Festool (Ad #1)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
  1. #1
    Forum Leader Senior User
    Nickname
    Dave
    Join Date
    Aug 2013
    Location
    Rochester, MN
    Posts
    957
    Visit Freq
    6.31 visits/week
    Threads
    Classifieds
    Question re: Patterns for Turning
    If you have a pattern for turning printed full size on paper similar to the one on the right, would you want dimensions on it? If so, what dimensions? Would you want just an overall length to check the printing with? Would you want diameters at certain points along the leg? Thanks for your time.
    SketchUp Authorized Training Center
  2. #2
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,482
    Visit Freq
    6.96 visits/week
    Threads
    734
    Classifieds
    Re: Question re: Patterns for Turning
    I would want all the low spots and high spots noted with diameter. Critical lengths as center to center of beads would also be helpful.
    If I have to make an exact reproduction I make a template that I can check from time to time as I turn.
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  3. #3
    Nickname
    Dave
    Join Date
    Aug 2013
    Location
    Rochester, MN
    Posts
    957
    Visit Freq
    6.31 visits/week
    Threads
    Classifieds
    Thanks Mike. So probably all the details dimensioned even though you could pick them off the full sized drawing with dividers?
  4. #4
    Nickname
    Join Date
    Jan 2013
    Location
    Mc Leansville, NC
    Posts
    1,829
    Visit Freq
    4.27 visits/week
    Threads
    70
    Classifieds
    Quote Originally Posted by Dave Richards View Post
    If you can supply a full size drawing (half section) like you have, no dimensions are needed as long as a person can print it full size. There in lies the issue usually, being able to print full size, a 32" printer possibly. All a turner needs are the transition lines (along the center axis) and the diameters at those points to work to, as well as minimum diameters they all can be scaled from a full size drawing. So, to answer your question, maybe datum dimension all the transition points from one end and give diameters at all of those points as an alternative to no dimensions.
  5. #5
    DQ
    Nickname
    Roy
    Join Date
    Apr 2010
    Location
    Apex, NC
    Posts
    908
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    Dave, this looks like a table leg, so I would think you would need a dimension of the major diameters so you could scale them up or down. A farmhouse type table would need larger legs than a coffee table. It looks like the outside of the curves all line up as do the lowest part of the coves.
    Roy G
  6. #6
    Nickname
    Dave
    Join Date
    Aug 2013
    Location
    Rochester, MN
    Posts
    957
    Visit Freq
    6.31 visits/week
    Threads
    Classifieds
    Supplying the drawing at full size in PDF form is no problem and the PDF could easily be printed by an office supply house. Index marks could be added to the sheet for post printing from Adobe Acrobat or Reader.
    Roy, it [i]is[/is] a farmhouse style table leg. In this case the top is 5 in. square.
    A grid could be added easily as well.
    FWIW, I used the 2D DXF file from Osborne Wood Products to make this example drawing just to save a bit of time. I'm thinking more of custom patterns or perhaps creating patterns by lifting dimensions off of existing antiques and such.
  7. #7
    DQ
    walnutjerry's Avatar
    Nickname
    Jerry
    Join Date
    Feb 2006
    Location
    Salisbury, NC
    Posts
    1,615
    Visit Freq
    6.27 visits/week
    Threads
    Classifieds
    I would want all the dimensions included------diameters and distance between diameter changes. Just me
    Jerry
    We make a living by what we get...............We make a life by what we give
  8. #8
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,482
    Visit Freq
    6.96 visits/week
    Threads
    734
    Classifieds
    Makes it easier to scale and even at the office supply the printer is not always exactly to size.
    WWFD
  9. #9
    Nickname
    Dave
    Join Date
    Aug 2013
    Location
    Rochester, MN
    Posts
    957
    Visit Freq
    6.31 visits/week
    Threads
    Classifieds
    OK. Thanks all for the information.
  10. #10
    jimwallacewoodturning.com Corporate Member
    DQ
    Jim Wallace's Avatar
    Nickname
    Join Date
    Dec 2009
    Location
    Wake Forest, NC
    Posts
    287
    Visit Freq
    2.96 visits/week
    Threads
    Classifieds
    In general, turnings are designed to minimize the need for too much measuring. In your example it looks like all the crests of the beads and balls (large beads) are at the same diameter as the square once it has had the corners removed - just turn till the flats are gone and smooth up with a chisel taking as small a shaving as possible. All the fillets or shoulders appear to be the same diameter (except for the one at the top, which is the same diameter as the rounded blank), so you would measure all these (fillets) with a caliper and parting tool as soon as you have rounded the leg (minus the square left at the top). You make these cuts at the appropriate places, leaving the space for the bead or ball full size and use the parting tool to make a straight line between the shoulders where there will be coves. Then the beads and balls are just gentle curves that connect the outside diameter to the shoulder and the coves are gentle curves connecting the shoulder to a point in the middle that looks right to you - you don't measure the depth of coves, you measure the width and judge the depth by what looks right. So all of this is done with only one set of calipers. Finally you have the foot. You could either set a second set of calipers for this diameter or just turn it by eye.
    Remember that in turning the only part that needs to be turned to a precise dimension is a tenon (of which you have none here) because it has to fit tightly into a mortise, all the rest just has to look right. No one will measure these parts with a machinist's caliper and tell you that one cove is a few thousandths (or even a sixteenth or an eighth) different than the next. And these pieces will be separated from each other by the width and length of the table, so direct comparison is difficult. After turning the first piece, if you are satisfied with the way it looks, you can use that to hold beside the next ones as you get close to finishing them. That will be the closest comparison any one will ever be able to make. You are probably your own harshest critic.
  11. #11
    Nickname
    Dave
    Join Date
    Aug 2013
    Location
    Rochester, MN
    Posts
    957
    Visit Freq
    6.31 visits/week
    Threads
    Classifieds
    Thanks Jim. I'm not planning to turn legs from the patterns I'd be making. I had a request from someone who wondered if I could make full size patterns for them. Frankly, if I was turning legs from a pattern like this, I'd not be too concerned about exact dimensions but I just wondered what others who do a lot of turning would want. I'd be happy with lifting dimensions off the drawing after checking a couple of basic ones to see that the print was correct.
  12. #12
    DQ
    Bill Clemmons's Avatar
    Nickname
    Bill (69)
    Join Date
    Mar 2010
    Location
    Liberty, NC
    Posts
    6,155
    Visit Freq
    7.00 visits/week
    Threads
    261
    Classifieds
    Timely question, Dave. I just drew plans for a dining table w/ a leg very similar to the one you show. Here are pics of the dimensions I added to my working drawings for upper and lower legs. Granted, I'm a little OCD, but I like to have all the details worked out before I start a project.
    Attached Images Attached Images
    I'll gladly tell you how I do something. Just please don't confuse that with the right way to do it, and almost certainly not the only way.
  13. The following 2 users say Thank You to Bill Clemmons :
  14. #13
    Nickname
    Dave
    Join Date
    Aug 2013
    Location
    Rochester, MN
    Posts
    957
    Visit Freq
    6.31 visits/week
    Threads
    Classifieds
    Nice work Bill. That's a lot of dimensions but it gets the information across.
    Out of curiosity, will you be leave the transition from square to round sharp as you show it in your model?
  15. #14
    Nickname
    Join Date
    Jan 2013
    Location
    Mc Leansville, NC
    Posts
    1,829
    Visit Freq
    4.27 visits/week
    Threads
    70
    Classifieds
    Quote Originally Posted by Bill Clemmons View Post
    Was that drawing created from that model?. Im OCD too and wonder where the radius near the top fell off the model. from the top you have a 1/4wide flat dia, a cove, another flat and then a radius... that radius isnt in the model
  16. #15
    DQ
    Nickname
    Bill (69)
    Join Date
    Mar 2010
    Location
    Liberty, NC
    Posts
    6,155
    Visit Freq
    7.00 visits/week
    Threads
    261
    Classifieds
    Quote Originally Posted by chris_goris View Post
    Chris, in SketchUp when I create a round column I start w/ a flat, 2D drawing of half the profile, then use "follow me" to fill out the column. If you're not familiar w/ creating a column in SU, this may sound confusing. Dave can probably explain it better than I did.
    For the dimensions, I take that flat, half profile and turn it into a full profile. I then apply my dimensions to that. To turn the half profile into a full profile, copy and move the half the distance of your overall diameter, then flip it along the axes (in my case, the red axis). Again, Dave can probably explain this better.
    As for that undimensioned radius, that is a transition from one known dimension (3d) to another (2d). Once I have the two diameters established, it is a simple matter to freehand that radius. Actually, all the dimensions on the left side are diameters. SU will actually give you the radius, but once I get to that point, I go w/ whatever is visually pleasing to the eye.
    Good catch, Dave. No, I'll fade the transition up about 3/8 - 1/2". I just didn't know how to show that in SketchUp.
Similar Threads
  1. Turning Question
    By Larry Rose in forum Woodturning
    Last Post: 06-29-2010, 03:05 PM
  2. Turning Question
    Last Post: 10-22-2009, 02:38 PM
  3. Turning Question
    By Larry Rose in forum Woodcarving
    Last Post: 10-19-2009, 09:04 AM
  4. Pen Turning Question
    By Dutchman in forum Woodturning
    Last Post: 02-23-2009, 07:27 PM
  5. Turning Question - the 1st of Many!
    By bluthart in forum Woodturning
    Last Post: 08-31-2008, 06:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
