West Penn Hardwoods (Ad 1)
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Thread: Miter Gauge
  1. #1
    DQ
    Nickname
    Zach
    Join Date
    Aug 2010
    Location
    West Columbia, SC
    Posts
    159
    Visit Freq
    4.81 visits/week
    Threads
    Classifieds
    Miter Gauge
    I now have new to me Unisaw and blew my budget even with a great deal! The saw came without a miter gauge. The original Rockwell/delta miter gauges are about $50 with shipping. Is it much of an upgrade to go with an aftermarket miter gauge? Any miter gauge reccomendations? I plan on making a sled, so Iím really only concerned with simple cuts on the miter gauge.
    Thanks!
    Zach
  2. #2
    DQ
    JohnW's Avatar
    Nickname
    John (64)
    Join Date
    Feb 2007
    Location
    Charlotte, NC
    Posts
    814
    Visit Freq
    5.92 visits/week
    Threads
    55
    Classifieds
    Re: Miter Gauge
    You get what you pay for when buying a miter gauge. The OEM gauge that comes with most cabinet saws is just a basic use thing but are heavy duty and solid. There are lots of plastic gauges out there and while cheap, not worth having. So if its basic you are after, the Delta style OEM gauges are good. CPO has a very good Delta gauge on sale right now for 38 bucks.
    I use an Incra 1000SE and really like it for accuracy and reliability. Depending on what you are making, the accuracy you get from the Incra is well worth the higher cost. They go for around 139.00.
  3. The following user says Thank You to JohnW for this useful post:
  4. #3
    Staff Advisor
    McRabbet's Avatar
    Nickname
    Rob (75)
    Join Date
    Nov 2005
    Location
    Hendersonville, NC
    Posts
    8,755
    Visit Freq
    6.81 visits/week
    Threads
    173
    Classifieds
    Re: Miter Gauge
    I strongly recommend the Osborne EB-3, available from Klingspor's Woodworking Shop for $139.
    Every day brings a new adventure -- it is great to be retired!
  5. The following user says Thank You to McRabbet for this useful post:
  6. #4
    DQ
    Jim M.'s Avatar
    Nickname
    Woody
    Join Date
    Mar 2007
    Location
    New Church, VA
    Posts
    1,650
    Visit Freq
    6.96 visits/week
    Threads
    76
    Classifieds
    Re: Miter Gauge
    I use Incra 3000SE miter gauges, I have two and love them.
    Measure twice... cut once... SCREAM LOUDLY... get another board
  7. The following user says Thank You to Jim M. for this useful post:
  8. #5
    User TENdriver's Avatar
    Nickname
    TENdriver
    Join Date
    Nov 2012
    Location
    Wdbg, VA
    Posts
    500
    Visit Freq
    6.42 visits/week
    Threads
    Classifieds
    Re: Miter Gauge
    Zach, I have a Incra 1000 HD and like it. I also use the OEM miter quite a bit. In fact, I have two of them and sometimes alternate between them for specific cuts. I also use the OEM for certain coarse or rough cuts and reserve the Incra for the precision work.
  9. The following user says Thank You to TENdriver for this useful post:
  10. #6
    DQ
    Nickname
    Charley (75)
    Join Date
    May 2008
    Location
    Kannapolis, NC
    Posts
    991
    Visit Freq
    5.62 visits/week
    Threads
    Classifieds
    Re: Miter Gauge
    I still use my Delta Miter Gauge because the bar fits the miter slots in my Unisaw very well. For miter setting accuracy, I use my MiterSet gauges. http://miterset.myshopify.com/?aff=65. I've owned some of the fancier miter gauges but like the MiterSet setup gauges better because I get better results when using them. The MiterSet Segments gauge allows you to set up for making segmented circle cuts perfectly, where some of these cuts require angles accurate to three decimal places. This is easily done with the MiterSet Segments gauge. It's companion gauge lets you set your miter gauge to any angle in increments of 1/2 degree, and is also highly accurate.
    I have not had even a single even slight off angle cut since getting these jigs, and a package of both gauges is cheaper than some of the fancy miter gauges being sold today. Using them is easy, just place your miter gauge in the jig and position two pins in the jig for the angle or number of segments that you want. Then push your miter gauge up against the two pins and tighten it's locking knob. Put the miter gauge back in the saw's miter slot and make perfect angled cuts. The MiterSet jigs are high quality, made from black anodized aluminum and steel. They are nicer made than some of the aerospace hardware that I once worked with.
    Charley
  11. The following user says Thank You to Charles Lent for this useful post:
  12. #7
    DQ
    Gofor's Avatar
    Nickname
    Join Date
    Mar 2006
    Location
    Goldsboro, NC
    Posts
    3,075
    Visit Freq
    6.62 visits/week
    Threads
    76
    Classifieds
    Re: Miter Gauge
    Quote Originally Posted by McRabbet View Post
    Ditto on the Osborne: It has micro-adjustment to get it dead on; extendable fence with stop block; adjustment to take out any slop in your miter slot; and excellent fence support to prevent your work from skewing. Very happy with mine and have had it for several years.
    Practicing at practical woodworking
  13. The following user says Thank You to Gofor for this useful post:
  14. #8
    User Pop Golden's Avatar
    Nickname
    Pop (77)
    Join Date
    Jul 2011
    Location
    Charlotte, NC
    Posts
    772
    Visit Freq
    3.85 visits/week
    Threads
    20
    Classifieds
    Re: Miter Gauge
    ​I had a Jessem gauge, but never got it square. Their design is so that you have to take the gauge apart, adjust it and reassemble to check it's squareness. Jessem is a good bunch of souls and they gave me a refund. I then got a Incra 1000HD and love it.
    Pop
    ​With Enough Thrust Pigs Fly Just Fine.
  15. The following user says Thank You to Pop Golden for this useful post:
  16. #9
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,318
    Visit Freq
    6.96 visits/week
    Threads
    Classifieds
    Re: Miter Gauge
    I also use the Osborne. Highly recommended.
    Ban shredded cheese, make America grate again.
    "May the grain be with you" - Roy Underhill
  17. The following user says Thank You to KenOfCary for this useful post:
  18. #10
    Administrator Corporate Member
    DQ
    ehpoole's Avatar
    Nickname
    Ethan (46)
    Join Date
    Oct 2009
    Location
    Anderson, SC
    Posts
    5,782
    Visit Freq
    6.73 visits/week
    Threads
    201
    Classifieds
    Re: Miter Gauge
    Quote Originally Posted by JohnW View Post
    Any of the Incra series miter gauges are a tremendous upgrade and can do far more than any stock miter gauge. They can be quickly adjusted to any angle within the allowed range and include a vernier scale for sub-degree accuracy (marked in 0.1 degree increments), allow tuning to your tablesaw's miter slot to eliminate slop as every saw's miter slot is a little different, and include an extremely handy extendable fence with built in stops so that you can quickly reproduce cuts of identical length without the need to repeatedly measure length making it trivial to to turn out pieces of absolutely equal length all day long. I use Incra 1000SE miter gauges on my tablesaw, bandsaw, and even my router table.
  19. The following 2 users say Thank You to ehpoole :
  20. #11
    Nickname
    Mel
    Join Date
    Jul 2017
    Location
    Apex, NC
    Posts
    Visit Freq
    6.15 visits/week
    Threads
    Classifieds
    Re: Miter Gauge
    +1 what Tendriver said.
  21. The following user says Thank You to Melinapex for this useful post:
  22. #12
    DQ
    Nickname
    Zach
    Join Date
    Aug 2010
    Location
    West Columbia, SC
    Posts
    159
    Visit Freq
    4.81 visits/week
    Threads
    Classifieds
    Re: Miter Gauge
    Thanks all!
    i ended up finding a miter gauge of the same vintage of the saw. If I don’t like the miter gauge, I will probably buy the Incra.
  23. #13
    DQ
    sawman101's Avatar
    Nickname
    Bruce Swanson
    Join Date
    Feb 2009
    Location
    Newton, NC
    Posts
    2,535
    Visit Freq
    6.15 visits/week
    Threads
    160
    Classifieds
    Re: Miter Gauge
    I couldn't get the miter gage that came with my Jet cabinet saw to perfect square; I bought an Incra miter gage and love it--worth every penny!
    Experience is a hard teacher; she gives the test first, and the lesson later.
  24. #14
    Papa Red Senior User
    DQ
    red's Avatar
    Nickname
    Red
    Join Date
    Nov 2009
    Location
    Denver, NC
    Posts
    2,266
    Visit Freq
    4.50 visits/week
    Threads
    Classifieds
    Re: Miter Gauge
    +10. Very accurate.
    Red
    Red
  25. #15
    Nickname
    Guy Belleman
    Join Date
    May 2007
    Location
    Troutdale, VA
    Posts
    540
    Visit Freq
    0.23 visits/week
    Threads
    46
    Classifieds
    Re: Miter Gauge
    I like the Incra V27 too.
Similar Threads
  1. Miter Gauge Problem
    By Mt. Gomer in forum Power Tools and Their Use
    Last Post: 12-23-2009, 04:55 PM
  2. Aftermarket Miter Gauge
    By Bigdog72 in forum Power Tools and Their Use
    Last Post: 11-30-2009, 09:33 PM
  3. Ral CL: Incra panel gauge and Incra 2000 miter gauge - $230 (Youngsville, NC)
    By Douglas Robinson in forum Found for Sale/Hot Deals
    Last Post: 06-19-2008, 03:20 PM
  4. Miter Gauge recomendation
    By welldigger in forum Power Tools and Their Use
    Last Post: 06-02-2008, 05:15 PM
  5. Miter Gauge Upgrade
    By rick7938 in forum Power Tools and Their Use
    Last Post: 10-10-2007, 01:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
