West Penn Hardwoods (Ad 1)
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Thread: Drill press??
  1. #1
    Nickname
    Join Date
    Jul 2016
    Location
    Four Oaks, NC
    Posts
    416
    Visit Freq
    5.88 visits/week
    Threads
    97
    Classifieds
    Drill press??
    I'm casually looking for a drill press. I think this will be my next tool purchase.
    I recently made my first mortise and tenon joints. My mortise jig worked, but was NOT nice and neat work.
    What should I be looking for?
    • Floor model or bench top?
    • Minimum HP suggestion?
    • Speeds?
    • What else?
    I sold a couple hundred bucks worth of horse manure compost so far, so that is my budget. I see lots of bench tops for a lot less and some decent looking floor models in that $200 range on CL. Anything I need to stay away from?
  2. The following user says Thank You to DSWalker for this useful post:
  3. #2
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,470
    Visit Freq
    7.00 visits/week
    Threads
    734
    Classifieds
    Re: Drill press??
    Did not notice price but we looked at the Rikon floor model at Klingspor at I was impressed.
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  4. The following 2 users say Thank You to Mike Davis :
  5. #3
    Nickname
    Join Date
    Nov 2005
    Location
    Apex, NC
    Posts
    5,979
    Visit Freq
    6.15 visits/week
    Threads
    989
    Classifieds
    Re: Drill press??
    Please don't think about using mortising attachment on a DP. You can drill out mortises using a forstener bit.Then clean up side walls with a chisel.
  6. The following 3 users say Thank You to junquecol :
  7. #4
    Board of Directors
    Events Director
    DQ
    Berta's Avatar
    Nickname
    Roberta
    Join Date
    Oct 2008
    Location
    Cameron, NC
    Posts
    3,097
    Visit Freq
    6.50 visits/week
    Threads
    Classifieds
    Re: Drill press??
    I bought the Jet bench top a few months ago. I love it. It is also the one we have on the trailer. It IS a bit more than $200 though.
    Berta
  8. The following 2 users say Thank You to Berta :
  9. #5
    DQ
    tdukes's Avatar
    Nickname
    Eddie
    Join Date
    Nov 2017
    Location
    Lexington, SC
    Posts
    508
    Visit Freq
    6.19 visits/week
    Threads
    92
    Classifieds
    Re: Drill press??
    I bought a Delta bench top model off CL for $40. Still have it. Found out quick, fast and in a hurry it wasn't enough for woodworking. I think that was the moment I realized, buy a little more than you think you may need. A couple tax refunds later, I bought a 17" Jet. Added a Woodpeckers table to it. On occasion, I have found its still not large enough.
    PS I found a new Jet mortise jig with bits on eBay. Jet probably hadn't made it in years but it was new, never used. Think I paid around $75 for it. Know why that didn't work out.
    Two opposed edge guides on my Bosch router and a four flute end mill, with loose tenons seems to work out better.
  10. The following 2 users say Thank You to tdukes :
  11. #6
    Board of Directors
    Webmaster
    DQ
    FlyingRon's Avatar
    Nickname
    Ron
    Join Date
    Dec 2009
    Location
    Catawba, NC
    Posts
    1,146
    Visit Freq
    4.00 visits/week
    Threads
    77
    Classifieds
    Re: Drill press??
    I have a Porter Cable floor model that I got dirt cheap when Lowes (or was it HD) had them on clearance. It works adequately enough for what I use it for, which is pretty much just drilling (round) holes in things. I bought a dedicated shopfox mortiser a while back. Oddly, it seemed like a good idea at the time, but I don't tend to use it that much. I lived with a table top drill press for years, but the "full size" one is nicer (especially because it has a variety of speeds which is helpful if you're swinging big bits or fly cutters). The one thing I did get was a nicer table that clamps on to the regular table that I use most of the time but I do have a cheap cross vice I use for the odd time I need to drill into some metal.
    No job is worth doing unless you can get a new tool out of it.
  12. The following 2 users say Thank You to FlyingRon :
  13. #7
    Administrator Corporate Member
    DQ
    ehpoole's Avatar
    Nickname
    Ethan (46)
    Join Date
    Oct 2009
    Location
    Anderson, SC
    Posts
    5,980
    Visit Freq
    6.92 visits/week
    Threads
    206
    Classifieds
    Re: Drill press??
    Quote Originally Posted by junquecol View Post
    Agreed, drill presses make for very poor power mortisers, in part because they are not designed to provide the leverage necessary for the chisels nor have a spring strong enough to reliably retract the chisel from the board. If what you really want is a power mortiser then that is what your purchase should be as nothing else will work nearly as well. Otherwise, as Bruce mentions, it is not difficult to hog out waste with Forstner bits then clean up and square the sides manually afterwards with a chisel.
    Otherwise, what you want to look for in a drill press is the range of speeds it offers, especially towards the lower end (for use with large bits), length of quill travel (how much depth do you require), the ease of speed changes (usually pretty simple with most belt drives), easy quill depth stop setting, horsepower of motor (3/4-1 HP if you do a lot of hogging with large bits, otherwise 1/2-3/4HP is usually adequate), adjustable range of shelf, etc. What you need at a minimum depends heavily upon what you plan to do with it.
    If you do buy a mortiser, though, it is also worthwhile to purchase the sharpening cones whose angle matches your mortising chisels to help you keep the chisels nice and sharp. The drill bit can be easily sharpened using a file or diamond paddle but the sharpening cones for the chisels really helps you maintain their geometry over time and encourages you to keep them sharp.
  14. The following 2 users say Thank You to ehpoole :
  15. #8
    Nickname
    George
    Join Date
    Jan 2017
    Location
    Tellico Plains, TN
    Posts
    147
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    Re: Drill press??
    I have a General benchtop mortiser that I would be willing to let go it is great shape with chisels and all.
    I dont have a picture right now but it is this model.
    http://www.rockler.com/how-to/genera...ile-headstock/
    250 Let me know if you want it.
    George
  16. The following user says Thank You to gmakra for this useful post:
  17. #9
    DQ
    Nickname
    Neal (58)
    Join Date
    Apr 2017
    Location
    King, NC
    Posts
    608
    Visit Freq
    9.00 visits/week
    Threads
    50
    Classifieds
    Re: Drill press??
    Quote Originally Posted by gmakra View Post
    George
    George, you should place this in the classifieds.
  18. The following user says Thank You to bowman for this useful post:
  19. #10
    Nickname
    George
    Join Date
    Jan 2017
    Location
    Tellico Plains, TN
    Posts
    147
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    Re: Drill press??
    I understand about the classified adds.But this thread got me thinking so I offered it up.
  20. The following 2 users say Thank You to gmakra :
  21. #11
    DQ
    Jim M.'s Avatar
    Nickname
    Woody
    Join Date
    Mar 2007
    Location
    New Church, VA
    Posts
    1,885
    Visit Freq
    6.96 visits/week
    Threads
    81
    Classifieds
    Re: Drill press??
    I bought a RIDGID 15 in. drill press a couple years back and thought it would be just an interim tool, but I really like it's performance, now the new model has been upgraded to a 3/4hp motor. I think it would be a great addition to your shop, plus it qualifies for the RIDGID Lifetime Service Agreement, with free part and service for life.
    Measure twice... cut once... SCREAM LOUDLY... get another board
  22. The following user says Thank You to Jim M. for this useful post:
  23. #12
    Nickname
    Join Date
    Jul 2016
    Location
    Four Oaks, NC
    Posts
    416
    Visit Freq
    5.88 visits/week
    Threads
    97
    Classifieds
    Re: Drill press??
    George
    Thanks, but I"m looking for a good all around DP that could also be used for mortising.
  24. #13
    User Pop Golden's Avatar
    Nickname
    Pop (78)
    Join Date
    Jul 2011
    Location
    Charlotte, NC
    Posts
    865
    Visit Freq
    4.38 visits/week
    Threads
    Classifieds
    Re: Drill press??
    A drill press is a make-do ​mortiser at best. It is not built to take the strain on it's bearings etc. Buy a mortiser to do mortises. For a wood working drill press look for a used Shopsmith. I have a 520 I bought years ago and it now is my drill press. It is also a horizontal DP. An really neat machine to have around if you ever need one.
    Pop
    ​With Enough Thrust Pigs Fly Just Fine.
  25. #14
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,260
    Visit Freq
    6.92 visits/week
    Threads
    629
    Classifieds
    Re: Drill press??
    Is this the jig that Mike Davis suggested and you made it work pretty well without a plunge router? What were you expecting in order to label the outcome "nice and neat"?
    https://www.ncwoodworker.net/forums/...age=2&p=591747
    A drill press is a handy addition for many other uses besides roughing out mortises with Forstner bits (you'll still have to clean up the mortise with a chisel to make it "nice and neat").
    I have this bench top Craftsman (2/3 hp, 620-3120 rpm) that works fine for me over 12 years.
    http://www.sears.com/craftsman-10inc...p-00921900000P
    https://www.youtube.com/watch?v=SwPO3Hsen50
  26. #15
    DQ
    Nickname
    NCGrimbo
    Join Date
    Dec 2009
    Location
    Clayton, NC
    Posts
    283
    Visit Freq
    4.69 visits/week
    Threads
    Classifieds
    Re: Drill press??
    Mortising aside, I have a Delta benchtop drill press and after using it for over 15 years, I wish I had a floor model. It does a decent job, but with the height of my benches and the shortness of my legs, the location of the drill press's table isn't always conducive for easy drilling. There have also been many times where I wish I had a more powerful model which you can get in a floor model.
    I have the Delta mortising kit for drill press, but I've never taken it out of the box.
Similar Threads
  1. I am looking for a new drill press
    By Berta in forum Power Tools and Their Use
    Last Post: 03-12-2016, 08:16 PM
  2. Drill press
    By Larry Rose in forum Power Tools and Their Use
    Last Post: 04-27-2011, 09:24 PM
  3. drill press
    By scrollsawman in forum Power Tools and Their Use
    Last Post: 03-25-2008, 09:50 PM
  4. WTB Drill Press
    By John Reeves in forum Where Can I Find, Buy or Sell
    Last Post: 04-06-2007, 11:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
