Festool (Ad #1)
Results 1 to 9 of 9
  1. #1
    DQ
    Charlie's Avatar
    Nickname
    Charlie (73)
    Join Date
    Nov 2008
    Location
    Raleigh, NC
    Posts
    1,783
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    Process for Creating a Crescent for Segmented Turning
    Following are steps for creating a crescent, in this case 2 high, at widest point.
    Use contrasting woods of your choice.
    Drill a 2 hole in the center of a 2 7/8 x 3 1/8 dark colored block and a 2 5/8 x 3 1/8 light colored block using a forstner bit. Cut both blocks in half on center.
    Drill (4) 1/8 x 5/16 deep pivot holes on the centerline of a 2 x 3 dark block.
    One hole 7/8 from each end and one hole 1 1/8 from each end.
    Using a jig on a disc sander (Jig detail below), sand each end of the block to a
    1 radius that fits tight into the light blocks, using the 1 1/8 inset pivot hole.
    Glue one half of the light block to each end of the dark block.
    Cut some of the away excess wood from the light wood.
    Radius the ends to 1 as before, using the pivot hole 7/8 from the end (This creates the width). Glue one half of the dark block to each end of the light/dark block.
    You now have two crescents. Cut into blocks as required.
    Following are photos of the sanding jig:
    Jig mounted on 20 disc sander. Jig is adjustable for sanding any size radius.
    Pivot pin.
    Sanding the radius.
  2. The following 10 users say Thank You to Charlie :
  3. #2
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,660
    Visit Freq
    6.96 visits/week
    Threads
    746
    Classifieds
    Re: Process for Creating a Crescent for Segmented Turning
    So, then this gets cut with the angle to fit into a ring?
    Edit:
    Should have looked at the other thread first.
    Thanks
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  4. #3
    DQ
    Bear Republic's Avatar
    Nickname
    Steve (53)
    Join Date
    Apr 2017
    Location
    Raleigh, NC
    Posts
    587
    Visit Freq
    3.96 visits/week
    Threads
    Classifieds
    Even more i evolved than I was thinking with your jig. Not surprised at your creativity. You come up with great ideas.
    - Not living life till you're part of the Food Chain
  5. #4
    DQ
    Jim M.'s Avatar
    Nickname
    Woody
    Join Date
    Mar 2007
    Location
    New Church, VA
    Posts
    1,922
    Visit Freq
    6.92 visits/week
    Threads
    83
    Classifieds
    Thanks for sharing the process Charlie, you are a true craftsmen and artist.
    Measure twice... cut once... SCREAM LOUDLY... get another board
  6. #5
    Nickname
    Johnathon
    Join Date
    Mar 2018
    Location
    Currie, NC
    Posts
    Visit Freq
    0.46 visits/week
    Threads
    Classifieds
    Charlie, could this be accomplished with inlay techniques? I would think that with a jig saw and some sharp chisel patience you could get to the same result.
    I don't know about you guys, but for me it's all about that feeling of, "Wow, I made that."
  7. #6
    DQ
    Charlie's Avatar
    Nickname
    Charlie (73)
    Join Date
    Nov 2008
    Location
    Raleigh, NC
    Posts
    1,783
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    Johnathon,
    The woods used in segmented turning goes all the way through because 80% of the wood gets turned off when shaping the vessel. Inlay will not work unless applied to a finished vessel.
  8. #7
    Nickname
    Johnathon
    Join Date
    Mar 2018
    Location
    Currie, NC
    Posts
    Visit Freq
    0.46 visits/week
    Threads
    Classifieds
    I guess I was thinking of a different term. I wasn't thinking of a surface inlay, but more of a through inlay? Drilling a hole and using a jigsaw to cut out the entire shape.
  9. #8
    DQ
    Nickname
    Steve (53)
    Join Date
    Apr 2017
    Location
    Raleigh, NC
    Posts
    587
    Visit Freq
    3.96 visits/week
    Threads
    Classifieds
    With the segmented techniques it's easier to build the shapes or voids into the build. Charlie has created some amazing pieces for that ring.
  10. #9
    DQ
    Charlie's Avatar
    Nickname
    Charlie (73)
    Join Date
    Nov 2008
    Location
    Raleigh, NC
    Posts
    1,783
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    Johnathon, As always, there are many ways to accomplish something. My way works well for me, but may not for others.
Similar Threads
  1. Segmented Turning # 200
    By Charlie in forum Woodturning
    Last Post: 08-27-2016, 10:44 PM
  2. segmented turning
    By erasmussen in forum Woodturning
    Last Post: 02-09-2012, 08:58 PM
  3. 3rd Segmented turning & more
    By MrAudio815 in forum Woodturning
    Last Post: 01-04-2012, 09:21 PM
  4. 2nd Segmented Turning~!
    Last Post: 06-14-2011, 04:05 PM
  5. segmented turning
    By Mark Stewart in forum "How To" Forum
    Last Post: 03-23-2010, 08:58 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
