Klingspor's Woodworking Shop (Locations) Ad #1
Results 1 to 7 of 7
  1. #1
    Nickname
    jeff
    Join Date
    Sep 2010
    Location
    Chesterfield, SC
    Posts
    Visit Freq
    2.85 visits/week
    Threads
    Classifieds
    Jointer tables need resurfacing
    Does anyone know of a machine shop that has experience regrinding large jointer infeed and outfeed tables in the Monroe area?
  2. #2
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,125
    Visit Freq
    7.00 visits/week
    Threads
    711
    Classifieds
    Re: Jointer tables need resurfacing
    How big are the tables?
    Surface grinding machines I have seen in job shops are usually around 12 x 36 much bigger and you are looking for a big machine shop.
    Are they really bad warped or just need adjusting and cleaning?
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  3. The following user says Thank You to Mike Davis for this useful post:
  4. #3
    Administrator Corporate Member
    DQ
    ehpoole's Avatar
    Nickname
    Ethan (46)
    Join Date
    Oct 2009
    Location
    Anderson, SC
    Posts
    5,881
    Visit Freq
    6.92 visits/week
    Threads
    204
    Classifieds
    Keep in mind that plus or minus a few mils (thousandths) is not an issue for woodworking equipment so they are rarely ground perfectly flat over their width and length unless it was a very high end jointer, so it is fairly rare to need tables to be reground unless something major has happened (severe twist, such as from a fire) or there is extreme wear. If the issue is that the tables are not parrallel to one another then that is typically a basic setup issue resolved by shimming the two tables parallel and a part of jointer ownership like setting the knives.
    I mention the above solely to ask if you are certain that regrinding is actually required? If it is just a setup issue then members here can squally help you get it resolved and possibly save you the cost of regrinding the tables. Otherwise I wish you the best in your search for a machine shop!
  5. The following user says Thank You to ehpoole for this useful post:
  6. #4
    Nickname
    jeff
    Join Date
    Sep 2010
    Location
    Chesterfield, SC
    Posts
    Visit Freq
    2.85 visits/week
    Threads
    Classifieds
    infeed is 56" x 16 1/2" and out feed is 40" x 16 1/2". Out feed is ok but infeed has a .023" dip in the middle.
  7. #5
    Nickname
    jeff
    Join Date
    Sep 2010
    Location
    Chesterfield, SC
    Posts
    Visit Freq
    2.85 visits/week
    Threads
    Classifieds
    It's a parallelogram machine. I'm installing a Byrd head and I may try it first to see how it performs and if the results are not nice and straight then maybe I'll look into grinding them. I just don't know of a shop with a big Blanchard or surface grinder.
  8. #6
    DQ
    Nickname
    Join Date
    Jan 2014
    Location
    Ramseur, NC
    Posts
    798
    Visit Freq
    1.62 visits/week
    Threads
    67
    Classifieds
    If you can't find a grinder that big, a vertical mill with a surfacing fly cutter will get within 0.001
    www.militaryappreciationday.org
    The largest all-volunteer, "take the troops fishing" organization in the world. Headquartered right here in North Carolina!
  9. #7
    Nickname
    jeff
    Join Date
    Sep 2010
    Location
    Chesterfield, SC
    Posts
    Visit Freq
    2.85 visits/week
    Threads
    Classifieds
    I did not think of that. Thank you for the suggestion.
Similar Threads
  1. resurfacing waterbased poly
    By BKHam in forum Finishing
    Last Post: 07-01-2015, 03:21 PM
  2. Two More End Tables Done.
    By Canuck in forum General Woodworking
    Last Post: 08-20-2010, 01:45 PM
  3. shimming jointer tables
    By gilliu in forum Power Tools and Their Use
    Last Post: 01-17-2008, 10:01 PM
  4. End Tables
    By Joe Scharle in forum General Woodworking
    Last Post: 09-11-2007, 11:23 PM
  5. MM jointer / planer 1phase, 16"jointer 3phase Raleigh
    By Toddler in forum Found for Sale/Hot Deals
    Last Post: 05-01-2007, 03:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
