West Penn Hardwoods (Ad 2)
Results 1 to 5 of 5
  1. #1
    DQ
    Nickname
    HenryW
    Join Date
    Aug 2005
    Location
    Raleigh, NC
    Posts
    1,265
    Visit Freq
    6.85 visits/week
    Threads
    250
    Classifieds
    Padauk table - bar height (Post 1 of 3)
    Here’s a kitchen table at bar height made for our recently remodeled kitchen.
    The top is a single board of Padauk (alternate spelling – Padouk), with a black lacquered maple base.
    In choosing projects, and how to accomplish them, I will often choose ones where I can attempt new techniques; (i.e. firmly not in the camp of practice makes perfect). This project had a number of firsts
    - First time using loose tenon joinery (yes I want a Domino, but am too cheap to take the plunge)
    - First use of a scraping plane
    - First time using spray finishing on one of my projects
    - First single board table top (not that this requires new technique, it’s actually easier), and the first time I have every spent more than $100 on a single board.
    - First glue-up of pieces below the top to make top look thicker
    - First glue failure – see description of base for detail.
    This is not my first piece of furniture, nor my first table; it is my first bar height table, and my first table without skirts. More on that in the description of base.
    There’s three chapters of my long winded project description; I will make these into three posts to break up the monotony.
    1. Table top (this post)
    2. Base - fabrication and issues
    https://www.ncwoodworker.net/forums/...ad.php?t=63776
    3. Finishing - table top and base
    https://www.ncwoodworker.net/forums/...646#post589646
    Chapter 1 – Table top
    The Padauk board that became the table top was a find at Capitol City Lumber (in mid-2017; there is Padauk there now, but none this size are left). They had several boards that were both long and wide – many wider than 24” and some of these as long as 14’. I chose a 27” board approx. 7.5’ long, aiming for about a 24” wide finished table top. Here’s the rough board in their hardwood building.
    This Padauk board had some black streaks that proved a challenge to remove. 60 or 80 grit ROS sanding removed the bulk of the black stains, but ‘witness’ stains remained. After sanding I tried:
    - solvents (to no avail),
    - a regular handplane (limited tearout ensued; caveat here - I have little to no expertise with handplanes), and
    - a card scraper (seemed to be effective, but very slow).
    Then I asked for advice here on NCWW in this thread:
    https://www.ncwoodworker.net/forums/showthread.php?p=577937#poststop
    I received some good advice there, particularly Jeff’s suggestion of using a No 80 scraper plane. I promptly purchased one from Klingspor’s consignment section, benefiting greatly from an employee’s assistance and advice on usage. I was able to use that effectively to remove the bulk of the witness stains with that plane. The rest of the table top was sanded and planed (scraper) as well.
    The next phase was to double up the edges of the table to make it look thicker. I had not done this before, nor really read much about exactly how other do this. Grain ‘matching’ to make the top look as seamless as possible was the goal, a challenge in the corners especially.
    I first ripped a narrow piece from each side (TS) – these were full length but only about 1.25” wide. The end cuts were jigsaw cuts that only had to be rough – as I planned to rout the final curve.
    These end pieces were cut and then glued underneath. I had to ensure that I had enough material glued there to accommodate the curves.
    I ‘roughed out’ the curve on the glued on piece as well, and then routed the end curves using with a template and top bearing bit (2” cutting length I believe).
    Then to achieve grain matching (as well as possible) at the corners, I miter cut the bottom pieces (re-reading I see I cut the miters before I routed the final curve). Because I had used curves on the ends, I decided to 'piece fit' and glue the 4 individual pieces onto the bottom rather than make a full 4 piece mitered frame and glue that to the bottom. I wasn’t sure the glued on full frame would achieve grain matches at the corners, especially with the curved ends. I did the bottom miter cuts on the end pieces with a back saw after glue up, simply cutting to the line.
    The only critical part was to keep the saw cut perpendicular, and I used a clamped on block at side of blade and in line with the cut to ensure perpendicularity. 3 of the 4 cuts were acceptable done, while I had allowed the saw to wander from the line somewhat on one corner.
    I then took the full length side pieces, which were now longer than the table because I had cut the ends, and miter cut (power saw) those to fit the openings between the end miters. Hope that makes sense. Glued and clamped these.
    The grain is not a perfect match, but the given the grain (rift sawn?) this was certainly acceptable to me.
    I filled some defects in the surface and end cuts with sawdust and glue, then did final prep on surface for finishing (more details on finishing in that chapter).
    This finished top portion then went in place in our kitchen – on a slapped together prototype base (i.e. 1x3 pine, held together with pocket screws). It served as a functional table, albeit on a wobbly base.
    The next posts will detail base construction and my mistakes there, and finally the finishing process.
    Attached Images Attached Images
    Henry W
    Prolific creator of sawdust, and sometimes shavings - with the occasional completed project.
  2. The following 5 users say Thank You to Henry W :
  3. #2
    DQ
    Nickname
    Bromley (30)
    Join Date
    Jun 2017
    Location
    Raleigh, NC
    Posts
    161
    Visit Freq
    6.23 visits/week
    Threads
    Classifieds
    Re: Padauk table - bar height (Post 1 of 3)
    Excellent write up and thank you for all the detail and work in progress pictures. I look forward to the other two parts.
  4. #3
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    6,869
    Visit Freq
    6.92 visits/week
    Threads
    596
    Classifieds
    Nicely done Henry. That 1" thick Padauk slab now looks 2" thick in pic #1 thanks to the 1" thick edging strips.
  5. #4
    DQ
    Nickname
    HenryW
    Join Date
    Aug 2005
    Location
    Raleigh, NC
    Posts
    1,265
    Visit Freq
    6.85 visits/week
    Threads
    250
    Classifieds
    Jeff:
    It worked! It worked! It looks 2" thick. Yeahhhh!
    Henry W
  6. #5
    DQ
    Nickname
    HenryW
    Join Date
    Aug 2005
    Location
    Raleigh, NC
    Posts
    1,265
    Visit Freq
    6.85 visits/week
    Threads
    250
    Classifieds
    And Jeff - one more public thank you for your No. 80 scraper plane suggestion. Using that got me 'over the hump' in terms table top surface prep. I would still be out there with a card scraper if you had not suggested the plane.
    I appreciate the advice!
    Henry W
Similar Threads
  1. Updated With Pics: Table Saw Height
    By LeftyTom in forum Power Tools and Their Use
    Last Post: 12-31-2016, 04:56 PM
  2. Adjustable Height Assembly Table?
    By SawBuck in forum Workshop Discussion
    Last Post: 10-30-2011, 09:18 PM
  3. Kitchen bar height table FINISHED
    By Mike Davis in forum General Woodworking
    Last Post: 03-06-2011, 10:02 PM
  4. Drill press table height mechanism
    By Alan in Little Washington in forum Power Tools and Their Use
    Last Post: 03-29-2009, 03:04 PM
  5. Blade height on table saw
    By Tom Dunn in forum Power Tools and Their Use
    Last Post: 12-17-2006, 01:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
