: A Nod to Hand Tools and Router Help
    Are you sure you router bit is made for end cutting? Some are great for cutting on the side but not down in the bottom of a hole. They make special plunge cut bits that do a much better job of it.
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  3. #3
    Administrator Corporate Member
    DQ
    ehpoole's Avatar
    Nickname
    Ethan (47)
    Join Date
    Oct 2009
    Location
    Anderson, SC
    Posts
    6,073
    Visit Freq
    6.69 visits/week
    Threads
    207
    Classifieds
    Quote Originally Posted by Mike Davis View Post
    What Mike said. Most straight flute bits are not plunging bits. To be a plunge capable bit there must be a full coverage cutting edge at the tip of the bit, often achieved on straight flute bits through the use of two extra deep flutes such that when spinning the two cutting edges will effectively overlap the full face profile of the bit. More typical straight flute bits do not cut in the central portion of the bit, leaving an island of wood that you are effectively tying to compress rather than cut when you plunge in. With non-plunge bits you must slowly draw the bit across the wood as it is lowered such that you are effectively firming a ramp cut until the bit is fully plunged, then you can route normally because the remainder of the cutting will be side cutting. My favorite bit for hogging out mortises and plunging is the upcut spiral bit as they also draw the waste out of the hole and if you have a dust collection system for your router then most of the waste will be captured by your vacuum, greatly reducing cleanup afterwards.
    If you were using a suitable plunge bit and still had issues then either the cutting edges have chipped or otherwise been damaged or the edges are very dull and no longer suitable for routing. This can happen easily since we often tend to heavily use certain sections of the cutting edge while other sections are often unused until you try to take a deep cut, with the end of the bit being the area that ordinarily dulls first (there very section you are trying to plunge). Also, be very aware of resin/pitch buildup on your cutting edges any time you are routing or cutting pines with any power tool as the resin buildup will effectively dull your cutting edges until removed with a suitable solvent (avoid things like oven cleaner if using carbide bits as many often cleaners attack the filler metals that attach the carbide). Pines are often easy to cut in principle as they are often fairly soft but the resin accumulation on your cutting edges often means more cleanup work and with some pines will effectively dull a blade fairly quickly. I would not expect the wood removed in your one mortise to result in enough resin buildup but if you have used the bits many times over the years without cleaning them you can accumulate a good deal of resin contamination over time.
  4. #4
    Board of Directors
    Vice President
    DQ
    Michael Mathews's Avatar
    Nickname
    Michael (56)
    Join Date
    Mar 2012
    Location
    Chapel Hill, NC
    Posts
    1,518
    Visit Freq
    4.77 visits/week
    Threads
    147
    Classifieds
    Also, is your router bit sharp? That could hinder the cut too!
  5. #5
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,588
    Visit Freq
    6.85 visits/week
    Threads
    649
    Classifieds
    Is this the type of 3/4" straight bit (it has some cutting flutes at the very bottom tip of the bit) that you were using?
    http://www.freudtools.com/index.php/...product/04-140
    https://www.homedepot.com/p/Diablo-3...2156/100660717
    Here's a 3/4" spiral uncut bit which is better suited to deeper plunge cuts like your huge bench top mortise pictured.
    https://www.amazon.com/Onsrud-Up-Cut.../dp/B0020B358G
    How large is the area that you excavated (l x w x depth)? A single cut (1/4" d x 3/4" w) is pretty hefty even with a 2 1/4hp router (same model as mine).
    Your hand tool alternative is an expedient alternative too!
  6. #6
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,883
    Visit Freq
    6.81 visits/week
    Threads
    527
    Classifieds
    A spiral up-cut bit would have been the one for this job. But as you said hand tools also work well.
    I don't believe in Astrology. I'm a Sagittarius and we're skeptical.
    "May the grain be with you" - Roy Underhill
  7. #7
    DQ
    Nickname
    Join Date
    Jul 2016
    Location
    Greensboro, NC
    Posts
    187
    Visit Freq
    2.73 visits/week
    Threads
    Classifieds
    Thanks everyone! I definitely think it was my router bit. It is brand new, but it's just a plain old straight bit like Jeff's second link.
    As luck would have it, I have a leg vise to install with an X brace, so I have 2 mortises to make on the chop and the bench leg. I'll give the router another try with a 3/8 upcut spiral bit that I have.
  8. #8
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    981
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    David, the 3/8" up cut spiral will work but in small bites I would stay with 1/8" bites at a time or you will over heat the bit and it could break. If nothing else it will dull and just sit there and go you want me to cut what. Good luck and I look forward to seeing pictures of the finished product.
    Nothing beats a try but a failure, failure is an opportunity to learn.
    http://graywolfwoodworks.wordpress.com/
  9. The following user says Thank You to Graywolf for this useful post:
  10. #9
    DQ
    Nickname
    Join Date
    Jul 2016
    Location
    Greensboro, NC
    Posts
    187
    Visit Freq
    2.73 visits/week
    Threads
    Classifieds
    Yes, if I ever get it finished. This wagon vise is an unbelievable PITA to install! I know it's more my fault than the vises though.
  11. #10
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,588
    Visit Freq
    6.85 visits/week
    Threads
    649
    Classifieds
    Quote Originally Posted by David Justice View Post
    Who made your wagon vise and why'd you go with that style instead of a much easier to install tail vise? Your PITA comment has a precedent too...
    https://www.popularwoodworking.com/w...oubo-workbench
    https://www.popularwoodworking.com/w...se-version-4-0
  12. #11
    DQ
    Nickname
    Join Date
    Jul 2016
    Location
    Greensboro, NC
    Posts
    187
    Visit Freq
    2.73 visits/week
    Threads
    Classifieds
    I got the Hovarter Wagon and Leg vise with the XLink (https://www.hovartercustomvise.com/) but like I said before it's not the vises, they are actually really nice and Len is a very nice and patient guy.
    After thinking about building a workbench for at least a year, I still managed to do a horrible job of planning. I built the base and top...then decided I wanted these vises. It was just a lot of work and refining to get the Wagon vise in correctly after the fact. If I had planned and had the vise when I built the top, it would have been much easier!
    I have it in and it's working great! I am going to tackle the Leg vise this week, and I think it will be and easier install.
  13. The following user says Thank You to David Justice for this useful post:
  14. #12
    DQ
    Gofor's Avatar
    Nickname
    Join Date
    Mar 2006
    Location
    Goldsboro, NC
    Posts
    3,236
    Visit Freq
    6.62 visits/week
    Threads
    82
    Classifieds
    When building my work bench, I remember a definition (not sure of the source) that basically stated that a woodworking bench is merely a structure to hold all the vises and attachments to secure your work at a comfortable height. The same treatise recommended procuring all vise hardware before designing the bench. Although that may sound backwards, i have found it to be a good philosophy.
    Practicing at practical woodworking
  15. The following user says Thank You to Gofor for this useful post:
Similar Threads
  1. Replies: 8
    Last Post: 12-19-2015, 10:57 AM
  2. And so you think you can use hand tools do ya?
    By CrealBilly in forum General Woodworking
    Last Post: 08-06-2015, 08:57 PM
  3. Why do you like hand tools?
    By froglips in forum Hand Tools and their Use
    Last Post: 03-11-2010, 01:44 PM
  4. Hand tools???
    By rcflyer23 in forum Hand Tools and their Use
    Last Post: 02-16-2010, 03:07 PM
  5. The best of ... hand tools
    By WoodWrangler in forum Hand Tools and their Use
    Last Post: 04-24-2009, 12:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
