Klingspor's Woodworking Shop (Festool) Ad #2
Results 1 to 12 of 12
  1. #1
    DQ
    Nickname
    Join Date
    Feb 2010
    Location
    Wadesboro, NC
    Posts
    88
    Visit Freq
    6.96 visits/week
    Threads
    Classifieds
    Tilt-Top Candle Stand
    I just finished this tilt-top candle stand and wanted to share. The wood is African Mahogany and the piece is 26 1/2" tall. It, like the highboy I posted on 10/22, is from Norman Vandal's Queen Anne Furniture (what a great book!). In Vandal's piece, the top is 17" in diameter. I wanted the top to be a solid board and the widest piece of African mahogany I could find was 16" (thanks ebay). After turning it round on the lathe, the finished top is 15 3/4" in diameter. This was a fun, small project and I really enjoyed working on it. Thanks for looking.
    Rob Liles
  2. #2
    DQ
    JohnnyR's Avatar
    Nickname
    Join Date
    Oct 2013
    Location
    Rolesville, NC
    Posts
    527
    Visit Freq
    5.62 visits/week
    Threads
    Classifieds
    Re: Tilt-Top Candle Stand
    Beautiful work Rob!
  3. #3
    DQ
    Jim M.'s Avatar
    Nickname
    Woody
    Join Date
    Mar 2007
    Location
    New Church, VA
    Posts
    1,645
    Visit Freq
    6.96 visits/week
    Threads
    76
    Classifieds
    Very nice Rob, a true classic.
    Measure twice... cut once... SCREAM LOUDLY... get another board
  4. #4
    Nickname
    tom
    Join Date
    Oct 2009
    Location
    Clayton, NC
    Posts
    Visit Freq
    6.65 visits/week
    Threads
    Classifieds
    I really like the classic look of this. What is your finish sched. ?
  5. #5
    DQ
    sawman101's Avatar
    Nickname
    Bruce Swanson
    Join Date
    Feb 2009
    Location
    Newton, NC
    Posts
    2,517
    Visit Freq
    6.12 visits/week
    Threads
    155
    Classifieds
    Very nicely crafted Rob! I don't want my wife to see this one or you know what she'll be wanting.
    Experience is a hard teacher; she gives the test first, and the lesson later.
  6. #6
    DQ
    Nickname
    Ed
    Join Date
    Oct 2006
    Location
    Plano, TX
    Posts
    119
    Visit Freq
    4.23 visits/week
    Threads
    Classifieds
    beautiful piece Rob, what did you use for hinge and stop?
    Finish?
    Ed
  7. #7
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,313
    Visit Freq
    6.96 visits/week
    Threads
    Classifieds
    Very nicely done. I think it was a good choice to use a single piece top. Makes it unique.
    Ban shredded cheese, make America grate again.
    "May the grain be with you" - Roy Underhill
  8. #8
    DQ
    Nickname
    Join Date
    Feb 2010
    Location
    Wadesboro, NC
    Posts
    88
    Visit Freq
    6.96 visits/week
    Threads
    Classifieds
    Thanks for the comments. Tom from Clayton, the finish is as follows; I sand everything to 220 grit. On turned pieces (the pedestal and top) that are sanded on the lathe, even at 220 grit, there will be sanding scratches across the grain. I have learned from trial and error that if I follow the sanding on the lathe with a course, medium and then fine scotch-brite abrasive pad that those last scratches disappear. I then used a water based dye, very diluted, to even out the differences in colors in the various wood pieces. The top, for example, was a good bit darker than the pedestal and feet and this evened it out. Due to the complexity of the pedestal, I sprayed the dye which I have found to be a much better and more even way of applying water based dye. I then applied six coats of General Finishes satin Enduro-Var water based finish rubbing each coat out with progressively finer scotch-brite abrasive pads. Oddly enough, I brushed on the finish instead of spraying due to the temperature and the small size of the piece. It would have taken about three times as much time to set up, prepare the spray and clean up the spray equipment than brushing on the finish. Plus, I enjoyed the quiet and some decent music on in the background while doing that.
    Ed, the top of the pedestal has a 1 1/2" round tenon turned on it where a 3 1/2" square block is then mounted. Two stretchers are mounted to the underside of the top in line with the grain and the top then pivots on 3/8" wooden pins mounted off center in the block. The top is locked in place with a tilt-top latch I got from Horton Brasses. I'm not sure I'm describing it accurately and it is much better seen than explained.
    Again, thanks for looking and your comments. Rob
  9. The following 2 users say Thank You to robliles :
  10. #9
    DQ
    Canuck's Avatar
    Nickname
    Wayne (70)
    Join Date
    Dec 2005
    Location
    Cary, NC
    Posts
    6,802
    Visit Freq
    7.04 visits/week
    Threads
    491
    Classifieds
    Nicely done!
    ..............found out many years ago that Elbow Grease doesn't come in a bottle!!!!
  11. #10
    User Wyatt Co.'s Avatar
    Nickname
    Join Date
    Aug 2017
    Location
    Calypso, NC
    Posts
    406
    Visit Freq
    6.23 visits/week
    Threads
    Classifieds
    That is one beautiful piece of furniture!
    Happiness is a direction not a destination. ~Athena Orchard
  12. #11
    Nickname
    Mel
    Join Date
    Jul 2017
    Location
    Apex, NC
    Posts
    Visit Freq
    6.19 visits/week
    Threads
    Classifieds
    Wow, great looking piece. How did you attach the legs? I am thinking of doing a table with three legs like that and not sure what joinery to use to be sure it comes out even and level.
  13. #12
    DQ
    Nickname
    Join Date
    Feb 2010
    Location
    Wadesboro, NC
    Posts
    88
    Visit Freq
    6.96 visits/week
    Threads
    Classifieds
    Mel,
    The legs are attached to the pedestal post using sliding dovetails.
  14. The following user says Thank You to robliles for this useful post:
Similar Threads
  1. Left tilt TS or a right tilt TS?
    By Sharp Blade in forum Power Tools and Their Use
    Last Post: 11-26-2008, 12:03 PM
  2. another candle
    By FredP in forum General Woodworking
    Last Post: 06-24-2008, 06:15 PM
  3. Left tilt vs. right tilt table saws???
    By sapwood in forum Power Tools and Their Use
    Last Post: 08-28-2006, 03:06 PM
  4. Candle stand-Claro graft walnut and big leaf maple burl
    By Kyle in forum General Woodworking
    Last Post: 07-17-2006, 07:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
