Klingspor's Woodworking Shop (Locations) Ad #1
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
  1. #1
    DQ
    Nickname
    Zach
    Join Date
    Aug 2010
    Location
    West Columbia, SC
    Posts
    Visit Freq
    6.69 visits/week
    Threads
    Classifieds
    Part of the Unisaw Club
    I'm glad I waited and didn't buy either of the saws that I asked opinioins about in this closed thread.
    I ended up finding the below Unisaw for $300:
    Attached Images Attached Images
  2. #2
    DQ
    Bill Clemmons's Avatar
    Nickname
    Bill (69)
    Join Date
    Mar 2010
    Location
    Liberty, NC
    Posts
    6,115
    Visit Freq
    7.00 visits/week
    Threads
    259
    Classifieds
    Re: Part of the Unisaw Club
    Congrats Zach. Assuming everything is in good shape, that's a good price on a classic Unisaw. Mine is a 1982 model and looks very similar to yours. If there is any money left in the budget, I would try to add an upmarket fence.
    I'll gladly tell you how I do something. Just please don't confuse that with the right way to do it, and almost certainly not the only way.
  3. The following user says Thank You to Bill Clemmons for this useful post:
  4. #3
    DQ
    sawman101's Avatar
    Nickname
    Bruce Swanson
    Join Date
    Feb 2009
    Location
    Newton, NC
    Posts
    2,978
    Visit Freq
    6.77 visits/week
    Threads
    179
    Classifieds
    Great score Zach! I agree with what Bill said; a good fence is 50% of the quality and accuracy of the cut.
    Experience is a hard teacher; she gives the test first, and the lesson later.
  5. The following user says Thank You to sawman101 for this useful post:
  6. #4
    Nickname
    George
    Join Date
    Jan 2017
    Location
    Tellico Plains, TN
    Posts
    137
    Visit Freq
    6.92 visits/week
    Threads
    Classifieds
    I am somewhat biased, very smart lad!
  7. The following user says Thank You to gmakra for this useful post:
  8. #5
    DQ
    Jim M.'s Avatar
    Nickname
    Woody
    Join Date
    Mar 2007
    Location
    New Church, VA
    Posts
    1,855
    Visit Freq
    7.00 visits/week
    Threads
    81
    Classifieds
    Great find Zach.
    Measure twice... cut once... SCREAM LOUDLY... get another board
  9. The following user says Thank You to Jim M. for this useful post:
  10. #6
    Nickname
    Bob Vaughan
    Join Date
    Sep 2009
    Location
    Roanoke, VA
    Posts
    539
    Visit Freq
    4.73 visits/week
    Threads
    Classifieds
    The original fence design can work satisfactory but it does have a chronic weak point. There's a rubber bushing in the fence clamping arm that gets worn out over the years. This rubber bushing puts the tension on the front rail. Leaving the fence clamped down will wear this bushing to the point that the fence doesn't hold well and won't align when the locking handle is rotated downward. Replace this bushing and the fence will operate as new. There's also a stamped sheet metal pivot in the rear that sometimes gets worn. If that's the case, then it needs replacement. Both parts aren't expensive and usually available from Renovo parts.
    The locking arm, rubber bushings, and broken rear pivot. A new bushing is shown on the left and a new pivot is on the left (obviously)
    Another worn bushing that needs replacement
    There were two styles of locking arms. Both work equally well.
  11. The following 5 users say Thank You to bob vaughan :
  12. #7
    DQ
    Nickname
    Zach
    Join Date
    Aug 2010
    Location
    West Columbia, SC
    Posts
    Visit Freq
    6.69 visits/week
    Threads
    Classifieds
    Thanks all!
    Bob, thank you especially for the tip to rebuild the fence and the link for another parts supplier.
    I was adjusting the blad tilt tonight when I heard a "pop" and this is what I saw:
    After removing the top this:
    So, now I've joined OWWM, checked ebay and plan to call a local welding shop today.
    I have already watched the Fine Woodworking videos about restoring a Unisaw and I had read the unisaw disambly instructions found on OWWM. With the help of the written instructions, a friend and I tore the saw down last night.
  13. #8
    Nickname
    Bob Vaughan
    Join Date
    Sep 2009
    Location
    Roanoke, VA
    Posts
    539
    Visit Freq
    4.73 visits/week
    Threads
    Classifieds
    That's a bad thing, but not catastrophic. That break could be brazed. It doesn't look like there's a break in any of the critical alignment areas. As long as the weld/braze gets the bracket reasonably aligned, you'll be ok. Had the break gone through the middle of the tilt rod bosses or the trunnion boss, replacement would be your best bet. Of the industrial grade saws, Unisaw parts the most available on the used market.
    Unbroken trunnion bracket showing the casting details.
  14. #9
    DQ
    riggsp's Avatar
    Nickname
    Phil
    Join Date
    Jan 2017
    Location
    Charlotte, NC
    Posts
    Visit Freq
    6.46 visits/week
    Threads
    Classifieds
    I started replacing arbor bearings on a Unisaw like that yesterday for one of my customers and found the cast arbor bracket had broken...welded it back together, put in the new bearings, put it back together,and re-aligned it today...customer was happy because we couldn’t find a new or used bracket, and was afraid he’d have to buy a new saw.
  15. #10
    DQ
    Nickname
    Zach
    Join Date
    Aug 2010
    Location
    West Columbia, SC
    Posts
    Visit Freq
    6.69 visits/week
    Threads
    Classifieds
    Thanks for the info Bob and Phil!
    i dropped by a shop on Friday and he is going to spark test the part Monday and get back to me on the feasibility of repair. He seemed to doubt that it could be repaired—so I’m not sure what to expect.
  16. #11
    Nickname
    Bob Vaughan
    Join Date
    Sep 2009
    Location
    Roanoke, VA
    Posts
    539
    Visit Freq
    4.73 visits/week
    Threads
    Classifieds
    It should be weld or braze easily. Its good cast iron. There's bad cast iron also and repair welders are seeing more and more of it so they have to be cautious about predicting outcome.
  17. #12
    DQ
    Nickname
    Zach
    Join Date
    Aug 2010
    Location
    West Columbia, SC
    Posts
    Visit Freq
    6.69 visits/week
    Threads
    Classifieds
    Thanks Bob, I tried to kindly point out that it was an older part used in an industrial machine of good quality. At the same time I tried to limit how much I said because he’s the guy that welds for a living (I worked in a machine shop during college and we used to deal with folks wanting work done that knew more than our machinists—I don’t want to be that guy!).
  18. #13
    Nickname
    Bob Vaughan
    Join Date
    Sep 2009
    Location
    Roanoke, VA
    Posts
    539
    Visit Freq
    4.73 visits/week
    Threads
    Classifieds
    Good luck with the welder. Once welded, the worst thing that could happen is a slight misalignment of the mounting holes. That will necessitate reaming/filing oblong the mounting holes on the flange on the top of the cabinet so the miter gauge slot will align with the blade and that's more of a petty annoyance than anything.
    You're building for yourself a $3K+ value saw, so stick with it.
  19. #14
    DQ
    Nickname
    Bromley (30)
    Join Date
    Jun 2017
    Location
    Raleigh, NC
    Posts
    187
    Visit Freq
    6.19 visits/week
    Threads
    Classifieds
    Wow great pick up! My cabinet saw hunt continues... Keep us updated on how the fix goes.
  20. #15
    DQ
    Nickname
    Charley (76)
    Join Date
    May 2008
    Location
    Kannapolis, NC
    Posts
    1,015
    Visit Freq
    5.73 visits/week
    Threads
    Classifieds
    I hope he knows what he's doing. Welding cast iron is not easy and someone who doesn't have the experience will quickly destroy the part. Brazing is the safest repair.
    It can be welded with the proper preparation and a special high nickel content rod, but preheating before welding, and a very slow cool down is needed or it will crack in many places.
    Charley
Similar Threads
  1. Need part for old unisaw
    By weelis in forum Power Tools and Their Use
    Last Post: 08-31-2014, 09:52 AM
  2. Old Craftsman Jointer Planer, Broken Part, Part 2
    By dveenstra in forum Power Tools and Their Use
    Last Post: 11-25-2012, 09:49 PM
  3. Demuline Table(s) : Part 1 the round part
    By Shamrock in forum "How To" Forum
    Last Post: 01-14-2011, 11:41 AM
  4. Unisaw Part 2
    By Vetteman9956 in forum Workshop Discussion
    Last Post: 03-01-2010, 10:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
