Klingspor's Woodworking Shop (Locations) Ad #1
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
  1. #1
    DQ
    Phil S's Avatar
    Nickname
    Phil Soper (67)
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    4,148
    Visit Freq
    10.00 visits/week
    Threads
    498
    Classifieds
    Tool chest drawer bearing maintenance question
    I found a old/new Lista cabinet on Craigs list. 350 lbs of cabinet with seven drawers that have never been used, but the cabinet has been in storage for the last 10 or 15 years and the bearing grease has dried up and the bearings will barely rotate.
    My question is what is the best way to unfreeze these bearings. The bearings are riveted to the drawer slide frame and cannot be removed.
    here are the photos
    There are 56 of these bearings
    Thanks
    Attached Images Attached Images
  2. #2
    DQ
    Charlie's Avatar
    Nickname
    Charlie (72)
    Join Date
    Nov 2008
    Location
    Raleigh, NC
    Posts
    1,663
    Visit Freq
    6.73 visits/week
    Threads
    127
    Classifieds
    Re: Tool chest drawer bearing maintenance question
    I would squirt some paint thinner into each bearing, rotate until free (may require a couple doses), blow out with compressed air and then work some white lube into each bearing. Better than new.
  3. The following user says Thank You to Charlie for this useful post:
  4. #3
    DQ
    Nickname
    Andy
    Join Date
    Feb 2008
    Posts
    2,398
    Visit Freq
    6.38 visits/week
    Threads
    139
    Classifieds
    I would apply Marvel Mystery Oil to each, let soak a day then spray with canned air or compressed air if you have a compressor, then reapply grease. I can't say enough good about MMO!
  5. The following user says Thank You to CaptnA for this useful post:
  6. #4
    Nickname
    Danny (71)
    Join Date
    Oct 2009
    Location
    Whispering Pines, NC
    Posts
    185
    Visit Freq
    4.73 visits/week
    Threads
    Classifieds
    Seven new drawers to fill up. Where there’s a will....
  7. #5
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    6,383
    Visit Freq
    6.92 visits/week
    Threads
    574
    Classifieds
    #### unsealed bearings and double #### them! Spray the bearing traces with PB blaster from the little nozzle and let them sit, then spray a few more times.
    Follow up with DuPont Teflon Multi-Use Lubricant. It almost a dry lubricant that doesn't cling to dust, dirt, sawdust, etc. I have a few cans if you want one free!
    http://www.performancelubricantsusa....-lubricant.php
  8. The following 2 users say Thank You to Jeff :
  9. #6
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    477
    Visit Freq
    5.12 visits/week
    Threads
    Classifieds
    Yes, some type of solvent and some time to start. Then some spray lithium grease. Or a lubricant of your choosing.
    Nothing beats a try but a failure, failure is an opportunity to learn.
    http://graywolfwoodworks.wordpress.com/
  10. The following user says Thank You to Graywolf for this useful post:
  11. #7
    DQ
    Nickname
    Jim (70)
    Join Date
    Feb 2013
    Location
    Durham, NC
    Posts
    1,363
    Visit Freq
    7.00 visits/week
    Threads
    82
    Classifieds
    I usually clean bearings with kerosene. Cheap and gets the job done.
  12. The following user says Thank You to nn4jw for this useful post:
  13. #8
    DQ
    Bear Republic's Avatar
    Nickname
    Steve (52)
    Join Date
    Apr 2017
    Location
    Raleigh, NC
    Posts
    309
    Visit Freq
    5.04 visits/week
    Threads
    Classifieds
    I recommend patience..... with all of those bearings you'll need it. Can't wait to see the revealing
    - Not living life till you're part of the Food Chain
  14. #9
    DQ
    BWhitney's Avatar
    Nickname
    Join Date
    Feb 2011
    Location
    Fayetteville, NC
    Posts
    160
    Visit Freq
    2.38 visits/week
    Threads
    19
    Classifieds
    #2 on what Jeff says about PB Blaster. I always "exercise" the bearings, and in this case would probably try a rubber sanding drum insert chucked up in a drill. Spray with PB Blaster, rotate by hand to get started, rotate with the drill, lubricate.
    That should make them glide freely.
    If they aren't fastened in, I like to use a pointy dowel chucked up in the drill to rotate them. I have different sizes of pointy dowels, some 1/2 inch and larger have a hole drilled in the dowel with a headless bolt epoxied in for the drill chuck to bite on.
    Works every time so far, but sometimes I do wonder why I bother.
  15. The following user says Thank You to BWhitney for this useful post:
  16. #10
    Nickname
    Join Date
    Jan 2013
    Location
    Mc Leansville, NC
    Posts
    1,698
    Visit Freq
    4.54 visits/week
    Threads
    Classifieds
    I have 3 old Listas like that that came with a few seized bearings... some WD40 worked like a charm.... then I sprayed them with white lithium grease, theyve been fine for 4-5 years now.
  17. #11
    DQ
    scsmith42's Avatar
    Nickname
    Scott Smith
    Join Date
    Mar 2007
    Location
    New Hill, NC
    Posts
    5,013
    Visit Freq
    2.81 visits/week
    Threads
    217
    Classifieds
    Phil,
    All of the above.....
    OR....
    IF you want to eliminate the second step, use LPS2 to both clean and lubricate the bearings.
  18. #12
    Board of Directors
    Vice President
    DQ
    Hmerkle's Avatar
    Nickname
    Join Date
    Jul 2013
    Location
    Greer, SC
    Posts
    4,990
    Visit Freq
    2.96 visits/week
    Threads
    270
    Classifieds
    Phil agree with a solven to free the bearings, but I have almost exclusively switched over to B'laster dry lube - you can still get it at Lowes and it is everything Chris stated in his blog two years ago - the best things: 1. no silicon 2. no "wet" lube for dust to cling to!
    https://www.popularwoodworking.com/w...aster-dry-lube
    People are amazed as a shaving rises from the throat of a plane as if itís a spell plucked from a sorcererís hand Ė Paul Sellers
  19. The following user says Thank You to Hmerkle for this useful post:
  20. #13
    DQ
    Gofor's Avatar
    Nickname
    Join Date
    Mar 2006
    Location
    Goldsboro, NC
    Posts
    3,073
    Visit Freq
    6.65 visits/week
    Threads
    76
    Classifieds
    Although the PB Dry lube would probably be best, 3-in-One also makes a Garage Door Lube that dries so it doesn't gather dust and debris. However, it says do not use on surfaces to be painted, so may contain silicone.
    Practicing at practical woodworking
  21. #14
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,311
    Visit Freq
    7.00 visits/week
    Threads
    Classifieds
    Not sure I'd worry about silicone in this application. It's not coming into contact with your wood. But the advice you've already gotten sounds good to me.
    During a summer job I had waxing and working on School Buses as a teenager we took all the bearings and cleaned them in a big tub of solvent then dried and re-greased them. One of the jobs the mechanics let us kids do after we were done waxing 70 some school buses over the summer. They of course re-installed them. We were only trusted with the cleaning. But I digress.
    Ban shredded cheese, make America grate again.
    "May the grain be with you" - Roy Underhill
  22. #15
    Board of Directors
    Vice President
    DQ
    Hmerkle's Avatar
    Nickname
    Join Date
    Jul 2013
    Location
    Greer, SC
    Posts
    4,990
    Visit Freq
    2.96 visits/week
    Threads
    270
    Classifieds
    Quote Originally Posted by KenOfCary View Post
    I am not sure where I heard this or if it is simply an old (new) wives tail...
    If you use spray silicone in your shop it can remain for a long time and affect finishing (fisheye etc.)
    I stopped using silicone products (for lubrication) when I found the dry lube - it is MUCH better and low to no risk with finishes!
    (I actually used it on my hedge trimmer and swear it cuts better. The clippings do stick to the bar and I feel like it is sharper, I am thinking that is the reduced COF in the blades. (Cooeficient of friction)
Similar Threads
  1. Drawer pulls for tool chest
    By Rwe2156 in forum General Woodworking
    Last Post: 01-24-2015, 03:42 PM
  2. Tool chest build question
    By Rwe2156 in forum Project Design
    Last Post: 12-02-2014, 01:52 PM
  3. 4 drawer chest
    By CrealBilly in forum General Woodworking
    Last Post: 11-21-2010, 10:40 PM
  4. Chest of Drawer
    By pcooper in forum General Woodworking
    Last Post: 03-06-2009, 06:06 PM
  5. Jointer bearing question
    By Keye in forum Power Tools and Their Use
    Last Post: 05-04-2008, 10:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
