West Penn Hardwoods (Ad 2)
Results 1 to 12 of 12
  1. #1
    Nickname
    Man with many vises
    Join Date
    Feb 2015
    Location
    Raleigh, NC
    Posts
    Visit Freq
    6.15 visits/week
    Threads
    Classifieds
    Portable woodworking vise
    Members of Triangle Woodworkers have dubbed me the “man with many vises” and here I go again. Earlier this year, another member had built a Benchcrafted HiVise (https://www.benchcrafted.com/hivise) and I was intrigued by the criss-cross but not the screw mechanism which felt “heavy” to me.
    I contacted BenchCrafted and asked if the 9” criss-cross was for sale separately. Their response was not now but ask again next week. Later, I was able to purchase the cross-cross for $64 + $9 shipping.
    Using that criss-cross, I built this 17” tall portable vise which opens 6-1/4”:
    Here is the portable vise being held in my end vise:
    And bolted to the bench top through dog holes:
    The Acme screw mechanism has been used in other vises of my design. Components include a 3/4-6 Acme screw, a self-aligning ball bearing, an ordinary radial ball bearing, a flat thrust washer, and a brass Acme square nut.
    The tee is a common reducing iron pipe tee which is roll-pinned to the Acme screw. The tee pushes on the self-aligning bearing which is a press fit into a shaped recess in the chop. The SA bearing hub is set screwed to the Acme screw and this provides the garter function to open the chop. The radial ball bearing in the leg sits in a 1/16” cushion of silicone caulk to stabilize the screw and prevent rattling (I hate vises that rattle).
    I just finished this vise yesterday and will now put it into service to find any bugs.
    Attached Images Attached Images
  2. #2
    Administrator Corporate Member
    DQ
    Nickname
    Neal (57)
    Join Date
    Apr 2017
    Location
    King, NC
    Posts
    421
    Visit Freq
    9.42 visits/week
    Threads
    Classifieds
    Re: Portable woodworking vise
    Very cool, well done sir!
  3. The following user says Thank You to bowman for this useful post:
  4. #3
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    565
    Visit Freq
    5.31 visits/week
    Threads
    Classifieds
    That is mighty fine, would love see and feel that in person!
    Nothing beats a try but a failure, failure is an opportunity to learn.
    http://graywolfwoodworks.wordpress.com/
  5. #4
    DQ
    Jim M.'s Avatar
    Nickname
    Woody
    Join Date
    Mar 2007
    Location
    New Church, VA
    Posts
    1,731
    Visit Freq
    6.96 visits/week
    Threads
    78
    Classifieds
    Very cool project.
    Measure twice... cut once... SCREAM LOUDLY... get another board
  6. The following user says Thank You to Jim M. for this useful post:
  7. #5
    DQ
    Gotcha6's Avatar
    Nickname
    Join Date
    Jan 2007
    Location
    Ivan's Corner (Monroe), NC
    Posts
    5,597
    Visit Freq
    6.46 visits/week
    Threads
    348
    Classifieds
    Intriguing. Since it is portable, perhaps you could bring it to the picnic for others to see if you're coming.
    WHAT BOX?
  8. #6
    User TENdriver's Avatar
    Nickname
    TENdriver
    Join Date
    Nov 2012
    Location
    Wdbg, VA
    Posts
    555
    Visit Freq
    6.65 visits/week
    Threads
    Classifieds
    Is the 6 1/4” opening limitation due to the acme screw length or the 9” criss-cross?
    If it’s the acme screw, how wide would the criss-cross open?
  9. #7
    DQ
    Nickname
    Jim (71)
    Join Date
    Feb 2013
    Location
    Durham, NC
    Posts
    1,390
    Visit Freq
    7.00 visits/week
    Threads
    83
    Classifieds
    That's a really nice looking, well executed vise. Did you source the bearings and other metal parts (except for the criss-cross?) from the same source or did you have to order from several?
  10. #8
    Nickname
    Man with many vises
    Join Date
    Feb 2015
    Location
    Raleigh, NC
    Posts
    Visit Freq
    6.15 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Graywolf View Post
    I'll try to make the picnic and bring the vise. It works well on picnic tables.
    BTW, "Reply with quote" didn't work on my new iPad with current IOS. I had to use my old iPad Mini which has a much older IOS.
  11. The following user says Thank You to pop-pop for this useful post:
  12. #9
    Nickname
    Man with many vises
    Join Date
    Feb 2015
    Location
    Raleigh, NC
    Posts
    Visit Freq
    6.15 visits/week
    Threads
    Classifieds
    Quote Originally Posted by TENdriver View Post
    Basically both. The arms hit the mounting pins at 7-1/2" opening so that is the absolute maximum.
    The real limit is more subtle. The lower ends of the arms ride on bearing plates in the mortises. When I first assembled the vise, the arms ran off the upper end of the plates before the screw left the nut. I made longer plates but then the center of the arms hit the plates preventing full closing. Shortened the plates a bit and now when the screw is flush with the nut, the arms are still on the plates and the vise will close.
  13. The following user says Thank You to pop-pop for this useful post:
  14. #10
    Nickname
    Man with many vises
    Join Date
    Feb 2015
    Location
    Raleigh, NC
    Posts
    Visit Freq
    6.15 visits/week
    Threads
    Classifieds
    Quote Originally Posted by nn4jw View Post
    Bearings come from The Big Bearing Store which is a stage name for Carnell Sales in TN. Generally Korean bearings but they have been fine.
    Most of the rest of the hardware comes for McMaster-Carr. The Acme screw and nut are 3/4-6 single lead (i.e. 6 turns to the inch).
  15. The following user says Thank You to pop-pop for this useful post:
  16. #11
    DQ
    sawman101's Avatar
    Nickname
    Bruce Swanson
    Join Date
    Feb 2009
    Location
    Newton, NC
    Posts
    2,703
    Visit Freq
    6.54 visits/week
    Threads
    166
    Classifieds
    Nowthat'sasooperkoolniftyvise!
    Experience is a hard teacher; she gives the test first, and the lesson later.
  17. The following user says Thank You to sawman101 for this useful post:
  18. #12
    Nickname
    Man with many vises
    Join Date
    Feb 2015
    Location
    Raleigh, NC
    Posts
    Visit Freq
    6.15 visits/week
    Threads
    Classifieds
    The jaw liners used on this vise are " crubber" which is ordinary automotive cork-rubber gasket material. You can get this at your local auto parts supplier (ask for it as it may be in the back and not on display). It's available in 1/16 (about $7) and 1/8 thickness (about $13) in a roll. My favorite adhesive for crubber is spray contact cement.
Similar Threads
  1. Portable tabletop vise
    By Opensightryan in forum Workshop Discussion
    Last Post: 12-08-2016, 08:53 AM
  2. Portable Mill
    By jlwest in forum Wood
    Last Post: 10-04-2014, 12:55 PM
  3. Raleigh CL - Woodworking workbench - $50 (Raleigh) with vise
    By Henry W in forum Found for Sale/Hot Deals
    Last Post: 03-27-2013, 12:33 PM
  4. Wood screws: Moxon double screw vise and thread for leg vise
    By eyekode in forum General Woodworking
    Last Post: 07-19-2010, 09:11 PM
  5. Portable table saw
    By mike_wood in forum Power Tools and Their Use
    Last Post: 01-05-2009, 04:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
