Klingspor's Woodworking Shop (Festool) Ad #2
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
  1. #1
    Nickname
    Join Date
    Jul 2017
    Location
    Fuquay Varina, NC
    Posts
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Worksharp 3000 replacement paper
    Hey fellow wood nerds!
    I got a WS3000 off another member here and haven't used it too much until late. Now I seem to be using it a lot. Curious if anyone has found suitable replacement paper on the cheap (other than what Klingspor offers or WS directly)? I'm assuming I can purchase self adhesive disks and just slap a 1/2" hole in the middle and go but I'm having an issue finding disks in higher grits (like 3200 grit that WS sells direct through Norton). Their micro mesh paper is stupid expensive and if you've used the WS3000 you know that you're basically honing in the same 1/4" space under the disk so that one strip wears out VERY fast it seems.
    Lately, I've also been looking at water systems (Tormek, Grizzly, etc.) - don't want to spend the money on the Tormek but it seems like all the other wet options (Grizzly, Rikon, Jet) either don't compare what so ever or have massive wobbles in either the stone or the shaft they ride on. I think I'm going to be using the WS for quite a while...
    Thanks it advance for any advice!
  2. The following user says Thank You to Joe G. for this useful post:
  3. #2
    DQ
    Nickname
    Join Date
    Dec 2005
    Location
    Winston-Salem, NC
    Posts
    1,554
    Visit Freq
    6.85 visits/week
    Threads
    180
    Classifieds
    Re: Worksharp 3000 replacement paper
    I use Klingspor PSA Rolls. I made disposable replacement wheels out of mdf and cover both sides with the same grit and trim to size. Only goes up to 2000 grit but after that I just hone and go.
    http://www.woodworkingshop.com/categ...2&f3=2000+GRIT
  4. The following 2 users say Thank You to zapdafish :
  5. #3
    DQ
    Gotcha6's Avatar
    Nickname
    Join Date
    Jan 2007
    Location
    Ivan's Corner (Monroe), NC
    Posts
    5,704
    Visit Freq
    6.88 visits/week
    Threads
    349
    Classifieds
    You should also look online for diamond disks of the same size. I have found several finer grits at reasonable prices that work very well. The only disadvantage with not using WS discs is that when you have other brands facing downward on the glass base you can't see the grinder in action. I'm usually pulling my chisel our every couple of seconds anyway to see what's happening with it and to allow it to cool.
    WHAT BOX?
  6. The following 2 users say Thank You to Gotcha6 :
  7. #4
    Board of Directors
    Secretary
    DQ
    Hmerkle's Avatar
    Nickname
    Join Date
    Jul 2013
    Location
    Greer, SC
    Posts
    5,537
    Visit Freq
    5.42 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Joe G. View Post
    I have the Jet (Tormek knock-off) and don't notice wobble in the shaft or stone...
    People are amazed as a shaving rises from the throat of a plane as if it’s a spell plucked from a sorcerer’s hand – Paul Sellers
  8. The following 2 users say Thank You to Hmerkle :
  9. #5
    Administrator Corporate Member
    DQ
    MarkE's Avatar
    Nickname
    Mark (63)
    Join Date
    Dec 2009
    Location
    Willow Spring, NC
    Posts
    4,359
    Visit Freq
    7.00 visits/week
    Threads
    285
    Classifieds
    When I had my WS3000 I got all my paper from Klingspor.
    I have the Grizzly T10010ANV and haven't had any problems with wobble.
    You are welcome to stop by the shop and check it out if you'd like.
    “I know you believe you understand what you think I said, but I am not sure you realize that what you heard is not what I meant.”
  10. The following user says Thank You to MarkE for this useful post:
  11. #6
    Staff Advisor
    DQ
    McRabbet's Avatar
    Nickname
    Rob (76)
    Join Date
    Nov 2005
    Location
    Hendersonville, NC
    Posts
    8,836
    Visit Freq
    6.96 visits/week
    Threads
    175
    Classifieds
    I ordered several grit levels of these back in early 2015 and they work very well and last a long time. I mounted them on the standard WS glass discs with some spray adhesive. They are a little more expensive now, but well worth the investment.
    Every day brings a new adventure -- it is great to be retired!
  12. The following 6 users say Thank You to McRabbet :
  13. #7
    Nickname
    Join Date
    Jul 2017
    Location
    Fuquay Varina, NC
    Posts
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Quote Originally Posted by MarkE View Post
    I may take you up on that offer. I bought the WS from you. Thanks, Mark.
  14. #8
    DQ
    Ralrick's Avatar
    Nickname
    Rick
    Join Date
    Mar 2007
    Location
    Raleigh, NC
    Posts
    419
    Visit Freq
    1.31 visits/week
    Threads
    82
    Classifieds
    Tagging on to this thread if that's OK . . . wondering if anyone has built a case for the WS3000 that would provide a surface to use the top of the glass plates using a rolling honing guide? This would enable full use of the sanding surface rather than just the small slice when using the traditional under-wheel sharpening. I've seen a couple designs online and was thinking of building one. Anyone build one and care to share experience and your design?
    Rick
    Rick
    Raleigh, NC
  15. The following user says Thank You to Ralrick for this useful post:
  16. #9
    Nickname
    Join Date
    Jul 2017
    Location
    Fuquay Varina, NC
    Posts
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Ralrick View Post
    Rick
    The one I got came with the wide blade attachment which also came with the little honing table which basically provides the same result: https://www.amazon.com/Work-Sharp-30.../dp/B001EPR9I6
    The jig works well for anything over 1/2" - anything under that, it tends to skew but you can just use the machine as intended for anything 2" and under anyway (putting it in the angle port). Stumpy Nubs (youtube) did a small cabinet build around his and looks like it works great. I may build something like this for it in the future for the disk storage, etc. https://www.youtube.com/watch?v=VU9WecxUFfw here is another example but neither are really a build video - just showing what can be done. https://www.youtube.com/watch?v=ZTtakqQx0jg
  17. The following user says Thank You to Joe G. for this useful post:
  18. #10
    DQ
    Bill Clemmons's Avatar
    Nickname
    Bill (69)
    Join Date
    Mar 2010
    Location
    Liberty, NC
    Posts
    6,156
    Visit Freq
    7.00 visits/week
    Threads
    261
    Classifieds
    Quote Originally Posted by McRabbet View Post
    Rob, these look interesting. I use the DMT diamond plates. Would you say these compare to those plates? I know they're thinner, but do you see them as comparable. Also, when you say they last a long time, can you put that in perspective. Would you say a year, 5 years, assuming "normal" use? I'm interested on your assessment. Thank you.
    I'll gladly tell you how I do something. Just please don't confuse that with the right way to do it, and almost certainly not the only way.
  19. The following user says Thank You to Bill Clemmons for this useful post:
  20. #11
    DQ
    Ralrick's Avatar
    Nickname
    Rick
    Join Date
    Mar 2007
    Location
    Raleigh, NC
    Posts
    419
    Visit Freq
    1.31 visits/week
    Threads
    82
    Classifieds
    Joe -
    I have seen the WS addition online but didn't think it was worth the $69. And the Stumpy video is where I saw the idea of the enclosure. I would like to build one. Also like the idea of making some MDF disks if they work as well as the glass.
    Rick
    Raleigh, NC
  21. The following user says Thank You to Ralrick for this useful post:
  22. #12
    Nickname
    Join Date
    Jul 2017
    Location
    Fuquay Varina, NC
    Posts
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Joe -
    I've read a few other forums where other folks are using the MDF disks and apparently they work pretty good. They're flat, of course but it's all about the honing paste at that point. The machine I got (from another member here) came with a lot of extra glass discs which is super helpful and time saving. I think if you were honing on the top of the machine, the MDF way would work just fine but if you were using the guide in the machine, I think it could make a mess if you're not careful. I'm also assuming the MDF probably needs a pretty large application of the honing paste the first couple times you use it as I'm guessing you're going to push a lot of that paste directly into the MDF. I was also wondering if using paste on MDF would make it swell at all but with all the posts I've read on it, it doesn't seem to be a problem...
  23. The following user says Thank You to Joe G. for this useful post:
  24. #13
    Nickname
    Join Date
    Jul 2017
    Location
    Fuquay Varina, NC
    Posts
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Bill Clemmons View Post
    Yeah, I've seen this as well and I'm super interested in the life of these disks. Overall, 15 bucks each, I'd only new a few and if they lasted even 6 months, would save a bunch on sandpaper.
  25. The following user says Thank You to Joe G. for this useful post:
  26. #14
    Nickname
    Join Date
    Jul 2017
    Location
    Fuquay Varina, NC
    Posts
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Joe -
    Yeah 69 is a bit pricey but the honing guide is a pretty decent one. I'm sure it doesn't stack up to the veritas but it's definitely repeatable, etc. It just doesn't handle small chisels very well.
  27. #15
    DQ
    MarkE's Avatar
    Nickname
    Mark (63)
    Join Date
    Dec 2009
    Location
    Willow Spring, NC
    Posts
    4,359
    Visit Freq
    7.00 visits/week
    Threads
    285
    Classifieds
    You must be using it a lot. IIRC there were quite a few sandpaper disks included in that deal.
    Anyway, you have the address, let me know if/when you want to stop by. Bring something that needs to be sharpened and we can play with the Grizzly.
Similar Threads
  1. Worksharp 3000
    By Bryan S in forum Power Tools and Their Use
    Last Post: 10-13-2010, 03:58 PM
  2. Worksharp 3000 $155
    By thrytis in forum Found for Sale/Hot Deals
    Last Post: 08-13-2010, 12:49 PM
  3. Worksharp 3000 - $155
    Last Post: 04-20-2010, 12:08 PM
  4. Worksharp 3000 - $149.95
    By Canuck in forum Found for Sale/Hot Deals
    Last Post: 02-24-2010, 02:36 PM
  5. Worksharp 3000??
    By cpowell in forum Power Tools and Their Use
    Last Post: 01-23-2009, 09:46 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
