Festool (Ad #2)
Results 1 to 14 of 14
  1. #1
    DQ
    tdukes's Avatar
    Nickname
    Eddie
    Join Date
    Nov 2017
    Location
    Lexington, SC
    Posts
    483
    Visit Freq
    6.85 visits/week
    Threads
    88
    Classifieds
    Milling question
    Hi Guys!
    I have a Dewalt lunch box planer and an old Powermatic 6" jointer.
    My question is, when I have to flatten a board wider than 6", is it better to start at the planer or rip the board to fit the jointer? I've been going the planer route, then going back to the jointer to do an edge, since I might mis-figure saw cuts/kerfs and end up with a piece too narrow.
    Also, how much waste should be built in when purchasing lumber?
    TIA
  2. #2
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,717
    Visit Freq
    6.88 visits/week
    Threads
    518
    Classifieds
    Re: Milling question
    Based on when those were my only planing tools, you've seen to come up with the same solution that I came up with then. I've upgraded my jointer to a 6" x 72" bed and a 15" planer, but I made due with about what you're dealing with for a long time.
    You seem to have it figured out. Plane things as flat as possible and then get a 90 on an edge and you are good to go. The rest is just finesse. Good luck.
    I don't believe in Astrology. I'm a Sagittarius and we're skeptical.
    "May the grain be with you" - Roy Underhill
  3. The following user says Thank You to KenOfCary for this useful post:
  4. #3
    Senior User Fishbucket's Avatar
    Nickname
    Joe (51)
    Join Date
    Sep 2016
    Location
    Franklinville, NC
    Posts
    285
    Visit Freq
    3.69 visits/week
    Threads
    Classifieds
    Build a jointing bed/sled for your planer. Then you can flatten any width your planer can handle.
  5. The following user says Thank You to Fishbucket for this useful post:
  6. #4
    DQ
    mkepke's Avatar
    Nickname
    Join Date
    Nov 2005
    Location
    Fuquay Varina, NC
    Posts
    1,326
    Visit Freq
    1.50 visits/week
    Threads
    115
    Classifieds
    Quote Originally Posted by tdukes View Post
    Hi Guys!
    TIA
    Depends - if your project calls for finished stock less than 6" or involves paint, I would rip the boards down and then joint. For wide 'show boards', I wouldn't rip them down.
    There are several ways to deal with wide boards:
    1 - use a planer sled like Joe described
    2 - use a hand plane to knock off the high-spots, then use the planer to take light cuts on alternating faces. You'll get close to flat as long as the board isn't too long or bent to begin with. Not recommended if you need a truly flat (planer) surface- which often is not needed.
    3 - remove the jointer guard a la https://www.woodmagazine.com/woodwor...ery/wideboards
    Waste - it depends on the project. Small projects like boxes where it will be easy to cut lots of pieces out of common sizes of lumber say 15-20% waste. With large projects like dining tables and full-size doors often only certain boards will fit your Bill of Materials so the waste can be much higher - you should plan to have enough "waste" to cut an extra table leg, an extra table-board, etc rather than trying to hit a % of the board-foot total.
    Note that your contingency plan can be "I'm going to drive back to the lumber store and get more material if I need too". It's not a risk-free contingency plan tho :-)
    -Mark
  7. The following user says Thank You to mkepke for this useful post:
  8. #5
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,146
    Visit Freq
    6.92 visits/week
    Threads
    617
    Classifieds
    I use a 20-30% bf overage for any lumber that I buy and I also pay about $1/bf extra to have it surfaced S4S before delivery.
    I have a 12" DeWalt 734 planer but no jointer (no space for one either). A Freud "glue line" rip blade on a table saw does a pretty good job edging a board too, as does a router with a bearing bit and straight edge template.
  9. The following user says Thank You to Jeff for this useful post:
  10. #6
    DQ
    Nickname
    HenryW
    Join Date
    Aug 2005
    Location
    Raleigh, NC
    Posts
    1,285
    Visit Freq
    6.58 visits/week
    Threads
    256
    Classifieds
    Quote Originally Posted by Jeff View Post
    Sounds like Jeff's setup / workflow is much like mine. I buy S2S lumber mostly, and use a TS to create edge glue surface. I use my planer (floor model, but still only 12" wide) for wider boards (>2-2.5"), but my TS to simply "rip' narrower boards to thickness. Router is used, but rarely, for glue-able edges. Also, like Jeff, I do not own a jointer, and likely couldn't squeeze one in either.
    Henry W
    Prolific creator of sawdust, and sometimes shavings - with the occasional completed project.
  11. The following user says Thank You to Henry W for this useful post:
  12. #7
    DQ
    tdukes's Avatar
    Nickname
    Eddie
    Join Date
    Nov 2017
    Location
    Lexington, SC
    Posts
    483
    Visit Freq
    6.85 visits/week
    Threads
    88
    Classifieds
    I thought about paying the extra for S4S. Have you had good results in the boards you buy that way?
  13. #8
    DQ
    tdukes's Avatar
    Nickname
    Eddie
    Join Date
    Nov 2017
    Location
    Lexington, SC
    Posts
    483
    Visit Freq
    6.85 visits/week
    Threads
    88
    Classifieds
    Quote Originally Posted by mkepke View Post
    -Mark
    Removing the guard on my jointer has rolled through my head several times.
    Might have to give that a try when its just a little oversized.
  14. #9
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,146
    Visit Freq
    6.92 visits/week
    Threads
    617
    Classifieds
    Yes the S4S if fine. Most of my wood comes from The Hardwood Store of NC so I can't speak to other suppliers.
  15. #10
    Master of None User
    DQ
    CDPeters's Avatar
    Nickname
    Chris (54)
    Join Date
    Oct 2010
    Location
    Windsor, VA
    Posts
    890
    Visit Freq
    2.85 visits/week
    Threads
    Classifieds
    The planer sled is typically the route I choose when I have stock too wide for the jointer and too out-of-flat to use.
    "Remember - If the women don't find ya handsome, they should at least find ya handy!" - Red Green
    "Always take hold of things by the smooth handle." - Thomas Jefferson
  16. The following user says Thank You to CDPeters for this useful post:
  17. #11
    DQ
    tdukes's Avatar
    Nickname
    Eddie
    Join Date
    Nov 2017
    Location
    Lexington, SC
    Posts
    483
    Visit Freq
    6.85 visits/week
    Threads
    88
    Classifieds
    How does the S4S come, thickness wise? 4/4=3/4 6/4=1-1/2? Or do you specify when you order?
  18. #12
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,146
    Visit Freq
    6.92 visits/week
    Threads
    617
    Classifieds
    How does the S4S come, thickness wise? 4/4=3/4 6/4=1-1/2 6Or do you specify when you order?
    I specify the finished thickness and minimum width that I want to receive; 4/4 will end up at 3/4" but unlikely to finish at 13/16 or 7/8" so I'd buy 5/4 and accept the 3/8" waste (3/16" planed off of each face) which isn't a big deal to me.
    6/4=1-1/2
    Yes, it's 1.5" t off of the shelf but won't finish S2S at that dimension.
    I have some 8/4 eastern white pine and poplar that was 8/4 and finished S4S at 1 7/8".
  19. The following user says Thank You to Jeff for this useful post:
  20. #13
    DQ
    tdukes's Avatar
    Nickname
    Eddie
    Join Date
    Nov 2017
    Location
    Lexington, SC
    Posts
    483
    Visit Freq
    6.85 visits/week
    Threads
    88
    Classifieds
    Thanks,
    Right, 6/4=1-1/2 didn't think before I typed. I guess if you want S4S 1-1/2 you'd have to buy 8/4.
    I may look into gong that route next time I buy wood. The lumber folks have much better equipment than I could ever afford or need plus they have more experience.
    Thanks!
  21. #14
    User Cato's Avatar
    Nickname
    Bob (68)
    Join Date
    Dec 2009
    Location
    Virginia Beach, VA
    Posts
    276
    Visit Freq
    0.00 visits/week
    Threads
    41
    Classifieds
    I have a similar set up, 6 inch jointer and 13 inch Dewalt planer. I usually edge joint and then rip to fit the jointer for flattening and then to the planer for surfacing to final thickness. I always figure in enough overage for an extra table leg and/or project boards either for grain matching or to fix a mistake.
  22. The following user says Thank You to Cato for this useful post:
Similar Threads
  1. Need Some Help with Milling
    By FlannelMan in forum General Woodworking
    Last Post: 02-12-2015, 01:15 PM
  2. Saw milling
    By Max Pedneau in forum Wood
    Last Post: 12-03-2014, 07:36 PM
  3. Milling?
    By Bugle in forum Where Can I Find, Buy or Sell
    Last Post: 06-11-2013, 04:28 PM
  4. Milling Help
    By AlexSwansboro in forum Workshop Discussion
    Last Post: 10-12-2011, 07:46 PM
  5. Need Help Milling
    By Jeff in forum Wood
    Last Post: 10-27-2008, 08:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
