Klingspor's Woodworking Shop (Festool) Ad #2
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
  1. #1
    Board of Directors
    Development Director
    DQ
    Jeremy Scuteri's Avatar
    Nickname
    Jeremy (37)
    Join Date
    Dec 2010
    Location
    Oak Ridge, NC
    Posts
    3,741
    Visit Freq
    6.38 visits/week
    Threads
    Classifieds
    A Shelf for the shop - First project in new shop
    I'm still finding homes for everything in the new basement workshop, but things are pretty much up and running at this point. I decided I needed a shelf to go above the rolling tool cabinet.
    I had some really warped and knotted black walnut from a lumber run a while back (got some good stuff too, so no complaints). I figured I would use the worst boards for this project and just see what I could come up with. I grabbed a bunch of boards and got to work.
    Some would only yield shorter boards because of the warping, but there were a few that had some straight sections as well.
    Looks a lot nicer after some planing.
    Filled all the defects with epoxy mixed with black transtint dye.
    I decided I was going to put through tenons on the shelves. I marked out the mortise with a marking gauge. I had both legs of the gauge extended, but *tried* to only have one engaged at a time. You can see that didn't quite go as planned here with the bottom line being a bit longer than intended. Oh well, that's how you know it was handmade right?
    I roughed out the mortises on the drill press.
    Next I needed to cut the tenons. I decided to make a tall auxiliary fence for the tablesaw and make the cuts that way.
    That worked pretty well, but it did require some clean up by hand. Mostly due to the difference in height between the slider and the cast iron top. Pretty easy to clean up though, so a success in my book. I made dadoes and through tenons on the side pieces. Notice that the tenons are the same thickness as the rest of the board. That didn't turn out to be a great idea. Any guesses on what happened after I did my final sanding?
    I recalled this technique from a workshop with danmart77, a simple block to keep your chisel at a 90 degree angle. I tried without the block at first because I didn't even think about it, and when things started going south, I remember that technique, found a scrap, ran it over the jointer and suddenly it was a night and day difference.
    Hmmm, something doesn't look quite right here....
    Time for a repair
    All better. The scribe line shows where the original wood is, no scribe line on the repaired part.
    The case is dry fit.
    Side view showing the through tenons and a big epoxy knot.
    Some good
    Some not so good.
    Some more dividers would look better
    And one more
    That board that I made a test cut with didn't have as much excess length as I needed.
    Another repair
    Time for a glue up. I decided to use epoxy for the glue up since there were a few gaps to deal with.
    Next I had to trim the through tenons and excess epoxy used to fill gaps. I spent some time with a flush trim saw, then decided to make a jig for the tablesaw. A simple board to act as an L-Fence. First time with this technique, it worked very well.
    Ran the case through referencing off the L Fence.
    This is where the outrigger table is really nice to have for support.
    I didn't dare go much closer than this. Close enough to peel the layer of epoxy with the tape.
    I put on some boiled linseed oil for a finish and wet sanded with 400 grit during the application.
    I cut notches in the back for electrical cord access.
    It will be mounted with a french cleat.
    The oil probably needs to dry a bit more, but I hung it up for a minute just to see what it looks like on the wall.
  2. #2
    DQ
    Nickname
    Bromley (30)
    Join Date
    Jun 2017
    Location
    Raleigh, NC
    Posts
    192
    Visit Freq
    6.08 visits/week
    Threads
    Classifieds
    Re: A Shelf for the shop - First project in new shop
    That turned out well! Thanks for showing your mistakes and repairs, I appreciate the candidness. It helps when I find myself in the same situations.
  3. The following 2 users say Thank You to mbromley :
  4. #3
    DQ
    Nickname
    Join Date
    Jul 2016
    Location
    Greensboro, NC
    Posts
    186
    Visit Freq
    4.92 visits/week
    Threads
    Classifieds
    Turned out excellent. Nice work!
  5. The following user says Thank You to David Justice for this useful post:
  6. #4
    Board of Directors
    Vice President
    DQ
    Michael Mathews's Avatar
    Nickname
    Michael (56)
    Join Date
    Mar 2012
    Location
    Chapel Hill, NC
    Posts
    1,487
    Visit Freq
    5.54 visits/week
    Threads
    144
    Classifieds
    Looks great Jeremy! Nice job!
  7. The following user says Thank You to Michael Mathews for this useful post:
  8. #5
    DQ
    Jim M.'s Avatar
    Nickname
    Woody
    Join Date
    Mar 2007
    Location
    New Church, VA
    Posts
    1,891
    Visit Freq
    6.96 visits/week
    Threads
    82
    Classifieds
    Cool post, your build looks great.
    Measure twice... cut once... SCREAM LOUDLY... get another board
  9. The following user says Thank You to Jim M. for this useful post:
  10. #6
    DQ
    Bill Clemmons's Avatar
    Nickname
    Bill (69)
    Join Date
    Mar 2010
    Location
    Liberty, NC
    Posts
    6,155
    Visit Freq
    7.00 visits/week
    Threads
    261
    Classifieds
    Looks great, Jeremy. You're getting pretty good on those repairs. BTDT.
    I'll gladly tell you how I do something. Just please don't confuse that with the right way to do it, and almost certainly not the only way.
  11. The following user says Thank You to Bill Clemmons for this useful post:
  12. #7
    Nickname
    Join Date
    Jul 2016
    Location
    Four Oaks, NC
    Posts
    416
    Visit Freq
    5.85 visits/week
    Threads
    97
    Classifieds
    Quote Originally Posted by mbromley View Post
    Mistakes? Nah. We just add 'character' intentionally.
  13. The following 2 users say Thank You to DSWalker :
  14. #8
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,779
    Visit Freq
    6.88 visits/week
    Threads
    519
    Classifieds
    Looks good and should be very functional. I'm still trying to deal with unpacking and clutter in the new shop. Still have shop cabinets to move from Cary. I got all of the ductwork out of Cary for Dust Collection and started installing it yesterday during the snow storm. I'll get some more done today and take some pictures to post.
    I don't believe in Astrology. I'm a Sagittarius and we're skeptical.
    "May the grain be with you" - Roy Underhill
  15. The following user says Thank You to KenOfCary for this useful post:
  16. #9
    DQ
    NOTW's Avatar
    Nickname
    Notw
    Join Date
    Oct 2014
    Location
    Knightdale, NC
    Posts
    622
    Visit Freq
    5.46 visits/week
    Threads
    60
    Classifieds
    That looks really good and that table saw is awesome
  17. The following user says Thank You to NOTW for this useful post:
  18. #10
    DQ
    drw's Avatar
    Nickname
    Donn (68)
    Join Date
    Sep 2009
    Location
    Holly Springs, NC
    Posts
    1,024
    Visit Freq
    4.00 visits/week
    Threads
    Classifieds
    Jeremy, thanks for the post! I especially liked that you posted the "good" and the "not so good". As we all know, woodworking isn't always smooth sailing; I appreciate you showing us your work, warts and all. At the end of the day, the shelf is not only functional but also very well crafted!
    DRW
  19. The following 2 users say Thank You to drw :
  20. #11
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    878
    Visit Freq
    6.96 visits/week
    Threads
    Classifieds
    Good job Jeremy, and it's really good to see you upend running in your new space. Congrats!
    Nothing beats a try but a failure, failure is an opportunity to learn.
    http://graywolfwoodworks.wordpress.com/
  21. The following user says Thank You to Graywolf for this useful post:
  22. #12
    DQ
    mquan01's Avatar
    Nickname
    Mike (59)
    Join Date
    Jan 2010
    Location
    Charlotte, NC
    Posts
    418
    Visit Freq
    6.58 visits/week
    Threads
    Classifieds
    Maybe a few issues, but great learning experience. Keep up the good work...
  23. The following user says Thank You to mquan01 for this useful post:
  24. #13
    Board of Directors
    DQ
    Nickname
    Jeremy (37)
    Join Date
    Dec 2010
    Location
    Oak Ridge, NC
    Posts
    3,741
    Visit Freq
    6.38 visits/week
    Threads
    Classifieds
    Thanks everyone. It sure felt good to make something again.
  25. #14
    Board of Directors
    DQ
    Nickname
    Jeremy (37)
    Join Date
    Dec 2010
    Location
    Oak Ridge, NC
    Posts
    3,741
    Visit Freq
    6.38 visits/week
    Threads
    Classifieds
    Finish is dry enough for me to hang the shelf and start using it.
    Now the tool cart can roll around without the issue of items on it being plugged in.
    Attached Images Attached Images
  26. #15
    Co-Director of Outreach Corporate Member
    DQ
    Barry W's Avatar
    Nickname
    Barry
    Join Date
    Oct 2014
    Location
    Lawsonville, NC
    Posts
    830
    Visit Freq
    5.46 visits/week
    Threads
    76
    Classifieds
    Great looking and dvery functional shelving unit. I especially like how it compliments the Makita Blue.
    "Nihil est melius quam vita diligentissima" (Nothing is better than a most diligent life.)
    -James Murray
Similar Threads
  1. My first project in my new shop
    By Acelectric in forum General Woodworking
    Last Post: 03-05-2013, 08:40 PM
  2. Second shop project completed
    By Bill Clemmons in forum User Announcements
    Last Post: 10-30-2012, 05:23 PM
  3. First project complete in new shop
    By dupont6480 in forum Workshop Discussion
    Last Post: 01-07-2012, 09:19 PM
  4. Shop storage shelf
    By Sully in forum General Woodworking
    Last Post: 10-09-2007, 08:02 PM
  5. My next shop project...
    By Monty in forum General Woodworking
    Last Post: 10-03-2005, 04:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
